Post new topic Reply to topic  [ 51 posts ]
Go to page Previous  1, 2, 3, 4  Next
 Post subject: Sram Red 137g
PostPosted: Tue Nov 11, 2008 12:18 pm
I replaced the stock pulleys on my Red RD with Extralite, and it brought the weight down to 138g. After replacing the Ti cable clamping bolt with alu, it was 137g.
Ole.
 Post subject:
PostPosted: Tue Nov 11, 2008 12:55 pm
rward325 wrote:
It's a slow day at the office:
RD Carbon Fiber 120g $1149.90 $9.52 per gram
Red 153g $299.99 $1.60 per gram
Record 187g $279.99 $1.49 per gram
DA 180g $159.99 $0.89 per gram
I know there is a price to pay for weight savings and I can live with that. But I think I just found my limit.
Seen the date of the post... But surely rward325 logic is not correct. Taking ultegra as benchmark the $/gram saving would be:
Ultegra 210
RD Carbon 120 1149.9 $12.8
Red 153 299.99 $5.3
Record 187 279.99 $12.2
DA 180 159.99 $5.3
Interestingly DA & Red identical and Record as much as a rip off as Lightweight!!! :D
 Post subject:
PostPosted: Tue Nov 11, 2008 4:28 pm
Ultegra 210
Red 153 299.99 $5.3
DA 180 159.99 $5.3
Your logic is also flawed since you have to take into consideration the cost difference as well, not only the weight difference. If people gave out free Ultegra I'd be ok with that though.
Ultegra...............210......109.99
RD Carbon........-90......+1039.91........$11.55
Red..................-57......+190.00.........$3.33
Record..............-23......+170.............$7.39
DA...................-30.......+50..............$1.67
Being unable to use tab instead of a ton of spaces or in this case periods in these posts is quite frustrating...
 Post subject:
PostPosted: Tue Nov 11, 2008 5:20 pm
I haven't even touched the cable tension bolt yet. ~6-8 grams.
Red RD- ebay $220 (minus 25% cash back with live search)= $165
dark_albert pulleys and plate- $100= $265 for a 128 gram RD
Thats $2.01/gr compared to LWs $1039/gr
-Deacon Doctor Colorado Slim
 Post subject:
PostPosted: Tue Nov 11, 2008 5:22 pm
 Post subject:
PostPosted: Tue Nov 11, 2008 5:32 pm
shite thats good...
green jacket, gold jacket...who gives a sh*t
 Post subject:
PostPosted: Tue Nov 11, 2008 5:57 pm
Boonens 114gram Dura Ace rear: http://fairwheelbikes.com/forum/viewtop ... f=6&t=5718
Boonens 119gram Sram rear: http://fairwheelbikes.com/forum/viewtop ... f=6&t=5621
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
 Post subject:
PostPosted: Tue Nov 11, 2008 7:40 pm
Your logic is flawed because $/gram should be relative to the next cheaper/lighter option, not versus Ultegra. For example, given two derailleurs, one $10 more and 5 grams heavier, the second would be a terrible choice, even if relative to Ultegra it was a similar $/gram difference, because it's incremental $/gram is negative.
That said, relative to Red, the LW becomes $25.76/gram. Outrageous? I agree, but within a factor of two the number you get from the Trek Madone Black->Red series upgrade, which is popular. (Pez says there's a quality difference in this upgrade, as well, however)
 Post subject:
PostPosted: Tue Nov 11, 2008 7:58 pm
Principia wrote:
Very nice looking, maybe my Impulse need one :D
See My Bike & Tillquist's Kitchen !
A Power2max user..
 Post subject:
PostPosted: Tue Nov 11, 2008 8:47 pm
madcow wrote:
:shock: .... :lol:
 Post subject:
PostPosted: Wed Nov 12, 2008 12:45 am
I got 1 for my DA Gruppo about a year+ ago and the shifting is way
to sensitive. Needed to fine tune after every long ride. It looks
great but would prefer the great to come with effieciency also, its now
sitting in a box.
Apparently the new ones are Campy and Shm compatible now but I
don't think they'll work with DA 7900 or Campy 11 spd.
NA
 Post subject:
PostPosted: Wed Nov 12, 2008 12:51 am
I have to agree that I think the SRAM RED is the best for the money option if you can get one for just over $200 like I have done.
All I have done with my SRAM RED is put on a pair of Fibre-Lite pulleys and the weight went from 145g stock down to 131g but I also changed out the stock pinch bolt to a black anodized that was still a bit lighter.
I have to agree with Colo that if I can get the cable tension bolt sorted out that I could get this down to about 120 if I sorted this out and picked up a Dark Albert inner plate. I will see if Fibre-Lyte have a carbon outer plate for Red yet as I have some other parts on order from them.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5890g/12.98 lbs
 Post subject:
PostPosted: Wed Nov 12, 2008 1:00 am
Does anytong on here have a good suggestion on how to eliminate the rear derailleur cable tension bolt as Sram has made it a beast to tune. I have heard that you have to drill and tap it too a bigger bolt then you can drill and tap that to use a lighter aluminum bolt but is there a better way of doing this :?:
Cheers.
BIG DADDY B FLOW
 Post subject:
PostPosted: Wed Nov 12, 2008 1:41 am
sitting in a box.
Hey, what do you expect for 750 euros? Picky, picky. :roll:
 Post subject:
PostPosted: Wed Nov 12, 2008 8:28 am
tuned version from s.roth
http://www.light-bikes.de/website/new/2 ... t-rd-tuned
Dura Ace 7800 black ultralight - 107.3g! ;)
http://www.light-bikes.de/website/new/2 ... ultralight
Campa Record black 119.6g
Light- Bikes news for weightweenies | Light-Bikes on twitter
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: 604Yarks, FastTarik, rijndael and 46 guests
There are no new unread posts for this topic. Soda blasting carbon fibre
crispy
Sat Mar 09, 2013 1:20 am
stephen@fibre-lyte View the latest post
There are no new unread posts for this topic. Weight of Carbon Fibre M4x20 bolt?
prendrefeu
Wed Mar 27, 2013 4:28 am
Horacio View the latest post
There are no new unread posts for this topic. Soda blasting carbon fibre: will it work? Or not?
SWijland
Wed Aug 01, 2012 1:45 pm
SWijland View the latest post
There are no new unread posts for this topic. Attachment(s) What happened to my new sram red rear derailleur?
glowder
7
1191
Tue Dec 04, 2012 11:03 pm
SUCycling88 View the latest post
There are no new unread posts for this topic. Sram Red Rear Derailleur tuning
NiFTY
Sat Jul 28, 2012 1:18 pm
NiFTY View the latest post
It is currently Tue May 21, 2013 11:29 am
