Post new topic Reply to topic  [ 33 posts ]
Go to page Previous  1, 2, 3  Next
Which Paved / Fire Road Clincher Tire
Poll ended at Wed Jun 11, 2008 3:01 pm
Vittoria Open Pave 24mm 69%  69%  [ 11 ]
Michelin ProRace2 25mm 19%  19%  [ 3 ]
Continental GP4000 25mm 13%  13%  [ 2 ]
Vittoria Open CX 25mm 0%  0%  [ 0 ]
Total votes : 16
 Post subject:
PostPosted: Sat Jun 14, 2008 12:34 pm
World Cycling Production
I ordered all black, but were back ordered for 2 wks. So I changed to green and got the last 2 they had. After discounts (special offer code on catalog) I paid $101.00 for the 2 tires.
PostPosted: Wed Jan 30, 2013 11:41 pm
Old topic, but it certainly seems to have come back around and there are several new tires since 2008, plus most would be set to much wider rims now as well, so I thought it was worth revisiting... and I've always been a fan of Randall Graves, so "I'm taking it back!"
Vittoria Open Pave - a decent reputation for toughness and ride, but unchanged for years and the 24c size is the biggest that would fit in regular road bikes
Michelin - extra-volume of their 25c is a plus, as they still fit in most road bikes, but they've not always the most resilient tires in the past (see question below)
Continental - GP4000s in 25c has been a nice addition to their line-up, as everyone knows what you're getting with a Conti by this point
So I suppose the questions are:
1) Does anyone have experience with the new Michelin Pro4 Endurance tires? They are mentioned as being a replacement for the Krylion Carbon, who's resilience I've been AMAZED by, so I'm keen to know if they're suitably strong and still have the typical volume of Pro3Race and Optimum 25c tires.
2) What else is out there that people have had the best experience with? Bonus points if we can keep it limited to what would fit into a standard road bike.
PostPosted: Thu Jan 31, 2013 12:02 am
Vittoria Open Pave......they probably haven't changed them because there is little to do to make them better. I use them on my "training", i.e. bad road, gravel, dirt road wheels and they never disappoint. Not to mention they aren't too shabby on the road either and only 220 or so grams per tire.
PostPosted: Thu Jan 31, 2013 12:49 am
I've always used Gatorskins, but am tempted to try GP4S. A little lighter, but I have torn a sidewall once on a gravel road on Gatorskins. It was a nail. Damn these old mining buildings.
PostPosted: Thu Jan 31, 2013 9:56 am
My pair is a lot heavier, 244-251g for the regular sized (24mm) 320tpi Paves.
PostPosted: Thu Jan 31, 2013 10:47 am
I doubt many of the people choosing Paves have a great deal of experience with different tyres in the use you're suggesting.
Because they aren't very wide (in 24mm guise) or very puncture resistant when it comes to small flints/gravel chips. And yes, it's c.250g. Nowhere have I seen it weighed at 220g.
Good tyre, but really only for dirty/winter roads, rather than pave/gravel tracks.
All the others are better options. A new tyre with lots of tread is important here remember.
If you want something fast and wide then the 28mm Ultremo ZX is good also.
Michelin Optimum is another good bet if durability is more of a concern
PostPosted: Thu Jan 31, 2013 1:24 pm
Hmmm, I will certainly go back and re-check my weights. Maybe I didn't weigh a brand new pair? I'll let you know what I find.
Also, I haven't had your experience with the Pave's as mine have performed wonderfully in dirt/gravel situations which can extend for miles on a route I take regularly. Maybe the dirt/gravel has larger chunks rather than the flint you are referring to :noidea:
PostPosted: Thu Jan 31, 2013 1:32 pm
Well years later I have tried all the tires. No contest. Not even close. The Michelin ProRace 2 in size 25. Still find them once in a while. I think they are about 260g and measure 27mm. Great ride and durability. Traction and handling on dirt and gravel is the best.
TIME RXR
PostPosted: Thu Jan 31, 2013 2:35 pm
Will be amazed if you weigh a few new ones on an accurate scale and they come out at 220g. 245-250g pretty consistent IME
Smaller flint kills them yes. Generally their puncture protection is pretty good however.
PostPosted: Thu Jan 31, 2013 11:54 pm
Gregario - have you tried the Optimums, as they certainly seem to have the 27c look to them. I've ridden with a customer on some truly gnarly gravel (he was seriously the ONLY client we've had all year who could have still been smiling at the end of it), and he had a pair of Optimums on Zipp 101 - they looked like Balloons!!!
Sawyer - can you back up your durability comment for the Optimums. I'd love to hear a bit more of your experience so I can understand how it relates to what I'm planning. Also, have you any comparison to the Pro4Endurance?
PostPosted: Fri Feb 01, 2013 12:57 am
I've ridden them all... and have some Grand Bois in a 26... Optimums are better for this kind stuff. Get two rears if you are serious about wanting them bomb-proof.
PostPosted: Fri Feb 01, 2013 4:50 am
I have a been running 23mm GP4000s over a fair bit of gravel roads and they have stood up pretty well. I typically get one flat per year and it has always been the side wall that has failed presumably after having hit a larger rock.
PostPosted: Fri Feb 01, 2013 8:22 am
HI - I have a set that have done some commuting service through London with no punctures. That said, I've only had one set ... a victim to too many tyres to ride and too little time. But they are really a reinforced version of a 25mm ProGrip. Not like Krylions though ... much more supple and fast rolling. In fact I think the front essentially is a big ProGrip and the back has all the additional tread.
Good Paris-Roubaix option
PostPosted: Fri Feb 01, 2013 8:50 am
my michelin pro4 sc 25mm weigh 220-225g. they measure 26.5 on a quite narrow rim (pro lite bracciano. To me these are exelent for bad roads, but not grippy enough for the supersteep gravel paths around here. I can go quite low on pressure as well with latex tubes, 70-80psi is okay with my 75kg
PostPosted: Fri Feb 01, 2013 11:46 am
I agree with sawyer in that the Paves are not resistant to punctures when used on roads made of crushed stone (man-made gravel). The small particles are as sharp as pieces of glass and even a brand new Pave will puncture very easily. I think this is due to the soft rubber compound, which makes the flints stuck to the tyre. Otherwise Pave is a great tyre for winter/bad weather riding.
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: 1415chris, Google [Bot], thencameyou and 34 guests
There are no new unread posts for this topic. I need advice for Road Tires
marcio riva
26
2295
Tue Aug 28, 2012 8:49 pm
mrfish View the latest post
There are no new unread posts for this topic. Tubular for Canadian spring riding (slush, dirt, sand, etc.)
LouisN
11
653
Wed Jan 02, 2013 8:37 pm
Geoff View the latest post
There are no new unread posts for this topic. Rebranding tires - how to do it
petal666
Thu Sep 20, 2012 1:21 pm
chazzawoods View the latest post
This topic is locked, you cannot edit posts or make further replies. Looking for Gumwall Tires
photocycler
Sun Feb 10, 2013 8:51 pm
tonytourist View the latest post
There are no new unread posts for this topic. Recommendations on 25c and 28c Tubeless tires?
thatdkid
10
596
Fri May 17, 2013 4:02 am
tinozee View the latest post
It is currently Sat May 25, 2013 11:25 am
