Have anyone used the Yokozuna reaction cable housing?
Rush
by Rush
Here is the Yokozuna brake housing ferrule in the SRAM Force housing. As you can see, it won't fit
Here is a standard sized ferrule (used for the shifter housing)
Here is the brake housing with no ferrule (fits fine). I note other members have used this solution.
This is my current solution
It's not perfect but I think it will be OK. As far as I can see, the only way to get a Yokozuna brake housing ferrule into the SRAM housing would be to file away the upper edge of the ferrule slot.
Rush
by Rush
Well there is a happy ending. I was testing the brakes before setting off for an installation ride (i.e. squeezing the levers as hard as possible with the bike stationary) and suddenly they went out of adjustment and I had loads of cable slack in the housing.
It turns out that the ferrules ended up working their way into the housing themselves.
The only concern I have now is the length of the rear derailleur housing loop. For the road shifting reaction (and shifting) pack, they supply the following housing lengths:
Front: 4mm x 600mm - 2
Rear: 4mm x 340mm - 1, 4mm x 300mm - 2
So the longest loop you have is a 340 mm length. I know that for SRAM it is often recommended to have a very long rear derailleur housing loop. I'm wondering if the CX or TT (internal) packages would be a better bet, although they are much harder to obtain overseas.
nfecyle
by nfecyle
That was exactly my problem last night when I installed the brake cable housing. I ended up not using one on my ultegras.
rlb81
by rlb81
I began installing these cables in my Ultegra 6700 setup tonight. I also ran into the issue of the brake cable w/ ferrule not fitting into the shifter. I happened to have a spare unused brake cable sitting around, so I ran it through the lever and cable then clamped an old derailleur to the end of the cable (right up against the end of the cable housing). Then I squeezed the lever which pulled the cable into the lever and seated the ferrule.
I suppose I could have skipped the ferrule, but I didn't want to deal with any loss of performance down the road from the cable end potentially deforming. I also wanted to have the housing properly seated from the start so it wouldn't crap out on me in the middle of a descent.
doomith
by doomith
3 rides in with the Yokozuna cables and going well!
bigpab
by bigpab
Hi,
question for yokozuna users
i had my lbs installing the yokozuna cables,in a caad10 2014 model,with 3t carbon bars internal cabling in bars...
the shifters work fine but the front cable when i turn to right or left the cables move the front brake cable resulting in the front brake activation...
i don't know if the lbs has done a dodgy job he seems to think is just the cable won't work with my frame,
i can't ride as its not safe
has anyone heard a similar failure with this cable?
Calnago
by Calnago
It's a function of how super stiff the housings are. That and the fact (as shown by others in this thread) that these cables are a pain in the ass to work with with no gain in functionality and possibly worse (as in your case, and mine) caused me to rip them off a brand new TT build I was doing and go with a set of the Shimano polymer cables and housing. Much much better and would never use Yokozuna again. But I wanted to at least give them a try. Experiment over.
motorthings
by motorthings
yokozuna shift cables/housings are amazing, but I have not found the brake cables/housings to be worth the hassle of installing.
MNX1024
by MNX1024
Good chance that your bike shop might've done a dodgy job as I was able to get Yokozuna housing to work properly on my Planet X brakes. People who owns this brake can tell you how sensitive it is to cable housings and centering it. Anyway, most people do not realize about the Yokozuna housings are that they "need" to be pre-bent before working with them. You can't really just install them like any regular housing or you'll be getting a full body workout that might result in a poor installation.
ms6073
by ms6073
My experience has been that unless you are running mechanical disc brakes, the Yokozuna brake cables/housings are a bit overkill with little gains in terms of actuation or leverage. Used a set on our disc brake cross bikes and as already mentioned, the oversized ferules paired with Shimano shifters and TRP Spyre mechanical disc brakes was a bit tedious to install, especially a full length run of the house to the rear brake where the housing exits from the top of the stay, requiring an upward bend into the caliper which due to the stifness of the housing, was somewhat problematic.
Gearjunkie
by Gearjunkie
The key with the Yokozuna brake housing is to get the length right. Too long and, especially, too short and the brake can be actuated.
Once you have them right they are very good and long lasting.
bigpab
by bigpab
Thanks for the input
I've some I links and I'll swop the brake cables hopefully it gets sorted.
Cheers
