It is currently Tue Jan 16, 2018 11:12 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Mon Feb 21, 2005 5:11 am
OK folks... any opinions with this crankset in combination with Campy drivetrain.
 Post subject:
PostPosted: Mon Feb 21, 2005 5:18 am
Very nice, but unless you get the K force mega exo your crankset will be very heavy.
I have no first hand experiance with it, but it is very stiff, not quite DA stiff from what I heard, and almost identical weight. 756g for a 172.5mm
 Post subject:
 Post subject:
PostPosted: Mon Feb 21, 2005 5:26 am
this one...
http://www.fullspeedahead.com/fly.aspx? ... 21&pid=153
before ditching the limited frame... we tried the compact version of this in the frame, and I was able to get my heels to clear.
If I still end up with rear end problems, then ugly yellow stickers here I come.
 Post subject:
PostPosted: Mon Feb 21, 2005 5:29 am
Yeah, that's the crankset.
 Post subject:
PostPosted: Mon Feb 21, 2005 4:31 pm
If these fit your scott like they are supposed to, then I would say there is something wrong with your record setup :?:
 Post subject:
PostPosted: Mon Feb 21, 2005 6:26 pm
I'm debating this or the Truvativ/Bontrager's. (The same.)
Cost is less for the Truv/Bont., but chainring quality probably suffers.
Anyone seen either...??? Reccomendation... or should I just save for the DA's??
 Post subject:
PostPosted: Tue Feb 22, 2005 5:49 am
We shall see... I have them on order and will have them next week. I also have a 56cm 585 waiting in the wings just in case as well.
I'm on vaca out in Breckenridge... so I'll be carving all week, and then building my superlight next week.
Hopefully it will be Door #1 CR1 Limited I'm sitting on (and if it works, I will eat all previous whining)
Door #2 Look 585
Door #3 CR1 Team with the awful yellow decals.
 Post subject:
There are no new unread posts for this topic. Campagnolo 53 and 36 chainring combo ?
nismosr
Sat Nov 04, 2017 2:53 am
Squashednuts View the latest post
There are no new unread posts for this topic. Lightest 38cm stem/bar combo
jpshorts
Mon Jan 15, 2018 10:37 pm
jpshorts View the latest post
There are no new unread posts for this topic. Bar-Stem combo: alloy or carbon?
MiddMan
22
2636
Mon Oct 02, 2017 7:32 pm
nemeseri View the latest post
There are no new unread posts for this topic. Crank Bearing Puller for SRM Campagnolo Crank
mrgray
14
1281
Tue Apr 04, 2017 9:37 am
mrgray View the latest post
There are no new unread posts for this topic. Lightest aero base bar + stem combo? (separate or integrated)
alcatraz
Fri Aug 18, 2017 10:52 am
Juanmoretime View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], Digger90, Google Adsense [Bot], L3X and 40 guests
cron
