It is currently Fri Mar 31, 2017 2:05 am
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3 Next
 Post subject:
PostPosted: Thu Feb 05, 2009 6:32 am
WideAMG wrote:
campagnolo CULT bearing upgrade kit available here for $450 USD
http://www.cbike.com/index.asp?PageActi ... rodID=3079
The same thing is available here for US$224 but the price is for 1 kit.
http://smartbikeparts.com/search_details.php?itm=HU9885
 Post subject:
PostPosted: Thu Apr 23, 2009 5:21 pm
Did anyone to the upgrade?
 Post subject:
 Post subject:
PostPosted: Thu Apr 23, 2009 11:38 pm
Not CULT but I swapped the stock bearing in my Shamal Ultras for the Campagnolo Ceramics... and in all honesty.. noticed S-F-A...
 Post subject:
PostPosted: Wed Apr 29, 2009 8:50 am
fdegrove wrote:
mtbnoob wrote:
Hi,
As said before, the only part of the upgrade that seems impossible (to me at least) to carry out yourself is to replace the cups from the Bora Ultra hubs with the Cronitect ones.
Interesting tolls to replace the the cups at 1.16 in the video
http://www.youtube.com/watch?v=eu9TnP_tgEw
 Post subject:
PostPosted: Thu Apr 30, 2009 1:33 pm
And here is the tools
http://shop.ra-co.de/default.asp?Shop=1
http://shop.ra-co.de/htm/functionwait.a ... ar1=720112
 Post subject:
PostPosted: Thu Apr 30, 2009 2:17 pm
fdegrove wrote:
In all honnesty I don't think that particular upgrade alone made me ride faster.
Reducing friction in all the other bearings as well (BB, pulley wheels and freehub) makes the difference much more noticeable.
I have read somwhere that half of all improvement in drivetrain friction can be had in the pulleys.
/Håkan
SWEDEN
 Post subject:
PostPosted: Thu Apr 30, 2009 2:52 pm
/Håkan
SWEDEN
You're right. Half of zero is zero. :twinkle:
 Post subject:
PostPosted: Thu Apr 30, 2009 5:47 pm
look this post
http://www.stevan11.com/
soloist carbon
 Post subject:
PostPosted: Thu May 07, 2009 6:07 pm
I decide to upgrade my Fulcrum rear wheel to CULT level and purchase 8 pcs upgrade cit from http://aebike.com/page.cfm?PageID=30&ac ... sku=HU9885
I will make the extractor and press tools by myself and believe that I will be abble to replace the stock cups with the new cronitect cups.
I ask a Fulcrum what kind of oil i must used for best results and here is the answer:
"with Cult bearings technology we suggest to use only a high quality, 100% synthetic, lithium based OIL with high rust protection qualities"
I try to surch in Google but can't find information for lithium oil, but only for lithium based grease, so i need your advise and help from where i can find this type of oil. Any suggestions are wellcome.
Thank you in advance.
 Post subject:
PostPosted: Thu May 07, 2009 7:01 pm
Tubbie Guru
Hi,
No such thing as lithium based oil.
The description of the type of oil to use isn't really helping either.
I'd recommend Dyupont de Nemours Krytox 200 grease for ceramic hybrid bearings. It's as slick as oil with extremely low friction.
BTW, what model of Fulcrum wheels are you going to upgrade.
I know of a shop that sells all the necessary tools if you're interested.
Ciao, :wink:
 Post subject:
PostPosted: Thu May 07, 2009 7:26 pm
Thanks for the reply.
The wheels are F Racing Speed model.
About the tools - yes I'm interesting in case if I failed with my home made tools.
About the lubricant - what you think about this http://www.finishlineusa.com/products/e ... grease.htm - it is easyer to find and they promise it is pure Dupont product.
And again - how useless is Campy/Fulcrum support - shame for the italians :shock:
 Post subject:
PostPosted: Fri May 08, 2009 12:31 am
Tubbie Guru
Hi,
Since the inception of the Bora wheels with carbon fibre hubs Campa hasn't listed any spare part number for the cups used in these hubs.
Although I'm sure these can be replaced, I'm very uncertain about how these can be safely replaced with the same tools and techniques used for the aluminium alloy hubs.
Keeping this uncertainty in mind I can assure you that moving from plain vanilla Racing Speed/Bora to USB or CULT level will only pay off if you change the lubrication of the bearings from the usual Galli Lithium based grease to a Krytox base lubricant.
This type of lubricant will yield more benefit than any oil based lubicrant in this kind of set up IMHO as oil will just leave the bearings past the seals leaving the bearings in a dry state sooner or later.
Ciao, :wink:
PostPosted: Mon Feb 20, 2012 2:47 pm
Hi!
Who could replace cups from carbon bora hub?
My old bora ultra cups is wear and need to replace.
PostPosted: Mon Feb 20, 2012 7:07 pm
Tubbie Guru
Hi,
The only places that can have that done for you are the certified Campagnolo Techcenters.
Not sure about Estonia...
Either way, it's very unlikely for the cups to be shot. The cones, yes but the cups?
Do not attempt to remove the cups yourself as you may very well end up with broken hubs...
Ciao, ;)
PostPosted: Wed Feb 22, 2012 5:40 pm
Thanks a lot.
But I'm from Russia, not Estonia :D
There are no new unread posts for this topic. Campagnolo Neutron Ultra and Bora one 35
BiaNeutron
Fri Dec 16, 2016 12:30 pm
BiaNeutron View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo Bora ultra two pre 2015 decals, dry or soap and water fit ?
ViggenNut
11
507
Thu Mar 23, 2017 2:39 am
mvacolnago View the latest post
There are no new unread posts for this topic. Bora 35mm One brand new - or - Bora 35mm Ultra used
ronderman
23
3163
Sat Nov 05, 2016 4:51 am
karng View the latest post
There are no new unread posts for this topic. 2017 bora one and ultra wheels?
karng
Wed Nov 02, 2016 4:42 am
Shonn View the latest post
There are no new unread posts for this topic. Need Help Please Campag Bora ultra two Dark Label
Snugship0
13
589
Tue Feb 07, 2017 10:34 am
graeme_f_k View the latest post
Users browsing this forum: Baidu [Spider], bipedzed, ferrarista, kookie, sethjs and 16 guests
