It is currently Sun Jan 21, 2018 11:56 am
Post new topic  Reply to topic  [ 1578 posts ]  Go to page Previous 159 60 61 62 63106 Next
 Post subject: Re: Bont shoes
PostPosted: Mon Apr 29, 2013 3:37 am
I don't see what you being an 11 in other shoes has to do with your Bont size? Their website is pretty clear that if your foot is 268mm long you should be looking at a size 8.5. Your size in other brands is irrelevant. No reason to believe that sizes should match across brands.
FWIW you may want to go up half a size to have some extra room for the sock. That seems to work well for people in general.
PostPosted: Mon Apr 29, 2013 6:16 am
+1
I followed the instructions on Bont's website, according to their chart, and using my measurements, I was an EU 45, no dramas - fit great, even pre-molding.
FWIW, I'm also a 45 in S-Works and Northwave, but I would use Bont's specific chart before just assuming anything.
KWalker wrote:
chill out perv dogs, homegirl is still only 17.
PostPosted: Tue Apr 30, 2013 3:40 am
So my shoe fits way better now. I baked it @ 190F for 20 mins and made shims out of cardboard and taped it on my foot where I get hotspots and wore 1 thin sock and 1 thick sock. I think I could've gone without the 1 thin sock but I put the shoes on after a minute of taking it out the oven so I needed the extra layer to protect my skin
now I have a stack height problem with my Speedplays :x
and unfortunately it cannot be solved by lowering my saddle as I'm already at the max. I need to find a way of increasing the stack height by 5mm (or whatever the usual difference is for Sidi vs Bont). Speedplay sells wedges and shim for leg discrepancy, but they'll just make my shoe too costly instead.
I'm thinking of using plastic sheets, trace and then stack them. I don't know if they'll work but they won't add much weight.
:noidea: grr.
PostPosted: Tue Apr 30, 2013 3:58 am
What a problem to have! I can think of 2 ways but neither may be of help to you: shorter cranks and/or thicker insoles.
Less is more.
PostPosted: Tue Apr 30, 2013 4:17 am
I was about to edit my post and ask what influences stack height and if the insoles are also a "part" of it.
I was using my orthotics with my Sidis and I'm estimating it's about 2mm in thickness. I can probably wear insoles since I have much more space now post-bake but let's see.
As for a shorter crank - yes I thought about it and it's actually a possibility since I'm buying a whole new groupset next year, but I'm not sure on how hideous a Shimano crank would look with SRAM groupset, lol. Ugly? I don't know, but I don't really want to resort to that.
PostPosted: Tue Apr 30, 2013 4:42 am
Frame = too big ?!
PostPosted: Tue Apr 30, 2013 5:11 am
Whatever in between where you're seated to the axis of the pedals counts. Transferring what you were wearing (othortics) to your new Bonts won't increase your stack though. Sram makes all the in-between crank lengths, otherwise don't look down on the ShimaNO cranks but heads-up :up: straight ahead!!
I'm in the not-hung-up-about-mixing-brands camp. At the moment I have all Campag mixed with ShimaNO cranks/O,s rings and Planet X brakes. Time heals every wound, it doesn't look bad anymore :lol:
I went from 170 to 165 and didn't feel that I had made quantum leaps in my pedaling but reaped the bonus of increasing seat to handlebars drop - hey 2+ more aero :thumbup: .
Less is more.
PostPosted: Tue Apr 30, 2013 7:01 am
I'm using a 167 crank now and don't mind going 165 which Shimano does carry. I could really go down this option now since I'll be using that for next year but I really want to save as much money at the moment.
I think I'll be buying wedges and stack about 5-7mm of it. That's still less than a cm and an eye sore I won't be seeing. I'll try to cut out the shape of the adapter while I wait for those wedges to come in. UGHHHHHHH.
{USERNAME} wrote:
Frame = too big ?!
I wouldn't say my frame's too big. I have a 7-10cm saddle to bar drop while have 2 spacers (I honestly could take out one more since I'm more flexible now), don't have to seats pushed too forward and run a 90cm stem.
just frustrated now.
PostPosted: Tue Apr 30, 2013 3:31 pm
You could always trim the bottom of your seatpost by 4-5mm... If it's metal this shouldn't be a problem at all, if it's carbon you most likely can get away with it just fine if you saw through it very gently ala fork steerer tube. I dont think this would really compromise any structural integrity but just in case... probably best to not do it if you're a very heavy person.
It pains me to see you want to increase your stack height though. Half the Bont experience is being right on top of the pedal!
PostPosted: Tue Apr 30, 2013 5:01 pm
I thought about that too. I'm @ 150lbs atm and don't blow up past 160lbs during winter.
Yes and I agree about the "Bont" experience. When I get my -5mm cranks next year I should be able to attain that.
I'll post pics later on what I can come up with. I'm estimating I really need about 5-7mm of stack.
PostPosted: Tue Apr 30, 2013 5:45 pm
This.
Adding stack height is the wrong way to go.
Shortening cranks is also the wrong way to go.
...but its not my bike...
M
PostPosted: Tue Apr 30, 2013 7:10 pm
I have to agree with gummee. Changing crank length is not the way to go.
What kind of seat post do you have? 150lbs is nothing to a post designed to function with a 200lb+ load. I say chop that bitch up.
PostPosted: Sun May 05, 2013 8:23 pm
Gave in. Chopped 2 cm for good measure.
I still left that 2mm of shim but I noticed the huge improvement from my shoes before (+ orthotics). I may need to re-bake them again but otherwise I'm a happy camper :beerchug:
PostPosted: Mon May 06, 2013 1:35 pm
I am having difficulty flattening the arch. Any ideas, I am about to get the hairdryer out :D
PostPosted: Mon May 06, 2013 2:46 pm
FWIW
My experience:
Bought a pair on sale from Excel, the "Thor" model on close-out.
Fit was spot on, I wear 45 Sidis and went for same with Bont.
They do mold fairly well and easily (my feet have no odd shapes so was straight forward).
They are very light and quite stiff.
Wonderful heel cup that wraps nicely around this narrow heel of mine.
Had some major issues with numbness, hot spots etc. Resolved this entirely when I replaced the thin flimsy inserts of bonts with my "blue" Specialized orthos - feet are happy as clams.
Now if I could only get that right iCliic pedal to stop squeaking when I put the power down...
It only hurts if you think.
There are no new unread posts for this topic. Bont Vaypor+ and Look Keo issues
girona
Mon Jun 19, 2017 7:24 pm
TwiggyTN View the latest post
There are no new unread posts for this topic. Attachment(s) Looking for Lake CX237, CX332, Bont Vaypor +, S-Works S6 owners
Rone69
29
2874
Thu Jan 04, 2018 9:49 am
KCookie View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
2012
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. D2 vs Rocket7 shoes
Master-Ti
14
1641
Sun Feb 12, 2017 4:46 am
Master-Ti View the latest post
There are no new unread posts for this topic. Bike Shoes
nycjwi
14
1573
Tue Apr 18, 2017 10:09 pm
hambini View the latest post
Users browsing this forum: Bogan, Francois_Viviers, nickl, themidge and 38 guests
