It is currently Sat Jan 20, 2018 8:13 pm
Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 18 9 10 11 1220 Next
PostPosted: Wed Jun 12, 2013 11:26 pm
Tubbie Guru
Hi,
In what way does the addition of talcum powder reduce rolling resistance?
TA, ;)
PostPosted: Thu Jun 13, 2013 12:58 am
fdegrove wrote:
Hi,
TA, ;)
You know what, I have no idea if it does reduce rolling resistance. I've just always done it after been told by my Dad, various other racers and also mechanics etc doing this with tubes at various shops. :noidea:
2012 BMC SLR 6.02kg http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110390
PostPosted: Thu Jun 13, 2013 5:16 pm
Doesn't... just make it easier to do a good install and removal.
formerly rruff...
PostPosted: Fri Jun 14, 2013 3:38 pm
Eclipse Road Superlight Inner Tube, a claimed 29 grams....
Don't know if they are latex or not though but still without a doubt the lightest tube I've ever heard of. They aint cheap at £40 a pop though.
(http://www.wiggle.co.uk/eclipse-road-su ... nner-tube/)
PostPosted: Fri Jun 14, 2013 3:56 pm
(http://www.wiggle.co.uk/eclipse-road-su ... nner-tube/" onclick="window.open(this.href);return false;)
Their press release says they are made of a "special plastic".
http://www.eclipse.ch/new/Press.html
My Cervelo R5
My Lynskey Helix
My MTB
PostPosted: Fri Jun 14, 2013 4:09 pm
This was also something I also have done over the last 30-years but having disassembled thoroughly warn/punctured Veloflex road and FMB cross tubulars, I noted that both had a talc-like powder residue inside. Also wanted to add that in hot/humid climates like we have hear near the Texas Gulf Coast, in the summer time (May-September :roll:), road temps often exceed 120+ degrees and adding talc helps keep the latex from sticking to the tire carcass. As for rolling resistance, I have always gotten the impression it helps by allowing the inner tube some 'wiggle' room inside the tire.
PostPosted: Fri Jun 14, 2013 11:28 pm
Tubbie Guru
Hi,
Seen that too but not recently. My guess is that the manufacturer hoped the fine talcum powder inside the inner tube would somehow reduce the porosity of latex hence helping to keep its pressure longer.
Does it matter one bit if or not the inner tubes sticks to the casing? I don't think so as an inner tube doesn't move with respect to a casing. How could it?
Yeah. If it would be half as good as it sounds to be we'd all be using by now. :mrgreen:
Ciao, ;)
PostPosted: Sat Jun 15, 2013 1:40 pm
I always thought it was to make the tube able to move (don't stick to the tire).
So wenn you inflate the tube it will spread better in the tire. That helps to keep the wall thickness evenly spread and so giving the lowest possible rolling resistance.
PostPosted: Sat Jun 15, 2013 11:17 pm
Tubbie Guru
Hi,
Using talcum powder to make it easier to mount the inner tube, yes. But that won't lower the rolling resistance of a tyre.
Try to use it sparingly as when talcum powder gets wet it tends to caulk.
Ciao, ;)
PostPosted: Mon Jun 24, 2013 9:49 pm
I swapped some tires around over the weekend.
Vredestein latex tubes (20/25) in Veloflex Paves (23) on Mavic Open Pro rims. Tubes went in very nicely and evenly, perfect size, easy as mounting up butyl tubes. Very nice ride quality, though on this wheelset Vittoria Corsas CXs seemed slightly smoother. Could be in my mind!
Vredestein latex tubes (20/25) in Veloflex Master (22) on Mavic Ksyrium SL rims. Same thing, very, very easy to mount. Haven't ridden them yet.
It's been noted before, but I had a great deal more trouble with Michelin latex tubes. They just seem too big for 22 or 23 mm tires, I always seem to get a bunched up spot.
I did get my first flat on Friday (solstice ride!) on Vredestein tubes. A slow leak, no blowout, which is better than the other option. Now I just need to find someone with some latex pieces I can have, as I'm reluctant to cut up a tube with one pinprick hole to get some patches. Nobody I ride with has any, nor do any of the LBS. I guess I'm in butyl country!
Oh, and I've been trying to mount Vittoria Open Corsa tires on some older Campagnolo Delta Strada rims. Wow, those rims don't seem to like any tires, it's always, always a major PITA, er PITThumbs.
A good day becomes a better day with a bicycle ride.
PostPosted: Mon Jun 24, 2013 9:55 pm
Vulcanizing patches like Rema Tip Top work just as well for latex tubes as for butyl.
my plastic bikes, 29ers & stable of old steel
PostPosted: Tue Jun 25, 2013 12:35 am
Tubbie Guru
Hi,
It works but then you find yourself with Half a Nelson.
Anyone use their brain any more?
Goodbye and good night, ;)
PostPosted: Mon Jul 15, 2013 3:23 pm
Problem with Vredestein latex tube.
It looses air during night and in the morning it´s empty, but it does not happen every night. Remounted it and put it under water - no bubbles.
Any ideas?
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
PostPosted: Mon Jul 15, 2013 4:26 pm
You mean totally empty, not pressure drop?
PostPosted: Mon Jul 15, 2013 5:24 pm
Not totally empty, but almost. It´s not the usual latex tube air loss.
Spark 900 RC
There are no new unread posts for this topic. Attachment(s) Latex tube?
53cxzero
Mon Jan 08, 2018 1:58 pm
C36 View the latest post
There are no new unread posts for this topic. Patching latex inner tubes
alcatraz
20
1615
Mon Jul 24, 2017 9:39 pm
sanrensho View the latest post
There are no new unread posts for this topic. Groove between tire and rim - silicone or latex or ?
alcatraz
16
1802
Mon Jun 19, 2017 3:35 pm
cyclespeed View the latest post
There are no new unread posts for this topic. Rim tape for tubed/tubeless with latex/butyl
mpulsiv
28
1116
Fri Dec 15, 2017 10:52 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Latex tubes nowadays - best performance tubes for race clinchers
LouisN
28
2437
Fri Jan 19, 2018 1:40 am
LouisN View the latest post
Users browsing this forum: Bing [Bot], Gavin929, Google Adsense [Bot], kasperkls02, spartan, stormur, wingguy, Zakalwe and 35 guests
cron
