Best latex tube - which one?
mitchgixer6
by mitchgixer6
Your point is indeed valid, but considering that the tube cost me £9 I wasn't willing to put it in the bin due to one puncture.
Yes the patch isn't as elastic as the tube itself, but it only covers a very small area of the total tube. I certainly can't feel it whilst riding my bike, I'm usually too busy trying to avoid potholes to worry about such a small issue! I will put another patch on it if I flat again on the same tube, but would stop at 2 patches purely due to the fact that that's my limit on ANY tube.
fdegrove
Tubbie Guru
by fdegrove
Hi,
Not sure this was actually mentioned in this thread but you can make your own latex patches from an old latex inner tube. Just make sure they're nicely rounded.
The problem with butyl patches is that it creates stress points in the area around them, overstretching the latex locally if you like which may lead to premature leaks and/or punctures.
I actually do feel and sometimes even see the presence of a butyl patch with top of the line tyres a la Veloflex Corsa etc. I find it quite annoying.
Ciao, ;)
mitchgixer6
by mitchgixer6
Thanks for the tip. Will try that once I have 2 patches on this tube and is ready for cutting into circles!!
dereksmalls
by dereksmalls
spytech wrote:"Vittoria aim to introduce some key products with the new Nanographyte material in mid-2014 for the 2015 season."
6 months from now at the earliest.
:popcorn:
11.4
by 11.4
fdegrove wrote:Hi,
Using talcum powder to make it easier to mount the inner tube, yes. But that won't lower the rolling resistance of a tyre.
Try to use it sparingly as when talcum powder gets wet it tends to caulk.
Ciao, ;)
I haven't had problems with real talcum powder. However, most of what is marketed these days as talcum or baby powder is mostly or totally cornstarch and that stuff does turn into glue when wet. It'll glue your tube into your tire if it meets water, and of course is happy to make hard little lumps after it dries. Be sure your bottle says "talc" and never any cornstarch at all in the ingredients list.
Ekorre
by Ekorre
+1 on the michelin
1415chris
by 1415chris
What kind of glue do you use for "hand cut old latex tube" patches?
I tried Rema TipTop cement once but with no success.
fdegrove
Tubbie Guru
by fdegrove
Hi,
That's odd as I always used that one without any troubles at all.
Do clean the patches and the punctured area with some alcohol first, do not use any abrasive sanding paper.
Cheers, ;)
1415chris
by 1415chris
That seems to be a reason of my failure, sanding the tube.
Next time I shall try alcohol, before, during and after gluing :)
Thanks Frank :thumbup:
WMW
by WMW
1415chris wrote:What kind of glue do you use for "hand cut old latex tube" patches?
I use Elmer's Rubber Cement from a jar... from the craft section of Walmart or wherever. It's cheap and lasts a long time.
I even use pieces of latex for patching butyl tubes (which I carry as spares)... it just works better.
formerly rruff...
Razor
by Razor
fdegrove wrote:Hi,
Ciao, ;)
I've used all of the latex tubes; Michelin, Vreds, Vittoria, Challenge. I find that the Vreds are a nicer ride but they are finicky. If you get a small hole and need to patch it on the road (I usually just carry an extra tube), it may be hard to find/hear/feel. I'll usually just put in the spare tube and wait to get home to patch the other one (it is necessary to submerge it under water to find the hole). I use baby powder on them before mounting them in the tire. Currently using them with Conti 4000s which give a smooth ride (contrary to using a butyl tube which makes the Conti's feel like they "bounce" over road imperfections).
As mentioned, I too used old latex tubes and cut them up for patches. I uses the regular glue that comes with butyl tubes, I've even used Super Glue. Sure, they lose air but I pump up my tires before every ride just out of habit. The reason why I have the old tubes and are using them for patches is because I could not find the hole that was causing the leak or they have been patched before and the escaping air is coming from a bad patch job which would require ripping the old patch off and reapplying it which is not idea so I just use it as patch source.
nayr497
by nayr497
After reading the advice of some in this thread, I've successfully patched latex tubes with a small patch made from another latex tube. It's worked great.
I'm curious - has anyone tried patching a butyl tube with another tube? Did you use a butyl patch? Latex?
I ask because I flatted on my 'round bike last night on my way to the movies. In looking through my patch kits at home...I have a whole bunch of glue, but am nearly out of the black-with-orange rim patches included in the Park Tool little patch kit boxes. Was wondering if I could make my own patches for butyl tubes as well?
A good day becomes a better day with a bicycle ride.
nayr497
by nayr497
Ah! It looks like the question I just asked....has already been answered!
Nice. I'll go ahead and give patching my butyl tube with a self-cut latex patch a try.
Thank you. :beerchug:
gazzaputt
by gazzaputt
I have used Park Tools patches on my latex tubes and they've worked fine.
ms6073
by ms6073
I have also used Park Tool clear self adhesive patches on Michelin Latex tubes (and while not as elastic as latex patches, will work in a pinch but wanted to mention that it can be problematic if contaminants such as sunscreen get on the patch during the repair.
