It is currently Sun Apr 30, 2017 10:08 pm
Post new topic  Reply to topic  [ 32 posts ]  Go to page 1 2 3 Next
 Post subject: Lightweight seatpost
PostPosted: Tue Jan 18, 2005 4:54 pm
Hi, is there anyone who can recommend me a nice (light) seatpost. My current one is an ITM Millennium carbon (170gr) in combination with a Tune Speedneedle. The ITM is burst so I have to get me a new one. I don't want carbon this time, but it must be around the weigt of my ITM or, if it is possible, below it. Anyone suggestions, titanium, aluminium, price?
Thanks[/list]
 Post subject: Post
PostPosted: Tue Jan 18, 2005 5:36 pm
Get a USE Alien Alloy or TI. They're lighter than ITM and more reliable. I've had a carbon one for 4 years with no problems other than a metal shim seizing in the frame due to lack of care!
 Post subject: Post
 Post subject:
PostPosted: Tue Jan 18, 2005 5:38 pm
what is about a new ultimate or a heylight post?
both are available under 100g (the shortest/ thin version ~200mmx 27,7mm) and cost about 150€
http://www.b-t-p.de/BTP-English/product ... nents.html
http://www.heylight.de/produkte/sattels ... leicht.htm
Pedä
 Post subject:
PostPosted: Tue Jan 18, 2005 6:21 pm
While on the subject .. how about the EC90? Anybody have any experiences with that?
I like the standard one-bolt design. It's relatively cheap in the U.S. I regularly see them going new for 100-130 $ on ebay.
 Post subject:
PostPosted: Tue Jan 18, 2005 7:18 pm
EC 90 is nice, but kind of flexy, due to the offset. I wouldn't buy the offset version again.
 Post subject:
PostPosted: Wed Jan 26, 2005 9:51 pm
Resident Pro
Schnolk TLO is the lights, but you will pay for it.......... 380euro
 Post subject:
PostPosted: Thu Jan 27, 2005 8:15 pm
Just received mine : TLO, 27.2 / 300 mm : 92 gr....
Breathtaking !
Pollice verso.
 Post subject:
PostPosted: Thu Jan 27, 2005 8:42 pm
I have a Thomson Masterpiece (158g). CNC Machined Aluminum, weighs less than your ITM did, pretty darned stiff too.....a little on the pricey side at $140.00 US.
 Post subject:
PostPosted: Thu Jan 27, 2005 9:02 pm
My Extralite UL2 is 156g uncut. (360mm) So it's going to be fairly light when i'll cut it. And it's strong.
 Post subject:
PostPosted: Thu Jan 27, 2005 9:12 pm
Is this a common thing to do? Cut your seatpost? Dude, I'd be careful if I were you.
 Post subject:
PostPosted: Thu Jan 27, 2005 9:19 pm
Is it a common thing? Yes.
I'll cut it so it ends 1-2 cm under the end of top tube jonction.
 Post subject:
PostPosted: Thu Jan 27, 2005 9:48 pm
...not afraid to find one of these days the seat tube in direct combo with your a** ?
Pollice verso.
 Post subject:
PostPosted: Thu Jan 27, 2005 9:52 pm
Well what i'm thinking about is most seatposts have a line on them that indicates that 'thou shalt not extend post out of frame beyond this line'. I guess as long as your post has at least that length of post below the line sticking in the frame then you should be ok.
So for example if you get your optimal riding position for your post and the line is say 20mm below the top of the seat tube then you can cut 20mm off the bottom and still be safe. The down side it would seem is that you would no longer have the ability to raise the post beyond where you originally had it set. Say if you decided you needed to raise the post because you thought you weren't getting enough extention on your pedals. In that case it would be best to give yourself some room for error and not cut the full 20mm off....maybe you should only cut 10mm instead?
 Post subject:
PostPosted: Thu Jan 27, 2005 10:03 pm
Except if the post is machined or butted in a way that the bottom is wider/ stronger than the top (I think this is the case of new ultimate). I guess you can only cut posts that have the same tube diameter/shape all along the post.
 Post subject:
 Post subject:
Curious if there are any recommendations for a 31.6mm setback post...
Without going to "exotics" such as heylight or schmolke... I was considering an EA70...???
This topic is locked, you cannot edit posts or make further replies. ENVE SES 4.5 or Lightweight???
jerrybrabus
32
3724
Fri Jul 29, 2016 5:02 am
reggiebaseball View the latest post
There are no new unread posts for this topic. Lightweight MTB SPD's
weastman
7
590
Wed May 11, 2016 10:27 pm
prendrefeu View the latest post
There are no new unread posts for this topic. lightweight cockpit
Rubik
11
973
Wed Apr 26, 2017 12:43 pm
DaReef View the latest post
There are no new unread posts for this topic. (Not lightweight, but...) How do you set up 105 5800 FD?
niklasp
16
813
Wed Apr 26, 2017 9:21 am
niklasp View the latest post
There are no new unread posts for this topic. Lightweight Urgestaldt
Roadeeee
21
2559
Fri Feb 24, 2017 9:49 pm
KCookie View the latest post
Users browsing this forum: Broady, Google Adsense [Bot], krusty, Musiker, Samklee15, Vikingr, wrcompositi, Yahoo [Bot] and 43 guests
