It is currently Mon Mar 27, 2017 3:56 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Wed Sep 03, 2003 1:30 am
Does anyone know how stiff the power arms are? Stiffer then FSA cranks or Dura ace? Also Is the JIS interface very good. hows the stiffness compared to an ISIS or octalink interface? Also does it squek alot? Thank you.
 Post subject:
PostPosted: Wed Sep 03, 2003 9:21 am
They are plenty stiff enough compared to FSA carbon pro or Dura ace, if you are buildin a ridiculousy light bike sometimes it is hard to pinpoint stiffness as they seem to respond so much quicker. Word of warning though if you are going for Square taper, then just make sure about the taper of the cranks. I have Storks in Shimano bolt pattern but the taper is iso not jis. I tried it on a jis BB and it does not go far enough
 Post subject:
 Post subject:
PostPosted: Wed Sep 03, 2003 10:30 am
Site Admin
On what BB did you install them?
For the Power Arms Pro you need a 104 mm axle.
And AFAIK at 104 mm the ISO taper is compatible with the JIS taper.
So you can mount JIS cranks on 104 mm ISO BBs and ISO cranks on 104 mm JIS BBs.
 Post subject:
PostPosted: Wed Sep 03, 2003 12:38 pm
Thanks mate
You learn something new everyday :idea:
 Post subject:
PostPosted: Wed Sep 03, 2003 3:59 pm
So which bottom bracket and what type of taper should I go with? What do you guys ride? Thanks.
There are no new unread posts for this topic. Which GXP bottom bracket?
cnyn
Wed May 11, 2016 6:44 pm
topflightpro View the latest post
There are no new unread posts for this topic. Need help on bottom bracket
poppiholla
Tue Jul 05, 2016 9:38 pm
poppiholla View the latest post
There are no new unread posts for this topic. What bottom bracket do I have?
G6612
Thu May 05, 2016 8:58 pm
Calnago View the latest post
There are no new unread posts for this topic. C60 bottom bracket removal
markyboy
Sat Jul 16, 2016 6:56 am
ianSWBB View the latest post
There are no new unread posts for this topic. Colnago v1-r bottom bracket
pdiomidis
Sun Jul 10, 2016 3:01 pm
corky View the latest post
Users browsing this forum: cyclenutnz, mnmasotto, sd5500, Yahoo [Bot] and 34 guests
