Post new topic Reply to topic  [ 9 posts ]
PostPosted: Tue Oct 21, 2003 8:14 am
I've recently bought myself a Ritchey WCS bar and would like to know what are the best ways to lighten it up a bit.
I am thinking of cutting away a bit of the drops (say about 1cm).
I have also seen on a Bontrager that holes are drilled near the ends. Is this wise to do, and is there a special technique that should be used?
Any advise and engineering knowledge appreciated.
PostPosted: Tue Oct 21, 2003 11:02 am
You can cut a bit of because you don't really need the end of the bar.
 Post subject:
PostPosted: Tue Oct 21, 2003 11:55 am
The Richtey bars have very long drops (compare them to ITM the bar!), you can cut off 1.5 - 2 cm if you want!
I don't think drilling holes in de ends of the bar wil weaken it significantly, you don't excert any force on it there.
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Tue Oct 21, 2003 4:57 pm
1 cm is about 4 gr...so if yu cut away 2 cm at both ends...its aprox. 16 gr...not so bad. :D
 Post subject:
PostPosted: Tue Oct 21, 2003 5:02 pm
With shorter bars you can put more bartape on the bars. If you stretch it at the bottom you can really wrap it thick at the top where your hands are most of the time.
I don't spend much time in the drops and if I do my hands are up towards the front so I can keep a finger on the brakes.
 Post subject:
PostPosted: Tue Oct 21, 2003 5:23 pm
Messing with your handlebars is dangerous and stupid. If you want a lighter handlebar buy a lighter one. Not trying to be rude, but seriously, its VERY dangerous, just looking out for my peeps! 8)
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Tue Oct 21, 2003 6:00 pm
But it's not dangerous to cut off a bit :roll:
 Post subject:
PostPosted: Wed Oct 22, 2003 8:23 am
Thanks for your concern Supalite.
I won't modify the bars at crucial stress points. I just think that the ends of the bars are fairly safe to tamper with.
I see the drillings on the Bontrager bars are in a X shape across the diameter (O). I think if it's in a + shape it might be more likely to bend downwards if you put a lot of presure on it. But the drillings would be quite close to the edge, so the chances of bending it should be minimal. Drillings would be from ring finger to your pinkie, if you place your hands on the ends of the bar.
 Post subject:
PostPosted: Wed Oct 22, 2003 12:49 pm
Go for it man. You have nothing to loose but weight!
Users browsing this forum: CSKeller, Google Adsense [Bot], jeffbong, jepd1973, kulcha and 47 guests
There are no new unread posts for this topic. Attachment(s) Seatpost suitable for quill modification?
strandsatt
Mon Nov 26, 2012 7:16 am
peruffo View the latest post
There are no new unread posts for this topic. Handlebar compact
physeter
Sat Sep 01, 2012 4:25 pm
em3 View the latest post
There are no new unread posts for this topic. Need suggestions for a new handlebar.
Strekoza
Sun Jun 03, 2012 8:50 pm
RussellS View the latest post
There are no new unread posts for this topic. Help Identify Handlebar
SGcyclist
Mon Jan 21, 2013 12:04 pm
cllrhodgen View the latest post
There are no new unread posts for this topic. Attachment(s) Help me Schmolke TLO MTB handlebar crack
minimini
35
1565
Sat Feb 23, 2013 6:43 pm
carbon2329 View the latest post
It is currently Sun May 19, 2013 8:29 am
