Post new topic Reply to topic  [ 972 posts ]
Go to page Previous  1 ... 51, 52, 53, 54, 55, 56, 57 ... 65  Next
PostPosted: Fri Nov 23, 2012 10:01 pm
You know the release date of Rotor Power Meter?
Alhoa
PostPosted: Sat Nov 24, 2012 10:12 am
^ I think I remember reading somewhere that the Rotor powermeter release date was for December/January.
Canyon Ultimate SLX 2013 + DA9070 + Red Quarq + Corima Aero+ MCC (Ordered! 6.0kg)
Canyon AeroRoad + DA9000 + Lightning Power2Max + MCU's (6.5kg)
Cervelo P4 + G3 Powertap (7.78kg)
Cervelo SLC + SRAM Red 2013 + Red Quarq (6.8kg)
PostPosted: Sat Nov 24, 2012 1:45 pm
. . . about to put money down on a power meter, but which one to get? SRM vs Quarq vs Power2Max . . . I know SRM is suppose to be the gold standard but what about the others . . . looking at a crank based meter . . .
 Post subject: New powermeter rumours
PostPosted: Sat Nov 24, 2012 5:18 pm
I have 3 Power2max and all works great.
See My Bike & Tillquist's Kitchen !
A Power2max user..
PostPosted: Sat Nov 24, 2012 5:44 pm
I'm sure they are all reliable, but why does SRM still sell for much more than others, I'm pretty much decided on the SRM and budget is not an issue but should I consider something else?
PostPosted: Sat Nov 24, 2012 5:48 pm
is there a comparison for the power meters currently available?
PostPosted: Sat Nov 24, 2012 6:14 pm
I have both a Power2max on a 3D+ and a Hollowgram SRM. The Power2max has really impressed me in the short time I have had it and the only negative I can find is the weight. SRM is a great product but having to send it back once a year is kind of a problem if it is your only meter. The Quarq is now on par with SRM and has a couple more features, while still being a little less money. If I was looking for a new meter to work with my C'dale cranks then I would go Quarq; however, if I was looking to replace the whole crankset I wouldn't bother with neither SRM nor Quarq. The Power2max is a great unit, the price is very competitive, and it has the same feature set of the Quarq. It really is hard to beat and I can see why Tillquist has three.
PostPosted: Sat Nov 24, 2012 6:20 pm
I've a SL4 with the Specialized cranks so I'm looking at buying just the power meter unit itself, also probable gonna use it with an edge500 so that narrows my choices down to a SRM or Quarq unless Power2max makes one for the Specialized crank. Also does anyone know how many strain gauges doe sthe above 3 have? 8, 4?
PostPosted: Sat Nov 24, 2012 7:16 pm
SRM has 8, Quarq has 10, and Power2max has 4. Like I said, faced with adding just a meter to my Hollowgram, or in your case the S-works, I would go Quarq. No reason to pay more for the SRM. The Quarq has a user replaceable battery, which is huge in my book. It also is accurate to 1.5% versus 2% for the SRM, not really sure that matters. Lastly, it has powerbalance, which is a useless metric but nevertheless an interesting one to look at. Weight wise they are close to even, swap rings on either with no issues, and both look good. Again, I'd spend my money on the Quarq.
PostPosted: Sat Nov 24, 2012 7:19 pm
The market is conservative and takes time to change. Also power2max user and very happy
Sent from my HTC One X using Tapatalk 2
power2max
PostPosted: Sat Nov 24, 2012 10:31 pm
I have a power2max, a G3 powertap and two quarq's. My favourite has to be the new sram red quarq. It definitely is worth the extra cash over the S975. Love the design!
But have to say the power2max for the price and weight (i have the lightning version) has performed flawlessly. Ive thrown everything at it, rain, snow, hail, salt, crashes and works a gem. A lot of people have complained about temperature drift but the new ones have had this corrected. I have an old one which I still find works great as long as I calibrate it outside.
PostPosted: Sun Nov 25, 2012 3:22 am
@virenque, don't get too caught-up about the number of strain gauges, etc. The number of strain gauges required for the design is also related to the stability of the component parts utilized by the manufacturer that are not controlled by them and the interface of those parts with the PowerMeter chassis. As long as the PowerMeter you choose delivers the accuracy and reliability you are looking for, you are good-to-go.
PostPosted: Sun Nov 25, 2012 5:25 pm
Like I said, I've the SL4 with the Specialized crankset, so my choices are down to the Quarq or SRM unless Power2max makes one that is compatible with the crankset
PostPosted: Sun Nov 25, 2012 6:15 pm
Is the Garmin ever going to be released?
PostPosted: Sun Nov 25, 2012 6:42 pm
Marts 2013
A Power2max user..
Post new topic Reply to topic  [ 972 posts ]  Go to page Previous  1 ... 51, 52, 53, 54, 55, 56, 57 ... 65  Next
Users browsing this forum: Google [Bot], Google Adsense [Bot], Monkeyboy3333, VMac and 64 guests
There are no new unread posts for this topic. 80th anni Ltd Edition Campag Groupset Rumours
BikeTart
39
3208
Tue Mar 19, 2013 9:26 pm
gitsome View the latest post
There are no new unread posts for this topic. Attachment(s) Lightest BB30 powermeter
jainsworth123
Sat Apr 20, 2013 5:23 pm
JackDaniels View the latest post
There are no new unread posts for this topic. Attachment(s) S-works vs Lightning crank for powermeter use.
Kasparz
Fri Aug 10, 2012 1:48 am
There are no new unread posts for this topic. Availability of SRAM Red 2012 Powermeter in Europe?
Roark
Fri Jun 08, 2012 10:44 am
Roark View the latest post
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
It is currently Sun May 19, 2013 10:23 pm
