Post new topic Reply to topic  [ 34 posts ]
Go to page 1, 2, 3  Next
PostPosted: Mon Feb 23, 2009 4:31 am
I'm considering wheels for a Prince with S/R and have been advised NOT to get the new 2-way fit versions. I'm told tire fitment is very difficult (presumably they have a slightly larger OD).
Can anyone comment on this and if they have found it a problem?
I do not currently use tubeless and until more tire manufactures get on board and provide more options, I'll probably stick with the tubes. Nevertheless, I'm reluctant to forgo the ability to run tubeless tires in the future.
 Post subject:
PostPosted: Mon Feb 23, 2009 5:13 am
do they do 09 with out "2 way fit"?
 Post subject:
PostPosted: Mon Feb 23, 2009 6:37 am
yep, can get them without 2-way fit. Generally cheaper, too
 Post subject:
PostPosted: Tue Feb 24, 2009 1:23 am
and the standards are lighter as well.
 Post subject:
PostPosted: Tue Feb 24, 2009 5:12 am
per Campy specs, the "Standard" and "2 Way" wheelsets are identical weight.
PostPosted: Tue Feb 24, 2009 5:14 am
milroy wrote:
.... I'm told tire fitment is very difficult (presumably they have a slightly larger OD).....
Are you referring to clinchers being harder to remove & install ? That's my concern, although I've not been able to ascertain facts.
By design, tubeless are supposed to be very tight on the rim
 Post subject:
PostPosted: Tue Feb 24, 2009 5:54 am
I can't speak specifically to the Campy 2 Way Fit wheels, but with the '09 Fulcrum 2 Way Fit wheels there is a specific tire lever that it is recommended you use. I just installed some of the Hutchinson Fusion tubeless tires on a set of Fulcrum Racing 0 2 Way Fit wheels and they went on alright. On one of them I did need to use the tire lever to get that list little bit on the rim but the other tire went on fine. Not as tight even as some traditional clincher tires.
Having put in some miles on the tubeless tires, I think that they are phenomenal and I would say you should check them out. You can ride much lower air pressure, get a smoother ride and generally have less flats. As far as weight is concerned, I could perceive a slight weight penalty on the Racing 0 2 Way Fit versus the regular Racing 0s, but I didn't put them on a scale so I can't help you there.
 Post subject:
PostPosted: Tue Feb 24, 2009 9:57 pm
Thanks. I'll try to weigh both types and see if I come up with any difference. From what I have read here, it seems Shamals are usually over the claimed weight, anywhere from 1420g to 1450g. It would be interesting for me to know if that is related to the 2-way fit vs regular.
 Post subject:
PostPosted: Wed Feb 25, 2009 9:23 pm
I've got 2009 'two-way-fit' Shamals with Hutchinson tubeless tyres. They offer a loveley ride with, so for, no punctures. Total weight is about the same as clinchers + tubes. The tyres go on easily as well. I've not tried the wheels with tubed tyres yet though so can't answer your question.
Regards
 Post subject:
PostPosted: Thu Feb 26, 2009 2:19 am
I just got my Shamal Ultra 2 way fit wheels from TotalCycling...
They are GORGEOUS!! I weighed them....
front (with valve stem) 625g
rear (with valve stem) 832g
skewers 114g
They also look awesome on my 07 595 Ultra. I just put the wheels on the bare frame to check it out....WOW!!
I hope to post pics once it's all built up.
 Post subject:
PostPosted: Thu Feb 26, 2009 2:49 am
I set a pair up for a friend and they were no more difficult than most campy wheels- if tubeless is something you are interested in you should give them a shot.
This board would be MUCH nicer if everybody would just chill out.
 Post subject: 2-way-fit
PostPosted: Thu Feb 26, 2009 9:34 am
Anybody else had 'pinch-punctures' running tubulars on these rims?
I saw a flat the other day on a Vittoria Pave and it was almost definately from checking on the rim bead.
I wouldn't touch them.
www.wheelsmith.co.uk
 Post subject: Re: 2-way-fit
PostPosted: Fri Feb 27, 2009 1:55 am
Either you have misread this thread or are confused (or trying to be funny). I've heard of ppl running tubular tires on a clincher wheelset, but its hardly within the design scope and a fault of the wheel.
 Post subject:
PostPosted: Fri Feb 27, 2009 3:41 am
^^^ Yeah, I think you are confusing tubular and tubeless. I believe there were some old skool wheels that accepted tubulars and clinchers but certainly not what everyone is talking about here.
Back OT: I haven't tried Campag rims/wheels for a while but all my older ones (old shamals, lambda rims) are a bastard to get tyres on and off. Trying to fit a Michelin tyre is a waste of time and if it does get on there you'll never get it off.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
 Post subject: 2 way fit
PostPosted: Fri Feb 27, 2009 9:36 am
Sorry, it was a bit tongue in cheek but this is the second time I have had someone talking about their tubular tyres not doing so well on these rims.
It beggars belief. Like the woman who electrocuted her son with an electric guitar on Xmas day by putting a 13A plug on the 'power cable'.
:shock:
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot], jooo, Mario Jr., MSN [Bot] and 37 guests
There are no new unread posts for this topic. Shamal goes 'pop'
Lig
22
1741
Fri Nov 16, 2012 6:17 pm
Bigger Gear View the latest post
There are no new unread posts for this topic. Campy Shamal Ultra rear hub
gn1tmac
Wed May 01, 2013 2:13 am
gn1tmac View the latest post
There are no new unread posts for this topic. Caad 10 - Regular 1 1/8 Fork ?
Megaclocker
Sat Feb 02, 2013 12:42 am
Maximilian View the latest post
There are no new unread posts for this topic. Campag eps
markyboy
Mon Nov 26, 2012 9:25 pm
apLe View the latest post
This topic is locked, you cannot edit posts or make further replies. Campag ATHENA EPS
Permon
Tue Jul 31, 2012 11:06 am
Tinea Pedis View the latest post
It is currently Wed Jun 19, 2013 11:18 am
