Post new topic Reply to topic  [ 15 posts ]
 Post subject: cranks
PostPosted: Thu Sep 26, 2002 5:32 pm
I'm upgrading my drivetrain to record and was going to go with a non-campy crank because the campy carbon is overpriced (I think) and other co's. offer some better performers. My frame is english thread and I am looking for input on some crankarm/bb settups. The weight/performance tradeoff is harder for me to figure on these components than in other areas. I've bought other components (like wheels) that did not make a significant difference in the performance or weight loss of my bikes, so please don't recomend some lower performer. The FSA pro is lighter than the team for instance. If I used the pro would the performance of my drivetrain be significantly increased or am I just spending money on new stuff to be cool in front of the guys? I heard that zipp was going to get back into making crankarms, is this true. Would they be the significant step up that I'm looking for? Who else is out there that I should be looking at? Thanks for your time, Popa
 Post subject:
PostPosted: Sun Sep 29, 2002 3:02 am
Where did you get your information that the Pros are lighter than the Team Issues? I haven't found a weight comparison for these anywhere, and would be interested to know by how much they are different.
I recently replaced my Dura Ace cranks with a set of Team Issues and immediatly noticed that they are indeed more rigid. Unfortunately I weighed the new set in at only 15 grams lighter than the D-A but given the more substantial feel, I'm satisfied. I have heard one person comment from personal experience that the Pros are not quite as stiff as their newer cousin but you may still find them a good improvement over any alloy alternatives. Incidentally, the large splined spindle D-A BB is a smart design, a solid performer and not difficult to maintain in my experience. It is one of the lightest things going without resorting to fairly obscure and specialized options. I understand that one can interface the D-A BB and compatible crank with an otherwise Campy 10 drivetrain.
 Post subject:
PostPosted: Thu Oct 03, 2002 2:26 am
I'm not sure where I found the weight difference between the pro and team FSA cranks but I'm pretty sure the pro's are lighter and probably not as ridgid. I'm still looking for the cranks that are going to do it for me I guess. Is there a site where I can compare the stats between the different high end cranks out there?
 Post subject: FSA Pro
PostPosted: Wed Oct 09, 2002 6:04 pm
I moved my 8-speed Record componants to a new frame this summer and changed the crankset to the FSA Pro with an Ultegra bottom bracket. I just couldn't see spending the money for the carbon Record set. The FSA crank is noticably stiffer than my old Record set. I didn't weigh it, but I know the bottom bracket alone weighs about a ton less. I'd recommend the FSA to anyone.
Dave from Maine
 Post subject:
PostPosted: Wed Oct 09, 2002 11:19 pm
Thanks Dave, I appreciate the recomendation. I'm still looking though. There should be a crank between the two. I'll bet there will be more choices in a little while. It seems the component companies will focus on a bike part and there will be an explosion in inovation and production. Maybe the crank/BB area is due.
 Post subject: BB's
PostPosted: Thu Oct 10, 2002 2:25 pm
I just put a set of the FSA pro's on my tri bike and have loved them. You might check out the American Classic BB's awesome low maintenance, great performance and superlight weght.
 Post subject:
PostPosted: Wed Oct 16, 2002 4:36 pm
Hi Mate
Yes good combination to try out (a bit more expensive than FSA) is the Storck power arms you can get these at www.poshbikes.com speak to Andy, very friendly chap. I am running these with AM classic bb. The cranks are pretty good upgraded from FSA carbon pro to these and when I got them they seemd just to light to even try hammering, but are more than strong enough. They weight about 310 gramms per pair, only funny bit is that the width between your feet while clipped in inreases by just over 1cm ------- that is the distance in reality, I don't feel it, but something to think about. They also only come in 172.5 mm lenght
 Post subject:
PostPosted: Thu Oct 17, 2002 6:07 pm
Thanks Francois, I'll take a look at their offerings. I appreciate the info, David
 Post subject: FSA Cranks
PostPosted: Fri Oct 18, 2002 2:30 am
The Team is lighter than the Pro. Under weight weenies listings, it shows 22 grams lighter, but I believe it is actually more. I'll check tonight and report.
 Post subject:
PostPosted: Fri Oct 18, 2002 5:07 pm
Thanks Desperado, It's funny how the weights are listed on some components and not on others right on the same page in a catalog. I think if a catalog is trying to sell alot of a certain product because they bought alot of them and the markup is high for them they are not going to list certain info on a product on the same page that would detract from it. So when you weigh the product and list it we can compare apples to apples. Thanks again, David
PostPosted: Sat Oct 19, 2002 12:02 am
I got a slightly greater difference 28 grams, but there has to be a certain amount of variation, better be lighter for about $150 more.
PostPosted: Tue Dec 10, 2002 7:12 pm
seen M2racer Ti cranks 222g and pedals 100g, real light and damn ugly cranks. www.m2racer.com
 Post subject: Tune Cranks
PostPosted: Fri Dec 13, 2002 7:11 am
What about Tune cranks?? I think they're about 400gms w/o chainrings. I haven't heard any feedback from anyone, but I was thinking of getting these myself.
PostPosted: Fri Dec 13, 2002 10:43 am
Havent tried these but they look like they'd have too much flex in them. :?:
PostPosted: Fri Dec 13, 2002 12:03 pm
The Tunes look very similar to Toplines and while they were great for light riders I could definatley feel the flex at 80kg+ (180mm cranks) but they are still going (now on my TT bike, so rarely used).
Users browsing this forum: ayrej2, Bing [Bot], giro di lento, Google Adsense [Bot], h4nc0 and 47 guests
There are no new unread posts for this topic. SRM for THM 3M cranks??
civdic
7
725
Tue Dec 04, 2012 9:47 pm
tetonrider View the latest post
There are no new unread posts for this topic. Campag 52/36 cranks
markyboy
Tue Jun 05, 2012 4:29 pm
Willier View the latest post
There are no new unread posts for this topic. Rideabike cranks?
verycreativeusername
Sun Dec 09, 2012 12:51 am
btompkins0112 View the latest post
There are no new unread posts for this topic. THM brakes & cranks
nick
Mon Feb 25, 2013 6:26 am
coppercook62 View the latest post
There are no new unread posts for this topic. Rotor Cranks
Thrillho
Tue Aug 07, 2012 1:11 am
project3 View the latest post
It is currently Tue May 21, 2013 8:35 am
