Post new topic Reply to topic  [ 33 posts ]
Go to page Previous  1, 2, 3
Which Paved / Fire Road Clincher Tire
Poll ended at Wed Jun 11, 2008 3:01 pm
Vittoria Open Pave 24mm 69%  69%  [ 11 ]
Michelin ProRace2 25mm 19%  19%  [ 3 ]
Continental GP4000 25mm 13%  13%  [ 2 ]
Vittoria Open CX 25mm 0%  0%  [ 0 ]
Total votes : 16
PostPosted: Fri Feb 01, 2013 3:43 pm
I guess it all depends on your definition of dirt and/or gravel roads... Right now, most of the dirt roads here in the DC area are pretty smooth. Come spring, they're going to get re-graveled and then riding on em on road tires won't be all that fun. :nah
Me? I'm on some 28c Gatorskins at the smallest and more usually on some 34c Racing Ralphs. I AM on cross bike(s) when I'm riding these tho, that may make a difference. Buddy of mine has Michelin Jets. They seem to roll faster than my RR-s.
I *should* be out riding dirt roads for 4hrs today, but its about 20deg F out and the wind is howling. The couch monster and its evil minions 'the Screw-its' are attacking.
M
PostPosted: Fri Feb 01, 2013 9:31 pm
They've already been mentioned, but Tufo C Elite Ride 25's. The tubular-clincher model. You can load them with sealant (they work better than clinchers for this since there's no tube) for thorns/glass, and they are as resistant to pinch-flatting as any tubular, perhaps more so because of the lack of a tube. The result is you can run them at way lower pressure than any clincher, meaning a better ride and better traction on dirt and gravel.
I use these for training, my team (we all race road and cx) often take dirt/gravel roads on our training rides. I can absolutely crush on these because of the 25mm size and the lower pressure. I often run them at 50-60psi, try that on a clincher on a dirt/gravel road and you'll pinch at any kind of speed.
My point being, the advantages of running lower pressure more than make up for the lack of a supple casing, and the extra grams. They're not cheap, hard to find for under $79 per tire, but I find the on/off road performance for my riding to be worth it.
PostPosted: Sat Feb 02, 2013 1:56 am
Tubbie Guru
Hi,
That sounds contradictory to me.
You can have lower pressure, more supple casing hence lower crr and less weight in a single tyre.
Ciao, ;)
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Bing [Bot], Mario Jr., nigel379, tri, Vuong05 and 50 guests
There are no new unread posts for this topic. I need advice for Road Tires
marcio riva
26
2266
Tue Aug 28, 2012 8:49 pm
mrfish View the latest post
There are no new unread posts for this topic. Tubular for Canadian spring riding (slush, dirt, sand, etc.)
LouisN
11
638
Wed Jan 02, 2013 8:37 pm
Geoff View the latest post
This topic is locked, you cannot edit posts or make further replies. Looking for Gumwall Tires
photocycler
Sun Feb 10, 2013 8:51 pm
tonytourist View the latest post
There are no new unread posts for this topic. Rebranding tires - how to do it
petal666
Thu Sep 20, 2012 1:21 pm
chazzawoods View the latest post
There are no new unread posts for this topic. When do you replace your bike tires?
stevec1975
Wed Aug 22, 2012 3:55 pm
prendrefeu View the latest post
It is currently Sat May 18, 2013 11:28 pm
