It is currently Mon Jan 22, 2018 1:45 am
Post new topic  Reply to topic  [ 1578 posts ]  Go to page Previous 165 66 67 68 69106 Next
 Post subject: Re: Bont shoes
PostPosted: Mon Aug 12, 2013 8:07 pm
stax wrote:
Liggero wrote:
Any news about the new bont riot shoes availability?¿?¿
Riot and BOA closure Vaypors now at Sigma Sport. Sorry, I can't post a link from my phone as i am technologically inept.
Just ordered Riots to replace my Sidi Zetas, I'll keep you all posted.
If I don't like them, they're going back for Giro Trans.
PostPosted: Mon Aug 12, 2013 8:31 pm
nfecyle wrote:
Thanks for the response.
I did make sure that there is no speedplay base plate bolt sticking out of nut. Also is it necessary to cover the nut inside the shoe? Upon observation, it is indeed that the original bont insole is very thin compared with my lake shoe. Moving my lake shoe insole into my bont seems to help. I purchased specialized blue insole today to see if it helps to alleviate the problem.
It should.
I immediatly ditched my original Bont insoles, and used my Specialiuzed (red) ones instead, and evrything was super after. I had to cut a small portion of the Spesh soles to fit the Bont ones.
I switched my soles with Pearl izumi Pro 1:1 soles this year. Very nice and comfy, close to the Spesh BG reds.
I'm in my 3rd year with my A-1's, and I really like them now. I got used to how to adjust the fastening.
At first, I was tightening them too much, like a "usual" shoe, and got numb feet. When I loossened them, my feet moved a little too much (1-2 mm is too much) and hit the carbon "tub walls", and it was worst. Now I tighten them just enough so my feet don't "rock", and I can ride for hours without problems.
Louis :)
PostPosted: Fri Sep 20, 2013 5:43 pm
I just received my Bont Zeros and came here for tips on molding them. Well after reading through 67 pages of posts, I have to say, this is without a doubt the single best resource out there for these shoes! Great info!
My Zeros seem to fit me pretty darn well right out of the box and I imagine will only get better after heat molding. So at the moment, I don't see any issues there. I will proceed to molding tonight and over the weekend.
Before I do that, however, I took some new KEO cleats and test-fitted them on the Zero's soles and they don't sit flush at all. I think there is a good chance that I will experience "rocking" when really pushing the pedals.
I know a few folks have talked about shimming the cleats in order to get a more secure interface between a KEO cleat and the Bont sole - does anyone have any photos of this so I can see how you did it? Thanks!
EVO Hi-Mod | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 3/5
P5 | 9070 Di2 | Rotor 2Inpower | Aeolus TLR 7
T1 | Power2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
SuperX Hi-Mod Disc | Sram Red | Power2Max NG
PostPosted: Sat Sep 21, 2013 1:04 am
Cut a strip of plastic about a half inch wide or less. Fit it under the cleat between the bolt holes. Tune to taste. I used some ABS I had... think it was .040" thick. That was for Shimano cleats.
formerly rruff...
PostPosted: Sun Sep 22, 2013 4:33 am
when I rode my bonts and had to use old Look Delta pedals for a while I put several small strips of rubbery-ish (lizzardskins) bar tape between the cleat and the sole and it worked beautifully.
PostPosted: Sun Sep 22, 2013 7:17 pm
I'll buy a pair of A-three
any idea on how to colour in White the blue lines on the straps?
PostPosted: Tue Sep 24, 2013 1:27 pm
Modifying the insoles:
In case anyone is interested, I used some cushioned handlebar tape to customize the arch support. It's light and does the job. The kind with an adhesive strip makes it easier. Once you get it right you can use goo to attach it permanently.
formerly rruff...
PostPosted: Sun Oct 06, 2013 12:53 pm
So how malleable should the heel area become after heating Bont's up? I've got the new Vaypor+ and heat moulded them twice tonight. Everything feels fine except my heel which is slipping up in both shoes. I applied pressure to the area during the cool down phase but wondering if I got them hot enough to start with to actually mould properly. The carbon tub around the heel didn't seem to have much give at all even straight out of the oven.
Thanks in advance to anyone that can give some advice.
PostPosted: Mon Oct 07, 2013 12:41 am
^ Cook them up for every minute of the recommendation. Really get them warm through and through. I don't recall feeling the carbon moving during the fitting, but they clearly had taken the molding change once they cooled.
My orig-gen Vaypors have developed an annoying squeak after 3 solid years of happy riding - both right and left. I really have to tighten up the ratchet straps now - no more fast and loose for me. They're still 100% functional 100% good looking, of course. Anyone else have this happen?
I want to get another pair of Vaypors (with ratchet - the dial versions look horrible with the giant dials), but am tempted to try a pair of Spesh's S-Works for no other reason than plain old wanting to try something else.
5.7kg / 12.7lbs Addict SL w/PowerTap
9.3kg / 20.5lbs Scale 29 Pro ... woefully under-used
Retired: 5.9kg / 13lbs Addict R1 w/PowerTap ... lowest was 5.593kg / 12.33lbs
PostPosted: Mon Oct 07, 2013 4:30 am
I'm surprised your heels are slipping. Mine literally"pop" out when I take my Vaypors off. Get a good oven thermometer and cook 'em right up to the limit. They should be too hot to hold when you first take them out and my shoes felt a little bit soft. Get them on immediately and really form that heel cup around your heel with your hand. Then make sure you let the shoes cool on your feet but don't go walking around in them! Stand in them on a firm surface even going one foot at a time. I only had to heat mine twice to get a really great fit using Superfeet blue insoles. Good luck.
Sent from my GT-P5113 using Tapatalk 4
PostPosted: Mon Oct 07, 2013 6:28 am
If the heels are the only area in question, just use a hairdryer to heat just that area. That's how I sorted mine out.
And I share the same experience as Twiggy. My heels literally 'pop' out when I take them off.
PostPosted: Wed Oct 09, 2013 3:31 pm
Hi Guys, 1st post for me so if I break any of the generally accepted protocols of forum posting it is unintentional! Honest...
Ok, I am considering some Bont Vapor's as I have had trouble with hot spots after about 40 miles with my Shimnao size 48's in wide fitting regardless of using Look style or spd cleats, the 40 mile mark shortend drastically with regaulr riding so I have ended up on flat pedals and trainers......
I alas have bunions which make my feet 120mm wide at the base of each big toe, however they are 282 mm long which Bont sized up as being a 46. But the 46 in wide fitting is too narrow (111mm).
I have 2 issues as a result. Do you think I would be able to stretch a size 49 (UK13) which in wide fitting has a width of 117mm, the extra 3mm to accomdate my feet around the base of my big toes?
If so the 49's are 30mm (3cm) longer tham my feet, would this potentially cause me a whole different set of problems?
I am seeing a podiatrist in the next few weeks and may be able to get specially built insoles, but I am hoping the flexibility of the Bont's heat molding may allow me to have pain free feet.
Bont themselves wanted £600 for a custom set which I cant afford.
Any help would be much appreaciated.
PostPosted: Wed Oct 09, 2013 4:28 pm
You can probably make room for your bunion by spot heating with a hair dryer and pushing that area out with a rounded hard object. No guarantee though.
Also, you will need more length than Bont suggests if your middle toes are longer than normal. Since their cleat holes are more rearward than most (at least they were) it might be a good idea to size up a little anyway.
formerly rruff...
PostPosted: Wed Oct 09, 2013 5:08 pm
I'm really confused by Bonts sizing. After measuring my feet 3 times I got a length of 261mm. Going by their guide I should have bought size 42,but a cheap pair of 42.5 came up so I bought them to try.
First try on of the shoes my big toe was right up against the end of the shoe. In theory I should have had 7mm of space! I tried them on a 1 hour ride and they were just plain uncomfortable. My toes were numb at the end of the hour. Not good. I'm now selling them on as I doubt they'd be big enough even after molding.
Has everyone else had better results going by the size guide?
PostPosted: Wed Oct 09, 2013 6:56 pm
Did the size guide carefully and came up with a 44 shoe. Thought that was small so ordered a 44.5 based on that and the sellers advice. Shoes ended up just barely long enough which I didn't like so I got some 45's which are perfect for me. I also wear a 45 in Sidi, Carnac, and Time shoes for reference. My experience says take the size wizard result and add one full size.
Sent from my Galaxy Nexus using Tapatalk 4
There are no new unread posts for this topic. Bont Vaypor+ and Look Keo issues
girona
Mon Jun 19, 2017 7:24 pm
TwiggyTN View the latest post
There are no new unread posts for this topic. Attachment(s) Looking for Lake CX237, CX332, Bont Vaypor +, S-Works S6 owners
Rone69
29
2880
Thu Jan 04, 2018 9:49 am
KCookie View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
2014
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. D2 vs Rocket7 shoes
Master-Ti
14
1643
Sun Feb 12, 2017 4:46 am
Master-Ti View the latest post
There are no new unread posts for this topic. Bike Shoes
nycjwi
14
1573
Tue Apr 18, 2017 10:09 pm
hambini View the latest post
Users browsing this forum: dricked, nismosr, pdlpsher1, sbkidd and 33 guests
