Syntace F99 doubt
toko
by toko
My stem arrived without instalation instructions,which the utility of the two rubbers that are inside of bar clamp, must remove when it will be to install the handlebar :?:
erty65
by erty65
toko wrote:My stem arrived without instalation instructions,which the utility of the two rubbers that are inside of bar clamp, must remove when it will be to install the handlebar :?:
none of them.
Pedä
by Pedä
it is very simple: you do not need them, but you should use them. they stop water, so that it could not go into the stem
Pedä
marko
by marko
They grip the bar from slipping as well. I'd keep them in.
toko
by toko
Thank u for help guys! :)
