It is currently Fri Jan 19, 2018 6:54 pm
 Post subject: Zero Gravity setup.
PostPosted: Sat Nov 06, 2004 12:13 am
I just got a pair of zero g´s. I can´t get them set up properly. The cables slip out of the holders if I brake. What am i doing wrong???
 Post subject:
PostPosted: Sat Nov 06, 2004 3:06 am
The cable runs on the inside (toward the center of the brake) of the bolt. You will see a small cutout for the cable. The cable is clamped by the washer and screw to this cutout.
 Post subject:
PostPosted: Sat Nov 06, 2004 3:38 pm
rustychain is right. 4 nm should be more than enough (at least for campy cables) to hold them tight.
 Post subject:
PostPosted: Sat Nov 06, 2004 5:35 pm
Eh well I´m changing LBS, the local mech set them up and they slipped of when I was braking (luckily riding alone and not downhill!)
Talk about breaking a sweat!
 Post subject:
PostPosted: Sun Nov 07, 2004 2:04 pm
Let me get this straight. Not between the washer and screw, but washer and screw on the same side? And thanx!
 Post subject:
PostPosted: Sun Nov 07, 2004 2:31 pm
the cable should be setting in the slot with the washer over the cable and the bolt over the washer. The head of the bolt is to small to hold the cable, thats why you need the washer. I have my brakes setup this way with no slipping. I did a panic stop last week, I was going 20mph+, skided 15 feet (it was my fault and the ladies car is ok :oops) these brakes will stop you just fine.
 Post subject:
PostPosted: Sun Nov 07, 2004 2:55 pm
One other thing just in case you did not hear, replace the brake pads with koolstop (black) or DA7800. Much better then the koolstop orange extreme weather pads that come with the brakes.
 Post subject: pads on 0G-05
PostPosted: Sun Nov 07, 2004 3:47 pm
My 0G-05 brakes came with black pads that look surprisingly like Zipp pads. They stop very well my Zipp 280 rims with silica ceramic brake surfaces. The pads are not lightened.
I set the calipers up as per the instructions that came with the brakes (why did you not get them?) and have not experienced any slipping or failure of the brakes. They are confidence inspiring, stop better than the 04 Record brakes I had before with better feel and progression.
End of testimonial...
dr Phil Gandini
Link to my 11.5lb Neo Ultimate
 Post subject:
PostPosted: Sun Nov 07, 2004 3:57 pm
Thx. I replaced them with the 7800´s. Im really looking forward to trying them out when they are properly set up. :twisted:
 Post subject: Re: pads on 0G-05
PostPosted: Sun Nov 07, 2004 3:59 pm
I did get them. But not being the most practical man on earth I trusted my LBS with the setup job. Resulted in that non braking experience. Changed LBS and will check setup before I ride. Tnx for the replies
There are no new unread posts for this topic. Enve 3.4 SES and Zero Gravity Brakes
markcp
Tue May 23, 2017 4:15 pm
Beaver View the latest post
There are no new unread posts for this topic. Changing setup, Aeronova/SL70
PLuKE
Tue Mar 21, 2017 9:30 pm
PLuKE View the latest post
There are no new unread posts for this topic. THM Fibula brakes-setup help required
retired
9
1141
Tue Aug 22, 2017 11:59 pm
retired View the latest post
There are no new unread posts for this topic. Nice carbon bar and stem setup?
PLuKE
11
1484
Wed Aug 23, 2017 6:09 pm
There are no new unread posts for this topic. can i make a 54cm frameset fit me for a trainer setup (normally on a 56)?
motorthings
10
861
Thu Nov 02, 2017 4:35 pm
motorthings View the latest post
Users browsing this forum: -Robin-, billspreston, Bing [Bot], dcorn, goodboyr, lovemyway, MyM3Coupe, Zitter and 45 guests
