It is currently Sun Oct 22, 2017 11:45 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 109 posts ]  Go to page Previous 13 4 5 6 7 8 Next
 Post subject:
PostPosted: Mon Oct 22, 2007 8:19 pm
Dude, you keep picking on people for not being scientific or showing you the numbers.. I have not seen you posting anything scientific with numbers ever relating the products you seem so eager to defend.
 Post subject:
 Post subject:
PostPosted: Mon Oct 22, 2007 8:21 pm
strobbekoen wrote:
@alienator:
That is not what Adrien said. He did not say "stiff is always better" as an absolute. It is the same argument you and I had in a previous post where you insisted on the argument as if i said "stiff is always better" which i didn't. He didn't either.
I don't remember any such argument with you, but that's beside the point.
Adrien said:
about the stiffness, yes it is very important, almost at any place of the bike. Mavic performed serious tests with stiff and flexy components, same super powerful track guy, same position, etc... the stiffness of the components allow the rider to exploit his full potential while reaching the maximal hearth rate. With less stiff components, the rider can't exploit fully his potential. You can contact Mavic if you want to know more. They perform thousands interesting tests.
Note that it is specifically implied that less stiff components prevent a rider from exploiting his full potential. That sure sounds like a blanket statement from Mavic. And it certainly says that stiff is always better, else you won't exploit the potential you could.
 Post subject:
PostPosted: Mon Oct 22, 2007 8:24 pm
See, I'm not defending a product, Dude. I am defending a tenet of good engineering which is that you design a product with the characteristics it needs to perform to its design specs. The idea that stiffness must be of a certain quality no matter the wheel design flies in the face of good engineering. It's simple, dude.
 Post subject:
PostPosted: Mon Oct 22, 2007 8:26 pm
Anyone with common sense would agree with Adrien on this. Show me your numbers to prove the contrary. Why would your questioning one thesis be more valid than the thesis ? I have not seen you posting any objective data. All you do is question other people's arguments!
 Post subject:
PostPosted: Mon Oct 22, 2007 8:31 pm
PezTech wrote:
What "Big advantage" do Lightweights "throw away" with regard to tensioned spokes?
That by pre-stressing a tension member it can effectively support "compression". Therefore as I keep saying, not only does the spoke losing tension contribute to the lateral stiffness, but also the spokes at the bottom of the wheel contribute to supporting the rim against forces from the ground. Is a common misconception that wheels hang from the top spokes - that is effectively how LWs work, but a traditionally spoked wheel with pre-stressed spokes doesn't - it stands on the bottom spokes.
See http://www.sheldonbrown.com/rinard/wheel/index.htm for data on how spokes becoming totally slack (as is the case from the start if there is no spoke tension) affects wheel stiffness.
The talk on here is all about how carbon has some magical properties that means you can build your wheels differently. Quick reality check here - it has no magical properties, just a better specific stiffness than steel. This means that for a given stiffness a tension spoke can be lighter, but that doesn't change the way the spoke works. There is nothing magical about the way these wheels work - you could build something much the same out of steel/alu if you wanted, but it would obviously be heavier. Spoke pre-tension would benefit them in terms of stiffness in just the same way as for a conventional wheel with no weight penalty (arguably you could then make them lighter for the same performance).
No scales on the trails
 Post subject:
PostPosted: Mon Oct 22, 2007 8:32 pm
WWotY 2007
Yes I meant stiff components are required to exploit fully the rider potential.
Keep in mind that a light and weak rider will not need as stiff wheels as a heavy powerful guy. The tests were performed with a 20kg lateral load.
Yes Alienator, you really seem like defending Lew from your posts. Take it easy and be fair.
Lew, Mavic or Lightweight: from all of them I would prefer to have a Lew 2008 wheelset, even though they were tested as the most flexy! ;) (just to let you see I don't defend any of the two other!)
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Mon Oct 22, 2007 8:36 pm
Well, that's the beauty of reading text on a screen: your free to assume things to be a certain way even if there not that way.
 Post subject:
PostPosted: Mon Oct 22, 2007 8:39 pm
Well, then there you go. Take your common sense and run with it, Dude. Before you run off though, Dude, by the definition of Scientific Method, theses are to be questioned, dude. That's what it's all about.
What data am I supposed to provide, especially since I'm just supporting sound engineering principles? Dude, pull up some data if you want to support your pet thesis, but remember it's the one with the thesis that is required to provide the data.
Doesn't it suck when that whole science and scientific method thing get in the way, dude?
 Post subject:
Be a little bit more critical of yourself before you tell people of using scientific verbage. You are not the only person granted to this privilege. To be honest i am getting tired of you picking on people while not providing any substantial arguments yourself.
I guess this tells the story. You are obviously the only one capable of grasping science and scientific methods.
What thesis ? What engineering principles ? You never provided anything constructive. You just enjoy picking out whatever it is that you think is not scientific. The best sailors stand ashore don't they ?
 Post subject:
PostPosted: Mon Oct 22, 2007 8:41 pm
and whats wrong with the word dude its one of my favourites?
tikka
 Post subject:
PostPosted: Mon Oct 22, 2007 8:44 pm
WWotY 2007
I wrote "you seem".
Now I think it's better to go back on topic. Will Lew propose a lighter wheelset to reply to the lightest wheelset of the world?
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Mon Oct 22, 2007 8:56 pm
Since you don't seem to understand how a normal tension spoked wheel works and why the parts of a LW / Lew being carbon don't make any difference to the engineering behind it, then I'd suggest you're not actually, dude. Since I'm basing my argument on well researched principles, I'd suggest it's you who needs to come up with some proper arguments to support your theory if you think carbon spoked wheels work differently, dude.
You'll note that I agree with you, tikka, dude :D
 Post subject:
PostPosted: Mon Oct 22, 2007 9:10 pm
As far as I know, carbon has it´s strengths in elongation, not compression, where it´s rather weak. That makes it different from metals. Hence the different construction methods and designs.
 Post subject:
PostPosted: Mon Oct 22, 2007 9:14 pm
Carbon does just fine in compression provided it is supported in an epoxy matrix. Otherwise carbon bike frames (where the top tube, seatstays and seattube are in compression) wouldn't work. Then again metal spokes don't do so well in compression either due to buckling!
 Post subject:
PostPosted: Mon Oct 22, 2007 9:18 pm
I don't really want to get this thread more heated, but I must ask this since it's not yet been answered. alienator, DO YOU OR DO YOU NOT WORK FOR LEW? How about an honest answer?
alienator wrote:
A well designed product is as stiff as it needs to be, as strong as it needs to be to meet it's performance targets. It does not have to meet some generic "wheel's must be built like this" ideal.
That would be fine if every company would design a custom wheel for every customer. If not they must be built to some generic standard as they need to work for almost any rider that gets on them. Certainly my 208lbs needs a stiffer wheel than someone weighing half as much.
But he did post something scientific relating to products.
alienator wrote:
I know some have raised questions about the design, and some have questioned whether they've done any CFD and/or wind-tunnel time. LEW claims that the spoke profiles coupled with the rim profile is more aero than a 100mm rim with metal spokes (I'm assuming bladed spokes). While I may be somewhat gullible, I find it hard to believe that they'd make such a claim without having done the tests to back it up. And those tests would have to be wind tunnel tests. I think CFD testing for a spinning wheel, especially with a lot o' spokes, would be a nightmare.
It seems quite convenient to require others to post links to published data yet not require it for yourself or your company.
Master of quotes.
 Post subject:
There are no new unread posts for this topic. Challenge Strada 25 on Mavic Open Pro rims blow off
roadchallenge
Mon Dec 05, 2016 5:58 pm
roadchallenge View the latest post
There are no new unread posts for this topic. lightweight cockpit
Rubik
11
1675
Wed Apr 26, 2017 12:43 pm
DaReef View the latest post
There are no new unread posts for this topic. These Lightweight brakes?
PLuKE
7
1136
Mon Aug 07, 2017 8:42 pm
kulivontot View the latest post
There are no new unread posts for this topic. (Not lightweight, but...) How do you set up 105 5800 FD?
niklasp
20
1741
Mon Jul 17, 2017 11:32 am
niklasp View the latest post
There are no new unread posts for this topic. Lightweight Urgestaldt
Roadeeee
21
3079
Fri Feb 24, 2017 9:49 pm
KCookie View the latest post
Users browsing this forum: Bing [Bot], itchyjoe, jgadd, motorapido and 25 guests
