NEW! '09 EE Brakes!
I can't wait to see pics of the prototype aero cover, thanks madcow!
Here are pics and some info on the 2015 model. Just quick notes about the changes.
Arm shape changes and gets stiffer
Bushings get smaller and stiffer
Eccentric mounting bolt is gone
finger adjuster for centering
Standard length reach adjustment slots
Weight is unchanged
Price goes up about $15 (not confirmed yet)
Main mounting bolt is covered with plastic plug, this plug will be available in a range of colors.
Rim widths from 18-28mm
Tire clearance for a 28c tire
leverage changed for slightly more power
compatible with Shimano, Sram or Campag levers
Available in August.
Direct mount version will be available at the same time. Carbon shield or alloy bridge options.
Weight is unchanged
How does the new centering mechanism work?
The old eccentric mounting bolt is the most interesting part of eebrake
I think calling it a cover is a bit misleading, you do not mount the brake and then mount the shield over it. It is an aero replacement of the bridge that would normally be alloy. If it were a cover I don't think it would be UCI legal, but as it is it's an integral piece of the brake, that is the brake will not work without a bridge and you can use either the flat alloy bridge or the carbon aero bridge.
Bman I'll try and snap a few more pictures this afternoon.
Is it possible to see the shield off of the brake. So if I am correct, you remove the metal brace, and replace it with the shield. So that is how it is held in place. So there is no way this would be a retrofit to the old brakes.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
correct it replaces the metal bridge. It will not work on older brakes as it only fits direct mount brakes.
