Campy Record Rear Deraileur Tuning
Superlite
by Superlite
Hey guys,
I want to redude the weight of my 05 Record RD. ANy ideas?
Also, does anyone out there know all the bolt sizes on it? Pully bolts, limit screws, etc?
Thanks
BTW
My Record FD weighs 53g!!!!!!! :twisted:
Samu Ilonen
by Samu Ilonen
Pulley bolts are M5X? but they are ti. Limit screws are M3 and steel. Back plate from CF would be vice choice.
What you changed on front der?
520 Dan
by 520 Dan
Finally saw the light and went to campy huh Superlite?
popawheelie
by popawheelie
The alu limit screws from a DA derraileur will fit in it. SRP has alu pulley bolts. The cable bolt could be alu? Pull all the steel pivots out of it and replace with Ti. The springs could be made out Ti.
zoey
by zoey
popawheelie wrote:The alu limit screws from a DA derraileur will fit in it. SRP has alu pulley bolts. The cable bolt could be alu? Pull all the steel pivots out of it and replace with Ti. The springs could be made out Ti.
Works fine for me to.
Cheers,
:lol:
"Ride lots." -- Eddy Merckx
Click Here to see my Scott CR1.
Superlite
by Superlite
Zoey,
Check you private messages
Enda
by Enda
I got my record RD modified by Poshbikes (Kent England; www.poshbikes.com) last year. All the nuts & bolts were changed and the rear aluminium plate was replaced with carbon. Not sure about warrenty but I've had no problems thus far.
Tippster
by Tippster
My DA7800 rear mech weighs only 168g.
Tuned with:
SRP kit - Ti Pivot bolt / Al pulley wheel bolts
Alu Cable bolt
removed the barrell adjuster - already have adjusters on my XT mtb shifters.
Before modifications it came in at an honest 180g (after 1g of grease was removed - the green stuff Shimano put to much of on)
Does the campagnolo 10 speed rear mech function better than the DA7800?
Is the Campag tunable to a lower weight that the DA7800?
Is the Camag more durable?
Just wondering what the benefits were Vs Shimano.
"Ride it like you've just stolen it!"
Tippster
by Tippster
You may also want to consider getting some cheap pulley wheels and drilling them. 2mm or 3mm drill bit and either single holes or 2 holes joined. The pulley wheels are surprisingly strong.
Deore or 105 pulley wheels should be cheap to pick-up and practice on.
Lot of effort for approx 5g saved.
:wink: Puts you in the "ultimate ww" section of odd-balls too :wink:
