Post new topic Reply to topic  [ 41 posts ]
Go to page Previous  1, 2, 3
 Post subject: Re: BTP Shifter Clamps
PostPosted: Fri Mar 01, 2013 2:13 am
Tubbie Guru
Hi,
Same here. 8)
Not sure they're still in production though. It all seems a little too quiet on the Western front.....
Ciao, ;)
PostPosted: Fri Mar 01, 2013 5:25 pm
thought about these a few times ...then i change my mind
i had their bottlecages as well & i punted them on
really flimsy & voids in the carbon ..looked really DIY ..
tcr's rule !
stefanpearce@rocketmail.com
PostPosted: Sat Mar 02, 2013 9:05 am
The finish of the clamps could be better. They look DIY indeed.
I had to file one of these, it was too wide to fit into the mounting slot.
Not a big deal at all, but for this price it should hold the diameters at least.
On the other hand, it's an element which doesn't get sunlight, so why bother...
They hold the shifters firmly and save 20g of the original ones.
Cervelo R5 VWD 5637g/12.43lb
Cannyon Ultimate slx 5592g/12.33lb
Pronghorn XC SW Race 8284g/18.26lb
PostPosted: Sat Mar 02, 2013 4:09 pm
I've been using mine since 2007 or 2008. Say what you want, they work.
Speedplay is the devil.
PostPosted: Sat Mar 02, 2013 4:31 pm
I have three bikes with these clamps and no issues whatsoever. I have been using them for the past 4 years. I always inspect them when i change my handlebar tape and have never found any problems. I would not hessitate to use them on my next bike.
PostPosted: Sun Mar 03, 2013 1:03 am
Tubbie Guru
Hi,
As it happens I am not even so sure mine were actually made by BTB.
Could it be MCFK (not sure) makes these as well as mine seem to be made entirely out of UD carbon and were finished quite nicely. Similar to a seatpost clamp actually.
Either way, I'm perfectly happy with mine and as someone quite rightly mentioned before, once in place you won't be looking at them anyhow. So, if they do the job they are intended to do, why bother with what they look like.
Ciao, ;)
PostPosted: Sun May 12, 2013 10:51 pm
Recently acquired some BTP clamps from a forum member and seem to be having some fitment issues. I understand these are true weightweenie parts and have a handmade aspect to them, but the fitment is not even close (about 1/4" too big). I tried to use these with my 2012 Sram Red Ergo shifters, but they can't fit flush inside the the shifter like the stock clamps.
I'm very hesitant to modify them as they look very fragile as is. Has anyone successfully used these with the 2012 Sram Red Ergo shifters? Did you have to modify them in any way to make them fit? Do you recommend sanding them down to make them fit?
Thanks in advance.
PostPosted: Sun May 12, 2013 11:47 pm
Thanks in advance.
I thought I read somewhere that the design of the newer sram red shifters didn't work w/ the btp clamps, but I can't remember where.
PostPosted: Mon May 13, 2013 12:24 am
I have a hunch that you are absolutely correct. I don't have the guts to modify the clamps due to safety reasons. Can anyone else confirm that the BTP carbon clamps do not work with the 2012 Sram Red Ergo shifters? Are there any alternative options out there to lighten the 2012 Ergo shifter? I've done a search here on WW, and it seems that all the tuning on Red shifters only pertain to the first generation (pre 2012).
Cheers.
PostPosted: Thu May 16, 2013 4:49 pm
Just wanted to add that while BTP is no longer producing anything these clamps are still being produced by someone. The standard ones are available through Tune and Schmolke offers a larger diameter one to fit the new full-over bar.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Fri May 17, 2013 7:10 pm
Do you know if they make one to fit the 2012 Sram Red Ergo shifters? Haven't had any luck searching online to see if there is an answer for this.
Thanks.
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Bing [Bot], Google Adsense [Bot], martroy, nlop, wassertreter and 55 guests
There are no new unread posts for this topic. New shifter clamps in DA 9000?
uraqt
11
807
Wed Mar 27, 2013 12:37 am
5 8 5 View the latest post
There are no new unread posts for this topic. Shimano Di2 R671 TT Shifter
alannmcl
7
625
Fri Feb 15, 2013 7:03 am
footwerx View the latest post
There are no new unread posts for this topic. Dura Ace DI2 sprintshifter AND top-bar-shifter
philischen
Wed Sep 12, 2012 5:22 pm
philischen View the latest post
There are no new unread posts for this topic. Shimano 105 shifter rattle??
will102
Tue Nov 13, 2012 10:19 am
will102 View the latest post
There are no new unread posts for this topic. New SRAM Red shifter tuning
skywalker268
Wed Mar 06, 2013 7:21 am
prendrefeu View the latest post
It is currently Wed Jun 19, 2013 1:34 pm
