It is currently Sun Jun 25, 2017 1:43 am
Post new topic  Reply to topic  [ 1553 posts ]  Go to page Previous 173 74 75 76 77104 Next
 Post subject: Re: Bont shoes
PostPosted: Sun Apr 13, 2014 12:50 pm
Thanks for the photos shillc. Looks like I can't swap out the ATOPs easily for BOA. The part sewn into the shoe is different which I guess you would expect from the different brands. Oh well :(
PostPosted: Mon May 19, 2014 4:20 am
Bont shoes are now available at Competitive Cyclist. They have a really good return policy too.
http://www.competitivecyclist.com/Store ... q=bont&s=u
PostPosted: Mon May 19, 2014 5:01 am
Performance started listing them this month as well.
 Post subject: Bont shoes
PostPosted: Mon May 19, 2014 5:29 am
I have heard Bont has swapped to Boa, will look for the info.
Ozrider - Western Australia
PostPosted: Mon May 19, 2014 7:44 am
hello
i had A2 shoes since 1 years and i buyed vaypor last wekk in the same size but the left shoes is shorter than A2
size is differents ?
PostPosted: Mon May 19, 2014 4:11 pm
Cool! If only Competitive Cyclist or Performance carried wide version they would get my money.
PostPosted: Thu May 29, 2014 2:48 am
So i have an issue with my bont Vaypor+. The "wire" on the upper ATOP dial came loose/disconnected. I see i need to remove the allen key holding the dial on, however my smallest 1.5mm hex wrench does not fit into the head of the bolt. Is the bolt a different size? Has anyone else had this problem?is it a simple fix?
I NEED to have it fixed by saturday as my state championship race is on sunday. terrible timing, just my luck
The New: BH http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=117760
The Old: Trek http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=110051
PostPosted: Thu May 29, 2014 8:43 am
Check the service page here http://www.atop-team.com/service.php?id=4.
Specifies use a torque wrench. I suspect but I can't tell if it's a star drive (Boa is).
PostPosted: Thu May 29, 2014 5:29 pm
Are the listed Bont weights reasonably true? Specifically I am looking at the Bont Vaypor listed as 240gr for size 42.
I will be returning a pair of Giro Factor's that Giro claims weigh 240gr, while the real world weight is 290gr...
(2012/2014) Scott Addict R1, SRAM Red 6.6kg | 2012 Scott Scale Pro, SRAM X0, 9.4kg
PostPosted: Thu May 29, 2014 7:16 pm
So my size is 275mm L, 114mm W
On Bont's website it says..."contact us for custom size"????
Hmmm..used the online store tool, it works...I guess maybe it is broke on the other portion..haha
PostPosted: Thu May 29, 2014 7:23 pm
I'm guessing you may need wide shoes. I measured at 263/100 and their recommendation of 42.5 was spot on. Contact them, see what they say.
"Deserve's got nothing to do with it." William Munny
PostPosted: Thu May 29, 2014 7:25 pm
What size shoe do you normally use? Do you take an extra wide in other shoes?
In my case Bont said I needed a 42.5W and I ended up with a 44.5 standard that fits.
formerly rruff...
PostPosted: Thu May 29, 2014 7:32 pm
Not to change the subject, but has anyone else noticed they can't place the cleats far enough forward? I have them maxed out, but it's still putting the cleat farther under my foot than my previous shoes. I haven't put any miles on them yet, mostly because I'm in the middle of some targeted events, but plan on giving them a go in a few weeks.
PostPosted: Thu May 29, 2014 8:31 pm
Make sure you pick a shoe that comes in wide on the fitting wizard. 275mm x 114mm is a 10.5 wide US/44.5 Wide Euro
For what its worth at 275mm long the following are the widths:
92 and smaller = Contact us for custom size
93-97 = Narrow
98-109 = Standard
110-114 = Wide
115-119 = Double width
120+ = contact us for custom size
Anyone heard of the double width before???
PostPosted: Thu May 29, 2014 8:53 pm
I had a similar problem but more related to feeling the cleats with a wider Q factor than other shoes with same cleat brand.
I even spoke directly to Bont guys at Eurobike but they said it was a first time for them.
My current ride
There are no new unread posts for this topic. Bont Vapor Plus vs Bont Bltiz?????
upside
Tue Jul 19, 2016 1:42 pm
wingguy View the latest post
There are no new unread posts for this topic. Bont Vaypor+ and Look Keo issues
girona
Mon Jun 19, 2017 7:24 pm
TwiggyTN View the latest post
There are no new unread posts for this topic. Shoes, shoes, not all of them created equal
vejnemojnen
13
1305
Wed Apr 19, 2017 11:57 am
Junior7 View the latest post
There are no new unread posts for this topic. Fizik R3B shoes
liam7020
Mon Apr 17, 2017 12:58 pm
liam7020 View the latest post
There are no new unread posts for this topic. D2 vs Rocket7 shoes
Master-Ti
14
1110
Sun Feb 12, 2017 4:46 am
Master-Ti View the latest post
Users browsing this forum: 3delis, Baidu [Spider], Bing [Bot], Google [Bot], raggi, scottgps, SuperDave, Tmk and 40 guests
