It is currently Tue Jan 16, 2018 1:02 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
 Post subject: wipperman ti chain
PostPosted: Fri Nov 05, 2004 4:56 am
what does it really weigh, 235 or 259, I know what is listed on this sight but its hard for me to believe a ti chain weighs about as much as a steel chain, any other weigh quotes other than the single sample reported on this page? theories? Because for my money the campy ultra drive ul @ 259 grams is a lot cheaper?
Brent
El Mahone
 Post subject: Titanium chanis
PostPosted: Fri Nov 05, 2004 5:31 am
I understand that Ti chains are not all titanium--that actually the rollers and pins are ti, and the plates are steel. This explains (at least to me) why they do not weigh all much less than hollow-pin and drilled-plate steel chains like my Campy Ultra 10 (which weighs about 260gms on my bike.)
I stand to be corrected, or course.
cheers,
dr Phil Gandini
Link to my 11.5lb Neo Ultimate
 Post subject:
PostPosted: Fri Nov 05, 2004 7:11 am
Second question? Do you think I could use a campy 10 speed chain on my shimano 9 speed set up or would there be significant problems?
El Mahone
 Post subject:
PostPosted: Fri Nov 05, 2004 10:54 am
Yes you can.
Mine is about 250g. Not quite sure how many links I have in it but I ride 53*25 so it is pretty long (I guess 112 or 114 links)
It is a very nice chain, and the craftmanship that goes into it is probably better than any other chain on the market, however I dont think it is worth its price. My next chain is gonna be Campagnolo Record Ultra.
 Post subject:
PostPosted: Fri Nov 05, 2004 1:10 pm
I'm happy with my SRAM PC-99R hollow pin @ 256.5g (shortened by a few links from stock 114 pin OE length.) I ride 50*26 for the record.
I really wanted a PC-89R hollow pin, but got a great deal on the 99R hollow pin, and it works flawlessly. Best of all it only cost me ~ $28.00 shipped from Nashbar (using a 10% web coupon code.)
I'd like to try a PC-89R hollow pin in the future, as the stock weight is less than the PC-99R hollow pin to begin with. But again, the 99R HP is a fantastic chain... light, strong, cheap.
Jim
PICS http://public.fotki.com/mackdaddy
16.6lbs Light enough for now!
 Post subject:
PostPosted: Fri Nov 05, 2004 1:32 pm
Jim
did you really mean 99R - is there really a roadversion of the pc99 (the R-versions have those funny drilled-out plates)
 Post subject:
PostPosted: Fri Nov 05, 2004 1:36 pm
Jim
No, Ive got a PC-99R hollow pin. From what I can tell, it's designed for MB use and has slightly wider link plates (by .1mm) It has hollow pins, not plates.
Like I said, it works fine on my rig, and it didn't cost a grip!
 Post subject:
PostPosted: Fri Nov 05, 2004 4:25 pm
Hi it depends on witch bike you put it.For example I put the Ti. chain on my TCR composite and to short it about 7 links so after that it weights 240grs.If you use it with 114 links it´s a little heavier.......
PostPosted: Fri Nov 05, 2004 6:02 pm
I'm running the hollowed out Campy 10 chain on my Shimano 9 speed mountain bike. Cog thickness is within .03mm so I had no concerns in that regard before I installed it. After installation I have had no noticiable shifting issues either.
Cut to 106 links it runs about 240 grams.
 Post subject: Re: wipperman ti chain
PostPosted: Fri Nov 05, 2004 6:40 pm
Brent
I've never tried this chain but have heard repeatedly that the lifespan is about 1000 kilometers. :(
That would mean premature chain stretch, which also will wear your cogs and rings faster. Not only are other chains about 10 times cheaper (and almost as light), they will last longer and wont require you to change any cogs too early. Try to save 20grams elsewhere, in other words!!
 Post subject:
PostPosted: Fri Nov 05, 2004 7:54 pm
Dont know where you have heard this, but it is defnitively not true. Perhaps you are mixing it up with that old all titanium Viking chain???
 Post subject:
PostPosted: Fri Nov 05, 2004 8:50 pm
I assume you're speaking from experience? If you're saying you can get a standard chain lifespan from this chain that will be the first time I've heard someone claim that. Not only have I heard a low lifespan for this chain I've heard they shift crappy too. Either way, can you justify spending $300 bucks for a chain that's about 20g lighter, if at all?
 Post subject:
PostPosted: Sat Nov 06, 2004 12:05 am
I know I won't. 8)
 Post subject:
PostPosted: Sat Nov 06, 2004 12:03 pm
Yea, I do.
Well I do. How many did you talk to who actually has this chain? The main parts are made out of steel just like any other Wippermann. I cant see why it would last any shorter than an ordinary chain.
I shifts just as good as any other Wippermann chain.
Read my first post a bit further up. Then you will know the answer.
 Post subject:
 Post subject:
PostPosted: Sat Nov 06, 2004 1:03 pm
2500 km so far and still not gone. Guess cleaning it properly is essential (weight is 247.3 in a 13-26 setup).
Guess lifespan is as good (or bad) as a normal Campa hollowpin chain.
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3048
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Di2 chain
Timmy269
27
1715
Fri Oct 06, 2017 8:20 am
Ritxis View the latest post
There are no new unread posts for this topic. KMC X10-93 chain question
Valy
Mon Apr 24, 2017 4:50 pm
audiojan View the latest post
There are no new unread posts for this topic. How dirty does your chain get?
Boshk
25
1424
Sun Oct 29, 2017 12:18 am
CrankAddictsRich View the latest post
There are no new unread posts for this topic. Chain pin protrusion
mike001100
Sun Nov 19, 2017 6:32 pm
wheelbuilder View the latest post
Users browsing this forum: Conza, Google Adsense [Bot], lovemyway, PinaF8 and 44 guests
cron
