Broken New Ultimate Seatpost....
ElDuderino
by ElDuderino
So all this talk about "true weight weenieism" and "practical weight weenieism" bring up this post...
I had my first collegiate race weekend of the year on saturday and sunday. I recently installed a new ultimate seatpost on the bike....great post. super easy to asjust. 93 grams...and best of all...it isn't carbon (won't slip, crimp, etc). It was solid in training the week prior to the race weekend. It was solid during the TT, and the TTT on saturday....then come Sunday, 50 meters from the line....the post sounded like it broke to a billion pieces. I sprint seated (like Zabel), and was in contention, until it broke. "true weight weenieism" lost out to practicality. Ah well. That's not what i'm starting a discussion about, however...
I was wondering if anyone knows where I can get a replacement bolt for this product? I should mention, that the seatpost itself did not break, one of the two Ti clamping bolts broke at the head. I weigh 164lbs, and am well inside the set weight limit of 190lbs. It's a great post, and I want to continue using it...maybe replacing the bolts with steel ones? If anyone has any info/insight, please let me know. I'll post photos of the broken bolt soon.
-Dude
that's me in green, white helmet...the photo highlights the predicament pretty well...you can see the slr floating around right behind...
Mr_Potatohead
by Mr_Potatohead
McMasterCarr will have all sorts of metric bolts in stainless maybe titanium too.
If it was a bolt breaking I'd suspect it was a fatigue failure possibly from not tightening it enough ironically. You can help get more tension in the bolt by using moly grease. That may be a problem if you have carbon rails on your saddle since you don't want to crush them.
A good titanium bolt will be just as good as a steel bolt, in some ways better because when the joint is loaded the fastener will take less of the load and the clamped surfaces will take more since titanium is about 50% as stiff as steel for a given cross sectional area.
Torque isn't a good indicator of bolt tension since friction effects produce huge variability in the bolt tension for a given amount of torque.
The best method is measuring bolt stretch.
The more you tighten a bolt the less probe to fatigue failure it will be, that is until you yield the bolt. So the trick is to bring the bolt up to about 80% of yield.
big fellow
by big fellow
gee dude that's just plain bad luck mate
that's the last thing you'd expect after paying that much for one!
give some feedback if you do change bolts, may do the same as I wight more than you!
cheers
shinkansen
by shinkansen
That's what I class as a TRUE WEIGHTWEENIE... Ditching your seat mid-sprint to save excess weight. Niiiiiiiice!
New Ultimate
by New Ultimate
Hi Elduderino
We allways wants our products to finish first - and in one peace :-)
The torgue is not critical in this bolt (allthough Mr Potatohead has a point - 2,5 - 3nm should be use as torgue)
The bolt is one of the parts that is "overdesigned" - we have done testing for a long time with 4mm bolts on cyclecross bikes - without any problems...
For all the testing we have done - with 4 and 5mm bolts - we have never had a failure ! Same bolt we use for our longer 350mm version - wich has bin tested on MTB - never had a failure...
Only reason I can see to this failure is a "error" in the titanium material used for the bolt... wich is extremely rare - and impossible to detect...
But anyway - very sorry to hear this - we will of course send you a new bolt asap - send me PM
Best regards
Jesper
New Ultimate
newbieweenie
by newbieweenie
Now thats what I call customer service. :) I see a new ultimate post in my future, simply because of that reply. How much do they run US $?
BikeTech
by BikeTech
Racing in Gainesville eh ElDuderino :)
What was your time for the ITT on Saturday?
ElDuderino
by ElDuderino
You a fellow collegiate weight-junkie racer? My ITT time was 26:50 . You do it as well?
an update on the New Ultimate post: I'm in contact with Jesper, and the customer service so far has been terrific. I will update with information as I receive it.
OLver
by OLver
big fellow wrote:that's the last thing you'd expect after paying that much for one!
... in my opinion, it's the first thing you expect from a 93g seatpost.
more expensive, lighter, weaker
Samu Ilonen
by Samu Ilonen
OLver wrote:more expensive, lighter, weaker
Not nessery on every time, every part. It needs just better design/testing/analyse and better/more expensive materials...I bet that my Stiletto fork is stronger than anything what exsample Kinesis has ever produced, least road forks...
2002SaecoReplica
by 2002SaecoReplica
ElDuderino wrote:You a fellow collegiate weight-junkie racer? My ITT time was 26:50 . You do it as well?
Faster than me by a bit. Mine was 32.26 racing collegent C's. C's crit racing is scary, I'm thinkin B's might be a safe place next race weekend. Green and white, you're a Lee's Mcray boy then correct? I'm over on the University of Georgia team.
- Zipp rims will break if you look at them too hard
- R-Sys wheels will spontaneously explode
- The ZG crankset will never, ever exist
- Everyone needs Lightweights, even if they're fat and old
- Parts actually made of metal are SO 10 years ago
ElDuderino
by ElDuderino
Cmon now....as if heavier seat posts have never broken...
and yeah, i'm a Lees-McRae student
marko
by marko
Can you get it to work without the saddle or do the old school rules ban no saddle?
carlos
by carlos
agree 100%
:exactly:
hey
ho
lets go!
Pedä
by Pedä
could you post a picture of the broken bolt? :shock:
Pedä
