It is currently Fri Jan 20, 2017 11:14 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
 Post subject:
PostPosted: Fri Feb 18, 2005 7:39 pm
They make spacers to address your problem, 1 or 2 will fix your problem. Quality bike parts dealers can order them in a couple of very thin sizes. you'd need the 68X 108 or whatever is the next size, but that would set the crank out there.
 Post subject:
PostPosted: Fri Feb 18, 2005 7:48 pm
whats the spacer for?
68 is the distance the bearings are apart
108 is the axle length....
the only place a spacer will go is behind the drive side BB cup..... as its the non drive side thats too close then that IMHO will only make it worse :shock:
 Post subject:
 Post subject:
PostPosted: Fri Feb 18, 2005 7:51 pm
PNuT wrote:
68mm & 70mm are the distances between the bearings..... sweet FA to do with threads other than english bottom brackets have 68mm axles & ittalian ones have 70mm??
there is so much duff advice on this site its unbelievable :shock:
Some duff observations :lol:
English bb 1.37 x 24 tpi (1.37 inches = 34.8mm)
Italian bb 36 x 24 tpi (36mm diameter = 1.42 inches)
Which is why English BB cups barely touch the sides of an Italian BB shell.
So to resolve the frame problem fit a couple of different Chainset/BB combinations. If the result is similar - uneven gap on all - then the frame is probably at fault.
 Post subject:
PostPosted: Fri Feb 18, 2005 8:26 pm
the above (in bold) are the thread sizes.... obviously one wont fit the other :roll:
 Post subject:
PostPosted: Fri Feb 18, 2005 9:31 pm
Sounds like he just needs to set his frame on fire. If he can't ride it no one can! :twisted:
There are no new unread posts for this topic. Ultegra DI 2 Dead
FOILOSI
13
1167
Mon Mar 14, 2016 11:41 pm
glepore View the latest post
There are no new unread posts for this topic. Campy SR DP brakes vs campy skeleton DP
JDEves
Tue Oct 11, 2016 8:39 pm
JDEves View the latest post
There are no new unread posts for this topic. LOOK 695 upgrade to campy EPS
slick1
Sun May 15, 2016 4:37 pm
SuperflyRick View the latest post
There are no new unread posts for this topic. Campy UT cups
tadrums
19
1373
Sat Dec 03, 2016 12:12 am
Calnago View the latest post
There are no new unread posts for this topic. New Campy 10s ... These days?
Kupepe
11
978
Wed Jan 04, 2017 7:39 am
Kupepe View the latest post
Users browsing this forum: Bing [Bot], chris47, Delorre, Google [Bot], Google Adsense [Bot], PhilippCX, poppiholla, zirxo and 11 guests
