Post new topic Reply to topic  [ 15 posts ]
PostPosted: Fri Jan 23, 2009 10:30 pm
I wanna get some opinions for my new project!I wanna get a light chain for my campy!I got kmc in my mind.Gimme more options!
 Post subject:
PostPosted: Fri Jan 23, 2009 11:44 pm
all things considered, I'd go with the X10SL.
11' Flash Ultimate, 1x10 - 15.7
11' SuperX Single Speed - 13.0
12' SuperX Geared - 15.3
12' Scalpel Ultimate, Wireless SRM - 18.3
 Post subject:
PostPosted: Fri Jan 23, 2009 11:58 pm
Ugh. I hate KMC chains. They come covered with this horrible goo that's difficult to get off, and if left on will goop up your drive-train. I just spent half an hour removing chainrings and scrubbing them with a soft scouring pad in various mixtures of paint thinner, alcohol, baby-oil, and dishwashing soap... finally got the KMC sludge off them... the washing loosened it enough that hard rubbing with a rag took it off...
Three, two, one / I like to stun. Hey kids, why not try rapping your posts like a big-time MC?
 Post subject:
PostPosted: Sat Jan 24, 2009 12:22 am
@Starter--i just dip my new KMC Chains in gasoline and the "goop" comes off right away after stirring for 30seconds. That's it--i have had durability probs doing it this way since i used Regina 6 speed chains in the 80's
 Post subject:
PostPosted: Sat Jan 24, 2009 12:27 am
So why not stop then? :?
10 SuperSix Hi-Mod
07 System 6.
06 Caad 8
90s Merlin Extralight.
 Post subject:
PostPosted: Sat Jan 24, 2009 12:34 am
Tubbie Guru
Hi,
Always remove the wax from a new chain before putting it on a bike than lube it and let it sink in overnight.
The wax is meant as to prevent the chain from rusting during transport or stockage.
I use gasoline or petrol as well and it works just fine while not stripping the metal blank.
Ciao, :wink:
 Post subject:
PostPosted: Sat Jan 24, 2009 1:04 am
Nearly every brand has a sticky grease preservative on it. KMC is no worse than most and it's no reason to avoid buying it. The new Campy 11 speed chain has as much goo on it as any.
Mineral spirits will remove the goo in a minute or two. I use an old water bottle about 2/3 full of MS, drop the chain in and shake for awhile. Remove the chain and wipe dry. The MS can be reused many times for general degreasing.
After degreasing, apply your lube of choice and allow to dry.
Gasoline is not a good choice for degreasing from a safety standpoint. It's much more volatile than mineral spirits, naptha, kerosene or diesel fuel.
 Post subject:
PostPosted: Sat Jan 24, 2009 1:51 am
gas evaporates pretty quick--BUT my friend and i once soaked a chain in gas and put it on my Pinarello Treviso SLX (way back when) and lit it on fire (heat treated)--it was pretty neat riding around for a few seconds with a fire chain. there was damage to the chrome chain stay though as i remember.
 Post subject:
PostPosted: Sat Jan 24, 2009 2:54 am
I wanna firechain!
17 and stupid, bear with me
 Post subject:
PostPosted: Sat Jan 24, 2009 5:47 am
Going back to the original question..the KMC/Yaban/KCNC (they are all the same) X10SL are probably the best bet unless you have ample fund$$$ and decide to go with the Wippermann 10-speed Titanium (+$300) or the New Yaban X10Sl Titanium ($200-$250)....
www.royalbicycles.com
 Post subject:
PostPosted: Sat Jan 24, 2009 9:37 am
Shop Owner / Manufacturer
Similar. As far as I am aware KMC and Yaban are different physical factories - ie. true manufacturers. I am not aware of KCNC making or marketing any chains yet.
V.
Velocite Bikes
Cycle Taiwan
 Post subject:
PostPosted: Sat Jan 24, 2009 12:57 pm
Administrator
There is a thread over at MTBR that Yaban has a very expensive titanium chain that weighs 13 grams less than the KMCX10SL.
Here is the thread:
http://forums.mtbr.com/showthread.php?t=486189
 Post subject:
PostPosted: Sat Jan 24, 2009 2:51 pm
V.
The KCNC is a re-branded Yaban...I know as we have them on stock, both regular X10Sl and the new Titanium. Was under the impression Yaban and KMC were the same...they look identical in design.
On the Yaban Titanium SL our verified weight for a gold one in 116 links is 230 grams.
 Post subject:
PostPosted: Sat Jan 24, 2009 9:04 pm
the KMC and the Yaban light chains are different indeed--i have both and decided to run the KMC due to looks and they are a few grams lighter as well. The Yaban is more flared inward at the plates than the KMC. The Wippermann ti chain i had for a few months before i broke it during a ride (probably my fault since one of the plates pulled out of the rivit--maybe a closing issue i don't know as i sold that thing after it happened). interesting to see if the KMC ti chain will be any more durable than the Wipp ti?
 Post subject:
PostPosted: Sat Jan 24, 2009 10:54 pm
In 10speed I do prefer
1-Camapgnolo
2-KMC x10 SL
Degrease and then lube with whatever you like .....
In fact even lubrication with 20W40 motor oil works fine..... :wink:
But if you like a clean chain Prolink Chainluber from “Progold lubricants” is real nice but only apply this on a clean chain!
My bike is Italian so it is Nervosa and of course has Anorexia I like them thin!
GIOS "New" Carbon Ultra 2006 Campa Record+Special parts.
GIOS "New" A90 2008 Campa Record+Special parts. My winter and vacation bike.
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Majestic-12 [Bot], timj and 26 guests
There are no new unread posts for this topic. Any way to repair campy 11 speed chain>
reemo
9
719
Thu Dec 27, 2012 2:26 pm
Wcl4 View the latest post
There are no new unread posts for this topic. chain drop on SRAM chain catcher
PoorCyclist
Fri May 10, 2013 4:38 am
timzcat View the latest post
There are no new unread posts for this topic. Yaw shifting with KMC chain vs 1091R chain
rijndael
Fri May 10, 2013 2:49 am
DaleRider View the latest post
There are no new unread posts for this topic. lightest disc caliper
cymans
11
2043
Fri Jul 20, 2012 3:06 pm
bones View the latest post
This topic is locked, you cannot edit posts or make further replies. What is the Lightest Carbon Stem
DamoRider
Mon Dec 17, 2012 6:32 am
theremery View the latest post
It is currently Fri May 24, 2013 9:32 am
