It is currently Thu Jan 18, 2018 3:31 am
Post new topic  Reply to topic  [ 7 posts ]
 Post subject: Truing Reynolds wheels
PostPosted: Thu Aug 23, 2007 11:48 pm
Hi, does anybody know what type of spoke key I need to true Reynolds Cirro SV's? They are the older versions with LTA hubs. They look like standard nipples inverted but I'm not sure. I've used the search facility but I'm still confused, do I need a 5mm hex driver or a stardard deep section spoke key like the FSA one?
Ti or dye!
 Post subject:
PostPosted: Fri Aug 24, 2007 12:32 am
I think that the older ones were inverted nipples. Now they are not metric (I think they are 3/16, I'm away right now).
-ERic
 Post subject:
 Post subject:
PostPosted: Fri Aug 24, 2007 12:35 am
This is from the Reynolds Web Site:
{USERNAME} wrote:
What spoke wrench do I need to true my Reynolds wheels?
Reynolds has both a professional spoke tool and a personal spoke tool that will allow you to true/tension the hex nipple on Reynolds wheels. Otherwise 3/16” or 5 mm socket driver or an older Campy t-handle spoke wrench will work as well.
 Post subject:
PostPosted: Fri Aug 24, 2007 2:37 am
I am just going to repeat what StrongBad (Love your weekly emails) and Ergott said that it is a 3/16th nut driver.
 Post subject:
PostPosted: Fri Aug 24, 2007 8:01 am
Thanks guys, looks like I'll try 3/16. I read the Reynolds site too, an either or answer isn't much good is it, I worked that one out myself!
Ti or dye!
 Post subject:
PostPosted: Fri Aug 24, 2007 2:06 pm
yes ... 5mm socket driver and you can mail order a set from Maplin for about £4 i think.
I did and it works!
 Post subject:
PostPosted: Fri Aug 24, 2007 3:07 pm
I'm a big fan of right tool for the job. 5mm doesn't fit anywhere near as well as the proper 3/16. You won't be applying much torque on them, but if you are going to get a new tool, get the right one. They Reynolds tool is real nice as the outer diameter is smaller that a standard nut driver making it easier to get in and out of the rim.
-Eric
 Post subject:
There are no new unread posts for this topic. Rear Derailleur Pulley Wheels / Jockey Wheels - 17t and oversized sizes - where?
prendrefeu
27
1962
Wed Jan 03, 2018 3:28 am
morganb View the latest post
There are no new unread posts for this topic. Attachment(s) Can you identify this Reynolds hub?
MarkH
10
964
Fri Apr 21, 2017 1:53 pm
CLEAR View the latest post
There are no new unread posts for this topic. Anyone has any experience with Reynolds Aero 65?
dorin
Tue Jan 16, 2018 9:50 pm
KarlC View the latest post
There are no new unread posts for this topic. Quick Opinion - Mercury M5 or Reynolds R SIx
ChiCyling
Thu Aug 31, 2017 4:40 pm
joepac View the latest post
There are no new unread posts for this topic. QR skewer shopping - Zipp v Enve v Reynolds
Shrike
34
3265
Tue Feb 07, 2017 5:00 am
Johnny Rad View the latest post
Users browsing this forum: AZR3, Bing [Bot], chronsbons, CrankAddictsRich, glam2deaf, Global, Imaking20, Jereb, nobuseri, Yahoo [Bot] and 43 guests
