SRM problem, help needed!
Antti Kuitto
by Antti Kuitto
Just got my second hand SRM´s today. Powercontrol was "dead", so I charged it for 6 hours, but still nothing when mode was pressed over 10 seconds. When plugged on pc (serial cable with usb-adapter), display flashes few times and then software says no powercontrol plugged when trying to make contact with powercontrol. I also tried a method from srm-site, which was 3-5 second plug-unplug etc. from charger, no help from this either.
Seller said that powercontrol battery was changed last summer and system was working week ago, so whats the problem?
First I thought that charger was broken, since there was something happening when plugged to pc -> so I took the knife, cut wires on charger and measured the voltage, which was 12.90 v which should be ok..
So, any ideas? Charger plug?
whodesigns
by whodesigns
Antti Kuitto wrote:Just got my second hand SRM´s today. Powercontrol was "dead", so I charged it for 6 hours, but still nothing when mode was pressed over 10 seconds. When plugged on pc (serial cable with usb-adapter), display flashes few times and then software says no powercontrol plugged when trying to make contact with powercontrol. I also tried a method from srm-site, which was 3-5 second plug-unplug etc. from charger, no help from this either.
Sometimes the battery gets so flat even the plug unplug doesn't work, what you do is open the PC disconnect the battery and connect it directly to a 3 cell charger, do not use the standard SRM charger.
What happens is the PC board has a charge circuit, but if the battery is totally flat there isn't enough power to switch on the microcontroller, so you need to charge the battery direct.
Specialist Sports Technology
http://www.luescherteknik.com.au
Carbon Bike Repairs
http://www.carbonbikerepair.com.au
Antti Kuitto
by Antti Kuitto
Thanks for your reply whodesigns,
but i was wondering how the powercontrol has "power" to flash display few times when connected to computer, if the battery is totally flat?
I sent email to SRM last evening, but they haven´t responded yet...
Geoff
by Geoff
I have found in the past, upon attaching the Powercontroller to the charger, that sometimes I need to 'jiggle' the connection and press the 'battery status' Mode/Set buttons several times to confirm that it is charging. I have plugged my Powercontrollers in various times, forgot to do this and found that it did not charge. Also, I have one charger that does not work for some reason, so that could be the problem, too.
Antti Kuitto
by Antti Kuitto
It works now! Charger plug was broken, one of the two wires was cut off from plug..quite simple to fix. :)
I think this should be checked also if there are some kind of connection problems with plug ( wire is so close that in some position it works, some not). To check this, just screw the plug open, it folds on three pieces.
Antti Kuitto
by Antti Kuitto
Now it is charged for 12 hours. But there is still BAT sign on powercontrol screen and minus (-) sign on bottom right corner of display. Display stays on for about 30 seconds, then it turns off, but comes back when any button is pressed. But buttons don't do anything else, powercontrol shows only this basic screen with date and time (which is not running, like it did when charged). And computer still won't recognize powercontrol.
I understand that charger could fail with use, but now it seems that powercontrol is also faulty in someway, so it seems that i was bluffed when i bought this? :(
Edit. Plugged it to charger again, now battery sign flashes and there is + sign, so it charges. And now all the functions seem to work....maybe I leave it on charger for a while and then check again. Still it seems that this is not normal...and it is little bit hard to use if it needs to be plugged in while used :D
edit # 2. Now after a little bit of charging, everything seems to be working ok. It connects to computer like it should and cadence is showing when i move power sensor behind the crank. Hopefully everything goes fine after this.. :)
ms6073
by ms6073
I think the one time I allowed my PCV battery to get completely drained, it had to be charged for 20-24 hours before it worked properly again. Also, once you get it charged, I know the battery indicator will say 29-hours remaining, but I have never seen my PCV able to run more than 12-14 hours before going dead - no fun in the middle of a training ride! Most wired SRM users I have spoken with typically re-charge the PC 1-2 times each week if not after every ride!
- Michael
Geoff
by Geoff
If the Powercontroller has not been stored charged for a long period, the battery will not recharge properly and will need to be replaced. I have several systems and did not use one Powercontroller all winter and had that happen once.
Stefano
by Stefano
Sorry to dredge up an old topic, hope this isn't answered somewhere else already...
I just bought an SRM PCV with computer download cable for a good price- looks like the battery is dead. However, it only came with the computer download cable, so before I send it back to SRM, I want to confirm that it is possible to charge the powercontrol from a usb wall outlet (like an iphone charger, for example) and that I am not just using the wrong device.
Here is a link to the cable I am talking about:
http://www.trainsharpcyclecoaching.co.u ... -PC-V.html
Thanks,
Stefano
bricky21
by bricky21
SRM specifically states that the Download cable cannot be used to charge the powercontrol V. Here is the rub. I bought a used PCV, and it arrived fully charged without a charger. I contacted the seller, and he told me that he just used the download cable with a wall charger. I have tried several different wall chargers and none of them work. Neither does plugging it into the computer. So either the seller was lying and kept the charger for himself, or it actually does work for some folks. :noidea:
Stefano
by Stefano
That's what I was afraid of. I'm pretty sure that the PCVI download cable does work with the powercontrol, so it may that's where the confusion is coming from. Yay, I get to buy a 50 dollar charger! *sarcasm*
ms6073
by ms6073
Yes, you are correct that for the SRM PC-VI, the USB download cable doubles as the charging cable. Unfortunately for the PC-V, the pin-outs of the wiring harness are specific to the function and that is what prevents the download cable from acting as a charging cable.
- Michael
