anyone have a sloping C50HP-HM?
I like this frame, Colnago has finally started to get the weight down on the c50. The only noticeable change is that the headtube is a little taller than it was on the c40's. Ride quality is great. And durability has never been an issue with Colnago carbon frames.
Madcow is right - the headtube is 7mm taller than a 40 - and Colnago CF frames are built to last. I can't believe how much crap my C40 has been through and it still looks beautiful.
Can you not get your position right on a 585?
rico
rico
Hi bud -
The fit is very close. Same stem length (120mm) on a 53.5cm TT (the Nags) and a 53cm (585). Near enough perfect seatpost length on both.
Post build there are a couple of spacers on the 585 I will happily have taken off (I like to be as low at the front as poss) but otherwise it's perfect. Beautiful ride on it today - and probably first race tomorrow.
Very impressed with the Arione on the 585 too.
rico
rico
