Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat Apr 04, 2009 8:09 pm
Someone please help me. I am getting a really annoying tink tink tink noise from the rear axle of my fulcrum racing zeroes. I have completely dissasembled the hub and greased everything but all it has achieved is to damp the noise of the pawls and make the noise more noticeable. It is not a very loud noise and occurs both when I am pedalling or freecaosting. It only occurs under load....i.e if I get off the bike and spin the wheel there is no noise. It sounds kinda "spokey" in origin if that makes sense.
 Post subject:
PostPosted: Sat Apr 04, 2009 8:58 pm
I had the same problem but with a set of racing 1's.
Happened on the first 100 mile ride I did on them.
Traced it down to the spokes creaking in the hub. Only happened on mine when I was climbing/hard efforts on the flat
Sprayed some lube in the joint and havent heard the noise since.
PostPosted: Wed Mar 13, 2013 2:10 am
I know this is an old post, but "spokey" sound is exactly what i've been trying to fix with my Zeros. Cant wait to try some lube around where the spokes meet the hub body.
Thanks for the tip!
PostPosted: Wed Mar 13, 2013 3:31 am
That's the fix, but be prepared for it to return again, again, and again. I ditched those wheels bc of that issue. Great wheels, but they need to have a fix for that problem bc its a royal pita to remove the cassette everytime it starts making noise.
Its the last thing I wanted to hear while grinding it out in a climb.
PostPosted: Thu Mar 14, 2013 1:57 am
I had the same problem with my Zeros, and it drove me crazy. Solution was Mobil 1 10w30 on both ends of the spokes. It has been 6 months and not one tick since.
Users browsing this forum: atakaoka, DaleRider, Exabot [Bot], Google [Bot], Google Adsense [Bot], kgt, LionelB, Majestic-12 [Bot], Mockenrue, TiG, weeracerweenie and 56 guests
There are no new unread posts for this topic. Fulcrum Racing 1 freewheel body on Fulcrum Zeros
digitalnorbs
Sat May 04, 2013 1:19 am
digitalnorbs View the latest post
There are no new unread posts for this topic. SL4 NOISE HEADSET-BB ???
vagbouk
Wed Apr 03, 2013 11:04 pm
Marwin3000 View the latest post
There are no new unread posts for this topic. Noise on the front wheel - HELP!!
cezinho
13
704
Fri Jul 27, 2012 7:49 pm
cezinho View the latest post
There are no new unread posts for this topic. Flite Gel Flow noise
MaxDaddy
Mon Dec 31, 2012 4:31 pm
Zigmeister View the latest post
This topic is locked, you cannot edit posts or make further replies. Super Record Noise
brt570
Mon Sep 10, 2012 10:20 pm
bikerjulio View the latest post
It is currently Wed May 22, 2013 11:11 am
