Post new topic Reply to topic  [ 1008 posts ]
Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56 ... 68  Next
PostPosted: Thu Oct 18, 2012 2:37 pm
djconnel wrote:
Right: repeatability. If I pedal 250 watts downhill, then 250 watts uphill, 250 watts in the big ring, then 250 watts in the little ring, will I really be pedaling the same power in each case?
Call me a sceptic.
Sorry, but I am not following. If the PM is calibrated, then why wouldn't 250w = 250w? That is like saying going 50mph uphill isn't the same as going 50mph on the freeway, unless I am missing something?
thprice wrote:
Another vaporware. Too bad the price point is $1500. I just wish someone would undercut the other makers and bring something that the masses would buy. Under $1000. Yes I know $1500 is cheaper than an SRM or Quarq.
"Sacred to the god Aesculapius"
PostPosted: Thu Oct 18, 2012 2:45 pm
tranzformer wrote:
Call me a sceptic.
It's starting to happen. The P2M FSA Gossamer version is €840, which should --just-- get you in around $1000.
power2max
PostPosted: Thu Oct 18, 2012 4:48 pm
tranzformer wrote:
Call me a sceptic.
"Sorry, but I am not following. If the PM is calibrated, then why wouldn't 250w = 250w? That is like saying going 50mph uphill isn't the same as going 50mph on the freeway, unless I am missing something?"
Different PM measure in different ways. So if by 250 watts you mean that your legs are generating that much, a Quark will give different readings than a PT and the PT readings will vary with gear choice, while the Quark readings will change if you go with Osy or Rotor rings.
Plus power isn't the be all end all. For trianing I suspect riding @ 250 wats uphill and riding at 250 watts downhill, give slightly different training effects.
PostPosted: Thu Oct 18, 2012 4:49 pm
djconnel wrote:
Zigmeister wrote:
With that said, my Quarq Sram S975 unit works just fine for the $1000 I paid for it slightly used. I shipped it to Quarq, for free, the calibrated it for my QRings....just cost me shipping, turnaround 3 days.
"Calibrating for Q-rings" is just an estimate. Since they measure cadence only once per pedal stroke, they need to make an assumption about the correlation of chain speed with power through that pedal stroke, which is just an assumption which might apply differently on a flat road to a climb. It's a fundamental limiting of the Quarq/SRAM hardware.
It's easy to see the average of power = tension times chain speed is not the average of tension times the average of chain speed: 1. apply tension with the chain stationary, 2. spin the chain with zero tension. In each of these phases power is zero, yet the Quarq's approach of power = average tension times average chain speed would fail.
I don't follow you. They use the weight hanging technique on the DS arm with the rings installed. How this translates to the numbers not being accurate, I'm not sure since they are likely doing it at the same point/crank arm angles as round chains. Hence, the variable is going to be within the +-2% I would imagine, the same as any other PM.
PostPosted: Fri Oct 19, 2012 12:14 am
"Thus far, your options are Garmin’s Vector pedal built around the Look Keo and won’t be available until next year at the earliest (side note: this summer, they embarked on a complete redesign internally to improve durability and aren’t stating any potential dates. The next time you hear something from them, it’ll go on sale that same day) "
From that Bikerumour article...
____________________________________________________________________________
Firefly FF050
Felt B2Pro
Trek Fuel EX9
PostPosted: Fri Oct 19, 2012 12:22 am
Power doesn't just depend on avg force and avg pedal speed during a pedal stroke: it also depends on how these vary relative to each other. Quarq makes a certain assumption about how they vary. That assumption needs to be different for round rings versus eccentric rings. But the assumptions won't apply equally well to all pedaling styles. If you're slogging through the mud or up a steep hill or into a block headwind, the variations will be different then if you're hammering a descent. In other words, if you produce exactly 250 watts, it may report more in some cases, less in others.
Powertap doesn't have this problem: it doesn't care about the details of your pedal stroke. Powertap has other issues, but ring shape shouldn't affect its accuracy at all. Neither would it affect the Garmin Vector.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Fri Oct 19, 2012 4:02 am
I guess that I am assuming you are using the PowerMeter for training, not JRA. If that is the case I also assume that you are trying to induce a training response by loading your body repeatedly on a known course or a trainer (i.e., intervals). To me, that implies that the training interval is on a climb, with the recovery on the descent.
I agree that if you have multiple PowerMeters, the accuracy matters, which is why I recalibrate.
PostPosted: Fri Nov 02, 2012 2:00 pm
Finally an update from Garmin regarding the Vector. All credit to DC Rainmaker for listening to the earnings call and getting the information presented below:
Quote:
Instead the update came during the investor/media Q&A period where it was asked what the timeline status looks like on Vector.
The quoted answer from Cliff Pemble, President and Chief Operating Officer of Garmin:
"We are making progress on Vector and we've been evaluating new design changes and we do feel like things are looking promising and are sticking to our early next year first quarter (Q1CY13) or early second quarter (Q2CY13) deliveries.”
This roughly aligns with what I’ve been hearing in other circles, though this is the first time we’ve heard 2nd quarter mentioned publically. I suspect we’ll likely see more public information following Christmas going into CES2013 (first week of January) – which is a popular time for consumer electronic companies to make announcements concerning the upcoming few months.
PostPosted: Fri Nov 02, 2012 2:21 pm
That sounds as firm as jello.
PostPosted: Fri Nov 02, 2012 3:56 pm
Well their "assumptions" are very accurate. Friend of mine has a powertap, he has used both round rings, and biopace. We have done the same race/group training rides. Then I send my Garmin file to him.
He takes them, just like I do in WKO training peaks software, overlays the files to compare. They are basically identical the entire time, the only difference is he weighs 20-25lbs heavier than me, and his power output will show about 10% higher on average due to his fat butt being hauled around. Otherwise, the curves, peaks, lows etc...all are identical. It is easy to correlate and see the route and how we are riding within 50ft of each other the entire time.
The proof is in the pudding as they say. So Quarq is doing the calculations very similar to a powertap no matter what rings on the crank once calibrated properly.
 Post subject: New powermeter rumours
PostPosted: Fri Nov 02, 2012 6:42 pm
I feel like round vs oval rings will result in power differences "at the wheel". Rather than "at the crank". I don't think strain gauge deflection on the crank arm really cares what shape or size your chain rings are. Having said that, the number reported might not change, but as others have said the calibration and assumptions made by the power meter may no longer be valid. So for training purposes, switching back and forth between different chainrings may not give comparable results but at least they'll be consistent compared by itself.
PostPosted: Fri Nov 02, 2012 8:37 pm
right: the avg torque should be correct. The avg cadence should be correct. The average of torque times cadence will not be correct.
But as has been stated, the "proof is in the pudding" and people have been happily using SRMs for 20 years.
Always good to hear Vector info... I miss the old Metrigear Blog days. Those were a lot of fun.
Fuji SL/1
PostPosted: Fri Nov 02, 2012 9:08 pm
Have you run into Clark Foy out on the road recently viewtopic.php?f=3&t=95419&p=812984#p812740 ?
And remember boys and girls, we anticipate availability of Vector within half a year. ... Oh wait, haven't we heard that before? Why yes we have, 3 years ago, LOL viewtopic.php?f=3&t=62804#p564777 .
PostPosted: Fri Nov 02, 2012 10:45 pm
Errr... Maybe.
But if I roll dice and say "I'll probably get doubles in the next six throws", then 12 throws later no doubles, I'd still say "I'll probably get doubles in the next six throws" and eventually I will. Unless the dice are loaded. But it takes a lot more than 12 throws to draw that conclusion.
Fuji SL/1
PostPosted: Sat Nov 03, 2012 1:37 am
In this case each throw of the dice is 6 months? :lol:
Post new topic Reply to topic  [ 1008 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56 ... 68  Next
Users browsing this forum: bikewithnoname, DamoRider, DMF, Google Adsense [Bot], mnmasotto, Tom-s, Tristan and 74 guests
There are no new unread posts for this topic. 80th anni Ltd Edition Campag Groupset Rumours
BikeTart
39
3272
Tue Mar 19, 2013 9:26 pm
gitsome View the latest post
There are no new unread posts for this topic. Attachment(s) Lightest BB30 powermeter
jainsworth123
Sat Apr 20, 2013 5:23 pm
JackDaniels View the latest post
There are no new unread posts for this topic. Attachment(s) S-works vs Lightning crank for powermeter use.
Kasparz
Fri Aug 10, 2012 1:48 am
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
It is currently Thu Jun 20, 2013 1:14 pm
