Best latex tube - which one?
btompkins0112
by btompkins0112
The Vredestins are natural latex which will lose more air than the pink or green latex that Vittoria or Michelin use. You just have to pump them up again and they should be fine :noidea:
MattSoutherden
by MattSoutherden
Yeah. The Vredestein's lose loads of air.
The biggest problem I had with them, though, is the valves - they keep failing and don't hold pressure.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
rainerhq
by rainerhq
Pumped to 8 BAR and after 12 hours 2,7 BAR (no riding, bike was hanging on the wall)
Loss is 0,44 BAR/hour
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
fdegrove
Tubbie Guru
by fdegrove
Hi,
Are you saying that pigmented latex loses less air than natural latex?
Ciao, ;)
btompkins0112
by btompkins0112
I am just saying that in my experience the pigmented latex holds air better than the unpigmented (natural) latex.....just my personal experience. It could be down to many factors, maybe thickness? Or possibly the pigmentation bonds some of the gaps? I really haven't a clue.
However, the natural latex rides much better!
atakaoka
by atakaoka
I'd say:test mounted on wheel whith full pressure on water.you may have a small puncture really hard to find.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
fdegrove
Tubbie Guru
by fdegrove
Hi,
Couldn't agree more. :thumbup:
Ciao, ;)
basilic
by basilic
rainerhq wrote:Pumped to 8 BAR and after 12 hours 2,7 BAR (no riding, bike was hanging on the wall)
This is not the porosity of latex, you must have a leak somewhere. This has happened to me once, and at first I didn't find the leak. But then I took my time, put the inflated tube in water, went slowly around, and found a tiny hole that emitted a micro-bubble every 3-4 seconds or so. Easy to miss.
Imaking20
by Imaking20
My Vreds always leak down like mad as well. More than my vittoria latex tubes in clincher or tubbies.
Current:
T2
Retired:
fdegrove
Tubbie Guru
by fdegrove
Hi,
Any latex inner tube should, typically, not be leaking more than two bar in 24 hrs.
AFAIK all higher end tubulars use unpigmented latex inner tubes.
There's no such thing as a problem with Vredestein latex inner tubes. I can well imagine there's a lack of knowledge on how to mount latex inner tubes though.
Ciao ,:
mellowJohnny
by mellowJohnny
Easiest way to mount them is to get someone to sew them inside a nice tubular for you...
1415chris
by 1415chris
About this time a year ago, regarding the new Vttoria's facilities we could red:
"The Nanographyte technology makes it possible for Vittoria to produce latex inner tubes that are 100% air-tight as well as lightweight. With 30 grams these inner tubes are the lightest in the world."
Any light on these new tubes would be welcomed. Have they reached the shopping shelves yet?
spytech
by spytech
"Vittoria aim to introduce some key products with the new Nanographyte material in mid-2014 for the 2015 season."
6 months from now at the earliest.
mitchgixer6
by mitchgixer6
fdegrove wrote:Hi,
Vulcanizing patches like Rema Tip Top work just as well for latex tubes as for butyl.
It works but then you find yourself with Half a Nelson.
Anyone use their brain any more?
Goodbye and good night, ;)
Just been reading this thread though, I don't understand the above comment. What's 'Half a Nelson'?
I've got a Rema patch on my Michelin latex tube and have been using it for approx 6 months with zero issues.
fdegrove
Tubbie Guru
by fdegrove
Hi,
If by "work" one means it actually sticks to the latex inner tube, then yes, it does.
But then what's the point of using latex inner tubes if one's going to patch them with something that has nowhere near it's superior elastic properties?
Half Nelson refers to a movie that goes by that title but never mind....
Ciao, ;)
