Post new topic Reply to topic  [ 92 posts ]
Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 Post subject: Re: NEW! '09 EE Brakes!
PostPosted: Thu Aug 13, 2009 1:59 pm
So what I really want to know is are these brake pad blocks available separately?
I hate swapping pads every time I swap to my race wheels. Quite happy with my Red brakes though.
08 Cervelo R3, Sram Red, Zipp 101's= :-)
PostPosted: Thu Aug 13, 2009 2:57 pm
The yellow swiss-stops don't need to be swapped, just cleaned.
BTW, Bike Nüt in San Francisco sells EE brakes, including a very cool red anodized pair.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Thu Aug 13, 2009 3:16 pm
I hear ya, but Swiss Stops (which i use with my Zipps) don't work anywhere near as well on Alu rims as my Salmon/black Koolstops. Most of my riding is in metropolitan Melbourne and in group rides, ie. lots of traffic lights meaning heavy braking is fairly common.
PostPosted: Thu Aug 13, 2009 5:12 pm
I think he's asking about the brake pad holders. If so the aftermarket holders are a slightly different configuration from the stock ones that come on the brakes. As far as I know fairwheel is the only place to get the holders by themselves.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Thu Aug 13, 2009 6:29 pm
bar non the best working brake i have every used. i think there the best mix of light weight and has the best stopping power of any brake i have ever used. im switching from my m5s to the ee's thats how good i think they are.
Theforcetraining.com
PostPosted: Thu Aug 13, 2009 8:27 pm
+ 1 to what Jedi says... best bar NONE. No one else's design can compare with the leverage and modulation. Period. I've got 5000+ miles on mine.
Some more perspective: I have 7900s on one bike and EEs on the other. Performance is very comparable. 7900 are stiffer, but the EEs have better modulation/feel. After going to some other light brakes for some time, and then making the switch back to grouppo (DA, Record, etc) calipers... I was scratching my head thinking... I dealt with this crappy performance for how long? I was sworn off weenie brakes. Until EEs. They are different, you get a 100g savings, and you don't compromise performance.
Good greif, I test rode a bike with those flexy KCNC brakes... those are downright laughable. Don't get me started on the others.
As for pad holders... why? The pads pop out with no effort, and can be swapped in seconds as fast as you change a wheel. I use SwissStop Yellows for my carbon wheels, and Green for my Ceramics. I swap my four wheelsets just about as often as I change my underwear.
PostPosted: Fri Aug 14, 2009 2:49 am
I want the pad holders separately to see if they will fit my Sram Red calipers. Baby on the way means disposable income has gone to $hit so no new brakes for me :( . My only annoyance with having carbon wheels for race day is changing the brake pads too. If I could eliminate that hassle I'd be wrapped and would ride the zipps more often when I now the weather will be fine, otherwise I use Easton EA90 Aero's.
PostPosted: Fri Aug 14, 2009 4:08 am
Its more hassle to change the whole pad holder than just the pads, if its not Campy that is. Just undo the little set screw and slide em out. Changing the whole pad holders is more of a pain with adjusting the pad height and toe.
Congrats on the baby! And changing brakes pads will be the easiest thing you will be changing soon enough. Welcome to a life filled with dirty diapers. They make up for it though, best thing I ever did was having kids
PostPosted: Fri Aug 14, 2009 5:33 am
The EE brake design is similar to the C record deltas I have and the stopping power of those is pretty nice mainly dues to the center pull action. The stopping power of the chorus brakes with kool stop pads and a machined rim surface is even better. The stopping power of the zero gravity plus kool stop rubber and machines surface is comparable to the chorus brakes.
PostPosted: Tue Feb 09, 2010 4:33 am
Appears there's very few people retailing these online?
So no discounted prices really forthcoming....?
PostPosted: Tue Feb 09, 2010 12:42 pm
You can get them direct from EE, the production run is so small I doubt you'll see them discounted anywhere. In fact the only place I know of that stocks them is Fairwheel (there's certainly no one in the UK, where I'm based)
Mine should arrive direct from EE (via 3 weeks in customs) this morning, can't wait to try them out!
Pegoretti Responsorium
Parlee Z5i
Donhou Commuter
PostPosted: Tue Feb 09, 2010 2:49 pm
Formerly known as PezTech
No screw on the EE.
And note the retaining lip edge tapers so you pop up tha back...
and push the pad out (not a lot of effort).
Then push in the new pad and snap it closed...
I think changing blocks is a lot easier than changing pads on everything but EE.
Most pads simply do not come close to sliding out of stock holders very easy... And when you change from wheel to wheel (between carn and Alu or otherwise), you need to reposition your brake pads anyway (virtually every time).
If you're only changing pads when worn, you should inspect the pad holders and brakes and remount em anyway...
charles@pezcyclingnews.com
PostPosted: Thu Feb 11, 2010 1:19 am
I've got a pair of the brake pad holders arriving Friday. I'll let folks know how they work with my M5 brakes. Like others, I'm so tired of the extra time it takes to change holders when I switch between my alu and carbon wheelsets.
PostPosted: Thu Feb 11, 2010 2:57 am
PezTech wrote:
No screw on the EE.
That is really slick.
PostPosted: Thu Feb 11, 2010 6:35 pm
Anyone try the EE brakes with the 7900 or Di2 levers? Wondering how they work with the different leverage ratio.
Post new topic Reply to topic  [ 92 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
Users browsing this forum: danielbahia, Ghost234, Google [Bot], tdudzik and 49 guests
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
There are no new unread posts for this topic. Attachment(s) New THM matte brakes
coppercook62
14
2036
Mon Jul 30, 2012 3:17 am
thatdkid View the latest post
There are no new unread posts for this topic. AX Lightness Brakes
DamoRider
13
768
Tue Mar 12, 2013 3:14 am
sedluk View the latest post
This topic is locked, you cannot edit posts or make further replies. Lightweight CNC brakes
wpccrunner
Mon Jan 21, 2013 1:48 am
wpccrunner View the latest post
There are no new unread posts for this topic. TRP brakes binding
shoemakerpom2010
Tue Dec 11, 2012 12:45 pm
wiRIDEfast View the latest post
It is currently Wed May 22, 2013 4:34 am
