It is currently Wed Oct 18, 2017 1:52 am
Post new topic  Reply to topic  [ 1567 posts ]  Go to page Previous 164 65 66 67 68105 Next
 Post subject: Re: Bont shoes
PostPosted: Tue Aug 06, 2013 4:55 am
So I get the 43s and they are way too small. Get the 44.5s and they are much larger... probably too big. Depends on if I can shrink them a little.
I happen to take the insoles out and notice that the 44.5 has "10.5" written on the shoe. That's cool... must be the US size. I take the 43's insole out and it says "8"... but it should be a 9 right? Because that is the size that corresponds to size 43. I can totally believe it is an 8 (or 42), because it is tiny. Was there a screw up somewhere?
formerly rruff...
PostPosted: Tue Aug 06, 2013 4:02 pm
My 42.5 bonts say 8.5 in them. :noidea: For me they fit like most other 42.5 shoes. Sounds like there may have been a mix up with the "43".
PostPosted: Wed Aug 07, 2013 1:31 am
Thanks... looks like a mix up at the factory most likely. I've now paid for shipping on a 42 and a 44.5 and I still don't know if a 43 or a 44 would fit best. Safest bet would be a 43.5 but they don't make one.
Anyone have an opinion on whether stretching or shrinking is likely to be most successful?
formerly rruff...
 Post subject: Smelly Bont shoes
PostPosted: Wed Aug 07, 2013 3:42 am
so few weeks ago got caught in a rain and got my self and shoes all wet, since then the shoes stink, maybe i should have dried them in a drier by hanging, instead i let them air dry, now they stink!!!
any advice on how to fix that, thanks
 Post subject: Re: Smelly Bont shoes
PostPosted: Wed Aug 07, 2013 3:45 am
Just ask Grandma! http://www.grans-remedies.co.nz/
I can vouch for its effectiveness.
Less is more.
PostPosted: Wed Aug 07, 2013 6:06 am
OT, but if shoes get wet pack them with crumpled newspaper. It pulls the moisture out and drys them much faster.
PostPosted: Wed Aug 07, 2013 2:25 pm
Rice works too although it takes a bunch and newspaper is cheaper....plus you really shouldn't eat the newspaper if your not drying with it
Looks like I made a new 90 Proof friend
PostPosted: Thu Aug 08, 2013 12:07 am
coloclimber wrote:
A good soaking in a long rain ride did more for my Bont's fitting well than the 2nd and 3rd heat moldings.
Yep.
I mentioned the same, pages back :beerchug: Especially for the heel counter.
The Gram
The Men of Steel
PostPosted: Fri Aug 09, 2013 5:34 pm
Another question...
I'm wondering about the top strap vs buckle on the A3. The strap doesn't cinch so it doesn't appear that it would do much... yet I haven't heard many complaints about it. In the beginning a lot of the A1s were sold that way also. Many in this thread mention that the straps don't need to be tight, in which case the strap is probably adequate. The buckle is nice in theory but there are complaints about it as well.
So... strap or buckle?
formerly rruff...
PostPosted: Fri Aug 09, 2013 6:15 pm
:oops: I never saw this thread before
Got a pair of Bont Vapor limited editions yesterday (white but with black strap and over closure). I thought I'd try them out, much as I love Italian brands they are always too narrow around the toes and only fit me once they've stretched. I always have to wear at least 1-2 sizes bigger than I should have to.
Did the Bont measurement thing a few times to double check, went up a size from their recommendation (BONT recommends a 41 Euro, I bought a 42). Still a full size smaller than a Sidi.
Boy are these things tight to get on, but they feel like they could be good. Can't heat mold them until tomorrow as I don't have an electric oven, need to use a relatives.
My only concern is the height of the toebox, I'm hoping with some gauze and tape I can stretch that a little otherwise I'm going to wear down my toe knuckles. A couple of other places will need a little work, couple of plasters should do it.
Other thoughts, Bonts look a little umm...homemade. I like the idea of the big area on the sole for the cleat, instead of overhanging cleat. Having to put washers on my bolts for now to shorten them which is a bit poor. They should really supply extra short bolts and a user guide with the shoes, yet Bont go to the trouble of providing a shoe bag. I like the the lack of vents everywhere, should be easy to keep clean - useful here in the UK.
PostPosted: Sun Aug 11, 2013 7:49 pm
Hi guys,
I bought a pair of A2, heat molded them , and have been using them for couple weeks now. While the overall shoes are perfect for me and love them, there is this one hot spot that I could not get rid of. Its on the ball of my left foot, where the cleat placed located below. Will remolding it help ? or maybe buy other insoles ? any advice is appreciated. I use speed play pedal system.
PostPosted: Mon Aug 12, 2013 2:42 am
Likely an issue of the insole being too thin ( the original Bont ones are very thin) or that the cleat bolts are slightly peeking out.
PostPosted: Mon Aug 12, 2013 3:06 am
I used to have an issue with the standard Look bolts poking thru the thin carbon sole and switched out to Shimano ones which solved that.
Speedplay come with two different length screws, so make sure you're using the black (shorter) ones..
KWalker wrote:
chill out perv dogs, homegirl is still only 17.
PostPosted: Mon Aug 12, 2013 4:20 am
Thanks for the response.
I did make sure that there is no speedplay base plate bolt sticking out of nut. Also is it necessary to cover the nut inside the shoe? Upon observation, it is indeed that the original bont insole is very thin compared with my lake shoe. Moving my lake shoe insole into my bont seems to help. I purchased specialized blue insole today to see if it helps to alleviate the problem.
PostPosted: Mon Aug 12, 2013 6:06 pm
nfecyle wrote:
Hi guys,
Heat molding will not help. The molding doesn't reshape the bottom of the shoe. If it did, it would throw the cleat hole alignment out, etc. The sole is fixed.
I could never get used to the tub shape sole on mine, and the volume of the shoe is too shallow to fit in any meaningful size insole IMHO.
I know at about 10 local riders who tried Bonts, none are still using them. I know, small sample size, but still.....most of these guys use their shoes for 2+ seasons. The Bont's were ditched within a few months...
There are no new unread posts for this topic. Bont Vaypor+ and Look Keo issues
girona
Mon Jun 19, 2017 7:24 pm
TwiggyTN View the latest post
There are no new unread posts for this topic. Attachment(s) Looking for Lake CX237, CX332, Bont Vaypor +, S-Works S6 owners
Rone69
21
1389
Tue Oct 03, 2017 8:14 pm
Rudi View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
1698
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. New Lake CX 301 WW Shoes
Ozrider
13
3017
Fri Jun 16, 2017 8:15 am
benzebub View the latest post
There are no new unread posts for this topic. Fizik R3B shoes
liam7020
Mon Apr 17, 2017 12:58 pm
liam7020 View the latest post
Users browsing this forum: alorast, Bing [Bot], Samklee15 and 33 guests
