It is currently Thu Jan 18, 2018 7:29 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Sat Jan 15, 2005 7:12 pm
Looking for recommendations on tools and technique to cut a carbon fiber steerer tube.
I need to take 1.5 cm off mine.
THanks.
PostPosted: Sat Jan 15, 2005 7:49 pm
It's pretty simple when done with care but READ THIS CAREFULLY if this is your first time.
And remember: measure twice, cut once....
"Gimondi รจ un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Sat Jan 15, 2005 8:19 pm
there is a good guide to this at:
http://www.eastonbike.com/TECH_FAQ/tech_techbull.html
look at number 5 - "cutting carbon"
 Post subject:
PostPosted: Sat Jan 15, 2005 9:31 pm
Got the Park tool. It a superb tool, and always take the most versatile (parktool delivers a range, so you can also cut 1"an 1 1/4" tubes and Seatposts as wel
 Post subject:
PostPosted: Sun Jan 16, 2005 2:20 am
Just a quick note that once you have cut the fork to the desired length, do not dress it with a file. Use some light wet/dry about 1200 grade. It stops the carbon de-laminating. Dan 8)
 Post subject:
PostPosted: Sun Jan 16, 2005 3:50 am
Thanks for the links and tips.
 Post subject:
PostPosted: Sun Jan 16, 2005 3:54 pm
1200? That is a bit on the fine side, depending on what blade you use. I prefer to start with 400 as it makes the process much faster. I also give the tube a slight chamfer which prevents delamination when facing the tube end. After all is done, a light coat of thinned epoxy will seal the cut end if there is any porsity.
I don't use a cutting guide on CF. I prefer to wrap the tube with masking tape, score the cut line with a razor sharp tube cutter and cut just outside of this line.
 Post subject:
PostPosted: Sun Jan 16, 2005 5:55 pm
tube cutters, no matter how sharp they are put pressure on the steerer. A good guidance and a special sawing blade (dedicated for carbon with as many teeth as possible) is a far better way.
Finally, especially when used in the wet: don't forget to seal the surface with nail polish or better, super glue to make sure fiber won't come loose and water won't com in.
 Post subject:
 Post subject:
PostPosted: Sun Jan 16, 2005 6:53 pm
We use a regular cutting guide but use the same blades used to cut ceramic tiles. 1200 weight paper works fine.......use it every day does the trick for me.
There are no new unread posts for this topic. show me your steerer tube ( inside )
stormur
Wed Jan 18, 2017 6:36 pm
stormur View the latest post
There are no new unread posts for this topic. Leather top vs. Carbon Fiber saddles (SMP Forma vs. Carbon Lite)
dgeesaman
Thu Aug 31, 2017 11:52 am
kgt View the latest post
There are no new unread posts for this topic. Help me please-Carbon fiber
Bianchi10
10
1551
Tue Jun 27, 2017 10:46 pm
thumper88 View the latest post
There are no new unread posts for this topic. Attachment(s) DIY Carbon fiber repair - seatstay.
BikeAnon
40
5674
Thu Nov 02, 2017 1:45 pm
BikeAnon View the latest post
There are no new unread posts for this topic. Carbon fiber spokes + Alloy Rim = DISASTER(for MAVIC users)
[ Go to page: 1 2 3 4 5 6 ]
ohhyeok90
80
5531
Thu Nov 16, 2017 9:57 pm
antonioiglesius View the latest post
Users browsing this forum: Google Adsense [Bot], Languid, YinYang, zoki76 and 24 guests
