It is currently Wed Feb 22, 2017 8:52 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Thu Nov 11, 2004 3:24 am
I have a reynolds stratus (tubular) front wheel and the rim is 20.5 mm wide. This is a race only wheel for sprinting on smooth crit courses. I am debating what would be a better tire the tufu <160 road tire which is 20mm wide or the tufo <120 track tire which is 18 mm wide. My question is primarily an aero dynamics question for the 'experts' out there but would the 18 mm tire actually have worse aerodynamics on a 20.5mm rim than the 20 mm? Secondly, any thoughts on other issues with these tires?
Thanks
El Mahone
PostPosted: Thu Nov 11, 2004 3:33 am
Thanks
The 160g Tufo you can use on smooth roads the 120g is a track tire. A light tire will not do you any good if you puncture and are standing beside the road. :roll: If you are a racer pick durability and strength over light weight. Check out this thread on the rolling resistance of different tires. http://weightweenies.starbike.com/forum/viewtopic.php?t=2549&highlight=tufo
Cheers,
:lol:
"Ride lots." -- Eddy Merckx
Click Here to see my Scott CR1.
 Post subject:
PostPosted: Thu Nov 11, 2004 5:14 am
Have you been at the Zipp website? They talk about tires and rims having a smooth transition so they are slipperier. The 20 mm should cover the rim a bit more but you would have to call it.
If you haven't already, the zipp website does talk about this.
There are no new unread posts for this topic. Tire Size reccommendation
bobbyfox66
Tue Feb 21, 2017 8:06 am
kgt View the latest post
There are no new unread posts for this topic. Wider is better? 23mm tire on 21c rim vs. 25mm tire on 15c rim
Beaver
Fri Jul 01, 2016 9:46 pm
crimsonbadger View the latest post
There are no new unread posts for this topic. Tire woes
Raccooningtanuki
Fri Nov 04, 2016 7:41 pm
Raccooningtanuki View the latest post
There are no new unread posts for this topic. Please Help With Tire and Wheel Questions
Scrench
Mon Aug 08, 2016 12:26 am
Scrench View the latest post
There are no new unread posts for this topic. Tire wear indicator
mvcap
Sat Feb 18, 2017 8:41 pm
Miller View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], crn, Frankie - B, ghisallo2003, glam2deaf, gsindela, ooo, prototoast, Sizzler, topflightpro, UpFromOne and 39 guests
