It is currently Tue Jan 16, 2018 8:46 am
Post new topic  Reply to topic  [ 132 posts ]  Go to page Previous 1 2 3 4 59 Next
 Post subject:
PostPosted: Wed Apr 15, 2009 7:14 pm
Sold me-Clark's cables for my next rebuild. The supplied cables with ym SRAM Rival 09 shifters has left the shifting a bit sluggish and the brakes the same. A very, very meticulous mechanic and I worked on it.
I think those cables are to blame!! Hard to toss brand new cables and unwrap new bar tape though. Well, when you need ot be frugal anyways.
My Blog: http://raysracingadventures.blogspot.com/
 Post subject:
PostPosted: Mon Apr 27, 2009 2:50 am
did you happen to figure this part out? i'm installing mine now and have the same question.
it looks like both the brake & shifter cables slide right into the brake/shifter mechanism without needing ferrules.
anybody have tips for installing this stuff on sram red? thanks!
ryfry07 wrote:
Were you guys able to fit the included brake ferrules into the Red shifters? They seemed way too big to me, and I didn't want to force them.
 Post subject:
 Post subject:
PostPosted: Mon Apr 27, 2009 4:23 pm
anyone?
 Post subject:
PostPosted: Tue Apr 28, 2009 5:27 pm
I put the brake cables in without the ferrules... But that's just because I didn't know any better.
Seems to be working fine, but I'm guessing their life span might be shorter?
 Post subject:
PostPosted: Tue Apr 28, 2009 6:22 pm
got everything installed just fine, mounting came out nice & clean.. thanks for the tips, esp. from the fine folks at fairwheel bikes. :D
haven't ridden it yet, but sure shifts nicely while on the trainer. kind of odd, but shifter clicks seems louder, if that makes sense? very crisp, and quick.
 Post subject:
PostPosted: Tue Apr 28, 2009 7:52 pm
So what'd you end up doing? No ferrules?
 Post subject:
PostPosted: Tue Apr 28, 2009 8:11 pm
The cables that came stock with my 2009 Rival shifters have been working great for me so far, no problems shifting or braking. I might give Yokozuna a try next year when it is time for new cables.
 Post subject:
PostPosted: Tue Apr 28, 2009 10:26 pm
brake housing: no ferrules in sram levers or at frame braze-on's; silver ferrules (as supplied by yokozuna) going into brake calipers (into the barrel adjuster).
shifter housing: ferrules at all ends of each piece of housing (they fit fine).
 Post subject:
PostPosted: Fri May 08, 2009 4:41 pm
i installed them into my sram red kit last night. wow, i cant believe the difference. i had installed new gore ride-on kit in january on this bike so i wasnt coming from old nasty cables either.
the brake feel is amazing. the shifting is snappier than ever.
i suggest them to anyone.
 Post subject:
PostPosted: Sat May 09, 2009 8:10 am
On SRAM you need ferruels at all points, shift and brake. Depending on your lever position/bar curve it can be hard to get the brake housing in-just loosen the three cover plate screws and then insert. The brakes work much better with ferruels-over time the end of the housing will deform and the brakes get spongy.
after 2 drinks I'm a loser, after 3 a star
 Post subject:
PostPosted: Wed May 20, 2009 6:17 pm
rode it, works great--better than stock, that's for sure. looks sharp too (at least the grey/black brake housing looks unique, and the shift housing, while plain black, looks just fine).
 Post subject:
PostPosted: Wed May 20, 2009 7:20 pm
I have been switching my DA7900 bikes to these and the braking is off the hook. I don't feel like I am loosing any power in braking coming from Record 10 levers, M5 brakes, and Nokon housing. As for the shifting, it seems that some people are griping about the DA7900 shifting being spotty, but mine has been tight as a drum...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
 Post subject:
PostPosted: Wed May 20, 2009 9:03 pm
look at the diameter of that freakin' brake cable compared to the stock stuff! :shock: i honestly didn't have any complaints about stock cables for braking, but hey, this is indeed better like you mentioned. what i really cared about is shifting, and this is for sure crisper. not sure how much bigger diameter the derail. cables are, but maybe there's a few other tasty ingredients in the manufacturing process that simply makes it a better system overall.
PostPosted: Tue Jul 14, 2009 6:12 pm
Is anyone using Yokozuna with a Campagnolo? It seems like most people have switched over for SRAM or Shimano, but I need to replace my Campy cables and was wondering if I would see the same improvement everyone else is raving about. Thanks!
"Deserve's got nothing to do with it." William Munny
PostPosted: Fri Aug 07, 2009 6:09 pm
Can anyone confirm if the Yokozuna Reaction cable system or new Nokon is compatible with 11-speed and the narrower hole on the levers?
Thanks
There are no new unread posts for this topic. Fluo brake cable housing?
jever98
Wed Mar 15, 2017 7:11 pm
Kurets View the latest post
There are no new unread posts for this topic. Link cable housing and internal full length runs?
SpecializedColnago
Wed Apr 12, 2017 1:53 pm
reknop View the latest post
There are no new unread posts for this topic. Sram red 22 and segmented housing
NiFTY
Tue Sep 12, 2017 3:54 am
dereksmalls View the latest post
There are no new unread posts for this topic. Jagwire XEX-SL and KEB-SL derailleur and Brake housing
tommasini
Mon Jan 01, 2018 4:44 am
Mep View the latest post
There are no new unread posts for this topic. Setting up AX3000s with Tune housing
4ibanez
Fri May 12, 2017 5:23 am
shimmeD View the latest post
Users browsing this forum: Aya, jlok, MirkoR, pdlpsher1, silverster, Squashednuts and 40 guests
cron
