It is currently Tue Jan 23, 2018 1:34 am
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Sat Nov 06, 2004 5:30 pm
Is it possible to tilt the saddle down in front with this type of clamping mechanism?
 Post subject:
PostPosted: Sat Nov 06, 2004 7:37 pm
2 q's:
-why?
-why not?
Samu @ www.signature.fi
 Post subject:
 Post subject:
PostPosted: Sat Nov 06, 2004 7:56 pm
yes it is, I have had a post with the same meganism.
 Post subject:
PostPosted: Sat Nov 06, 2004 7:58 pm
If you loosen the front screw and tighten the back screw, it'll tilt the saddle backward.
And if you loosen the back screw and tighten the front screw it'll tilt forward as you asked.
Simple system really.
Principia MSLe Pro 9543g
If you accidently had to, could your bike take a smaller downhill ?
 Post subject:
PostPosted: Sat Nov 06, 2004 8:18 pm
will the saddle point down?
 Post subject:
PostPosted: Sat Nov 06, 2004 8:23 pm
if you tighten the front scew you will see the point of the saddle going down. Loosening the rear screw at the same time will prevent excessive stress on the saddlerails. The adjustment of "point of saddle up and down" are pretty acurate with this type of seatpost.
Good luck.
 Post subject:
PostPosted: Sat Nov 06, 2004 8:59 pm
FORGET IT!
 Post subject:
PostPosted: Sat Nov 06, 2004 9:27 pm
erty65 wrote:
FORGET IT!
What don't you understand?
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Sat Nov 06, 2004 10:17 pm
if i got him right, he didn't want to know if the saddle can be adjusted either this or that way BUT if you can adjust the saddle (the clamp) that far the saddle wouldn't be horizontal but to make the nose "point down" a little...
i can just talk for the tune-clamp which is not absolutely equall but quite similar - the "adjustment-range" is veeeery small and in fact there's only one optimal position - horizontal rails. for the schmolke it seems to be different as the two pieces which hold the saddle-rails are round thus allowing more travel without harming the rails (as the sharp-edged tune-clamp would do if the saddle was too steep in one direction)
*edit*
correction - the schmolke actually has the same clamping-type as the tune. nearly no adjustment-travel here without "marking" the rails (i messed it up with the ax-post, which uses a friendlier version of this clamp)
 Post subject:
There are no new unread posts for this topic. Best carbon seatpost for a 2016 Evo?
chadm
Sun Jul 23, 2017 2:31 am
chadm View the latest post
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. tightening asian carbon seatpost clamp
nrsnow
Mon Apr 10, 2017 7:26 pm
stockae92 View the latest post
There are no new unread posts for this topic. seatpost for bontrager 7x10 carbon rails
hoojammyflip
Fri Feb 17, 2017 4:59 am
nickf View the latest post
There are no new unread posts for this topic. Galvanic Corrosion on Aluminum Insert with Carbon Seatpost
RyanH
18
1546
Fri Jun 16, 2017 10:06 pm
Calnago View the latest post
Users browsing this forum: Hexsense, joejack951, Majestic-12 [Bot], stormur and 33 guests
