Post new topic Reply to topic  [ 33 posts ]
Go to page Previous  1, 2, 3  Next
 Post subject: lol
PostPosted: Fri Sep 12, 2003 5:25 am
American Classic must be loving this free publicity...
 Post subject:
PostPosted: Fri Sep 12, 2003 4:38 pm
Just got my hands on a set of the CR350, actual weight is 530g front, 760g rear, so 1290g total. Pretty light stuff.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject: Things I like about...
PostPosted: Fri Sep 12, 2003 10:32 pm
American Classic is how their spokes are non proprietary... I haven't ridden a set of those Topolino wheels, but I imagine those spokes (an entire half) would be pricey to replace. AC is using DT Revos and Comp spokes, which are easy to obtain. And, of course the 350s are way lighter both in weight and damage to the wallet... I do like my set :)
 Post subject:
PostPosted: Sat Sep 13, 2003 2:11 am
does the rear rim of the new cr350 have off center drilling?
 Post subject:
PostPosted: Sat Sep 13, 2003 4:49 am
No. Both rims are standard.
 Post subject:
PostPosted: Wed Sep 17, 2003 4:08 pm
I have a set of the AM cr 350's...f-24 spokes; 551g, r-32 spokes;792 g. total set 1343 g!!! Very nice. these are the new 23mm rims. smooth, fast and light...
 Post subject:
I meant AC (american classic), not AM
 Post subject:
PostPosted: Wed Sep 17, 2003 4:43 pm
You have the new CR350 Set?
 Post subject:
PostPosted: Fri Sep 19, 2003 12:46 am
Check out these bad boys from FSA. First pic is sub 1400g clincher wheelset, next pic of new tubular carbon rims and new tri flange rear hub design.
 Post subject:
PostPosted: Fri Sep 19, 2003 10:32 pm
Tri-flange... what a marketing gimmick that is
 Post subject:
PostPosted: Fri Sep 19, 2003 11:56 pm
Not really, the tri flange design gives more even spoke tension on the load bearing hub.
 Post subject:
PostPosted: Sat Sep 20, 2003 1:15 am
and torque transfer???
 Post subject:
PostPosted: Sat Sep 20, 2003 1:23 am
Well yeah, thats the point of the equal spoke tension and transfer of power.
PostPosted: Sat Sep 20, 2003 5:41 am
---- posted from another forum in reference to the 3 flange wheel ---
Most hubs have too small a section diameter to transmit much torque to the non-drive side spokes. The wind-up of the hub prevents the NDS spokes from gaining enough tension to be effective. Hence the drive side spokes typically transfer almost all of the torque to the rim. Similarly, the flange in the center of the hub would have the same problem unless they made the hub diameter very large, which they didn't seem to do in this case. Granted, it would theoretically be able to deliver double the torque of the NDS flange, but double of close to nothing is still pretty close to nothing.
Edit... I just took another look at the hub pics and now realize that they are forcing the torque to the center flange by lacing the drive side (and NDS) radially. This negates any ability to transfer torque on the DS so all the torque is essentially driven by six spokes (only three pulling). Wow!
 Post subject:
PostPosted: Fri Sep 26, 2003 10:39 pm
HOLY CRAP!!! Just talked to my inside source today after reading a post by someone that a 300g magnesium clincher is comming out. IT'S TRUE!!! A 300g clincher is comming out from american classic, but unfortunatly it's only going to be a race day only product due to the corrosion of the magnesium on the brake track.
ALSO!!!! To complement the new mag rims, and all other current am classic road wheels NEW HUBS ARE COMMING!!! Front hub will weigh in at 61g, rear 183g!!! HOLY MOLY!!! 50g weight savings!! And a superior design and made by a more reputable manufacturor. These are gonna be sweet. The may or may not be at Interbike this year, but if the are not the will most likely be available next Spring! I can't wait!! A 1140g clincher wheelset, for race day, 1240g for everyday!! :P
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: fletch62, Google Adsense [Bot] and 30 guests
There are no new unread posts for this topic. Team GB's 'Secret Squirrel Club' bikes
Guyeclipse
Sat Oct 13, 2012 10:48 pm
stephen@fibre-lyte View the latest post
There are no new unread posts for this topic. Information about Moser bikes
Omiar
Wed Sep 26, 2012 8:33 pm
Omiar View the latest post
There are no new unread posts for this topic. SNG Brakes, more information? (Changed title)
Roeboe
19
1063
Sun Oct 28, 2012 8:09 am
Roeboe View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) Ciamillo carbon crank now with pre-launch offer information!
[ Go to page: 1 ... 11, 12, 13 ]
Getter
192
20242
Fri Dec 07, 2012 8:46 am
Frankie - B View the latest post
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
It is currently Sat May 25, 2013 6:12 am
