It is currently Thu Jan 18, 2018 5:10 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
 Post subject: CR1 Scott 11.85lbs
PostPosted: Wed Sep 22, 2004 7:15 pm
SCOTT CR1 11.85lbswithout pedals. This bike is beautiful, it is set up with:
Dura Ace 10 Speed Cranks
Shifters
Fron and Rear Der.
Front and Rear Brake calipers
11-21 Cassette
Chain and Bottom Bracket
Cable and Casing
ITM Millennium stem 100mm
Kestrel EMS Pro SL handlebars
FSA K-Lite carbon post 350 X 31.6
Vittoria CorsaEVO CX Tubulars
American Classic Carbon WheelSet with Sapim Spokes 18 front, 24 rear
Selle Italia SLR saddle
 Post subject:
PostPosted: Wed Sep 22, 2004 7:26 pm
sounds heavier if you ask me
 Post subject:
 Post subject:
PostPosted: Wed Sep 22, 2004 7:37 pm
NO way that bike weighs much less then 13. Got any pics? Plus pedals are a vital part of the weight.
Your crank/BB is 150g heavier then mine, Brakes 150g heavier, post 80g heavier, Saddle 70g heavier, fork is at least 60g heavier if not 140g heavier as the CR1 forks are not the quoted 360g unless you have a 2005 model which isn't out yet so I'm counting on a 160g heavier fork. Only thing you seem to have lighter is the wheels, so -150g there.
Your bike is about 450g heavier then mine without pedals so there is no way your ride is 11.85lbs, more like 13lbs without pedals.
My scott will weigh about 12.6lbs with pedals( they only weigh 133g) and 12.3lbs without with a much lighter build. No way your bike ways 11.85lbs. :roll:
Heres my build
Bar Tape: Cinelli Cork 40
Bottle Cage: Arundle 30
Bottle Cage Bolts: 4 Aluminium 5
Bottom Bracket: New Ultimate ISIS 108mm 118
Brake Levers/Shifter: 7800 Dura Ace 10 Speed (incl. shifters) 420
Rear Brakes: Zero-Gravity 185
Front Brakes: Zero Gravity weight included above 0
Cables: Shimano Cables 120
Cassette: 7800 Dura Ace 10 Speed 12-23 180
Chain: KMC X10 230
Crankset: Stronglight Pulsion 172.5mm ISIS 434
Crank Bolts: New Ultimate ISIS 23
Derlr (Front) 7800 Dura Ace 10 Speed Braze On 71
Derlr (Rear) 7800 Dura Ace 10 Speed 180
Fork: Ritchey WCS Carbon 280g
Frame: 05 Scott CR1 Limited (Size M / 54cm) 880
Handlebar: Kestrel EMS Pro SL 40cm 168
Headset: FSA integrated 80
Headset Cap/Bolt: FSA 0g
Headset Spacer: Scott Carbon 10mm 5
Pedals: Speedplay X/1’s with Alu insert 133
Quick Releases: USE Alien Spin Stix 56
Seat Binder: Scott CR1 16
Seat: AX Lightness Apollo SL 73
Seatpost: Heylight Superleicht II 31.6mm 110
Stem: Ritchey WCS 90mm 100
Tires Kenda Kaliente 23mm X 2 380
Tubes: Continental Supersonic (with extended valve stem) 102
Wheelset: 1270
Misc Option: Rim tape 5
TOTALS:
grams: 5696g
pounds: 12.54lbs
 Post subject:
PostPosted: Wed Sep 22, 2004 10:06 pm
Chris first off :welcome: to the board.
Based on the limted list of parts you posted your Scott could not weigh what you state.
See my earlier [url=http://weightweenies.starbike.com/forum/viewtopic.php?t=3105[//url]post[/url]
Cheers,
:lol:
"Ride lots." -- Eddy Merckx
Click Here to see my Scott CR1.
 Post subject: over 13lb for sure
PostPosted: Thu Sep 23, 2004 12:03 am
I must third, or fourth, that! All that Shimano stuff, nothing special except for those lightweight AC carbons and tires, there's something wrong with your math, or your scale. My 13.5lb TCR has nearly every component lighter or the same as yours, except for frame and bar/stem, and that's not 2lbs worth.
Sorry, but these weightweenies can weigh a bike from across the ocean, to within 100gms! This is *the* place for light bikes, and while yours is certainly worthy, it's no show stealer.
Happy gram hunting...
Ptg
dr Phil Gandini
Link to my 11.5lb Neo Ultimate
 Post subject:
PostPosted: Thu Sep 23, 2004 1:01 am
@Chris
Here's your list with weights I found on the listing:
Frame (medium?): 880
DuraAce Groupo
10 SPeed Cranks incl BB: 735
Brake Lever / Shifters: 420
F Derailleur: 71
R Derailleur: 181
F/R Brake Caliper: 312
Cassette: 165
Chain: 240
Cable: 120
Stem ITM 100mm: 95
Handlebar Kestrel EMS Pro: 183
Seatpost FSA K-Lite 350x31.6: 223
Tires Vittoria Corsa EVO CX: 470
Wheelset AC : 1120
Saddle SLR: 137
TOTAL: 5352g or 11.8 lbs
Things that you missed or maybe not using:
Bar Tapes, Bottle Cage & Bolts, Headset Cap & Bolt, Binders, QR.......
and the most important or unless you're from a circus.....
FORK & HEADSET !!!! :shock:
did i miss something?
 Post subject:
PostPosted: Thu Sep 23, 2004 1:26 am
LOL @ Fork & Headset!
Tire tubes also. All the stuff left out probably around 2 lbs at least.
 Post subject:
PostPosted: Thu Sep 23, 2004 4:36 am
Also computer, in my opinion, and maybe an allowance for grease, etc.
Why do these paper builds never add up? Because they're paper.
Welcome, Chris, to WW world, where besides a password, one needs an Excel spreadsheet; photographed digital scale weights; preferably skill with a Dremel; lots o' cash or excellent-paying lawn-mowing work; and absolute evidence that you're not using a rebadged Simplon or a 2-tone DA crankset. Gandini's right: these guys smell kilos, grams and milligrams.
Careful: it's an interest that quickly turns into a fetish that becomes an obsession. :) So, on with the diet....
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
 Post subject:
PostPosted: Thu Sep 23, 2004 8:06 am
Well said, absolutely excellent! :lol:
 Post subject: welcome here - Chris...
PostPosted: Thu Sep 23, 2004 11:22 am
welcome on this board Chris,
as you can see you will be corrected "by each gram" as you are entering a dangerous area here!!!
the guys around here really know about everything so be careful when posting guessed weights...it's all pretty accurate here and we guys care for every gram. like explained above that can become an obsession but it's part of the fun and hobby we all share here.
so next time you do such an attempt give the full detailed specs. have a look at other spec sheets so you don't forget something. here's mine for example, although not with my lightest wheelset and not the most actual pic but anyway...:
http://light-bikes.com/bikegallery/Bike ... asp?id=285
 Post subject: EEECK!
PostPosted: Thu Sep 23, 2004 6:21 pm
While I am excited to post on the board and real excited about my Scott, I want to be correct in weight of the bike. SO I plan to get a better scale and try to prove myself worthy of WeightWeenies.
I lett you know my findings.
 Post subject:
PostPosted: Thu Sep 23, 2004 8:04 pm
Nino, do you agree with Samu when he says thats AC Cr-420 arent race wheels?
 Post subject:
PostPosted: Thu Sep 23, 2004 8:15 pm
YES- completely!
my CR420 aren't great wheels. after just 90 km i had play in the rear hub. it was so much that it made a knacking sound. so i tried to adjust the play but there was no way to adjust it....when i finally disassembled the hub the rear bearings simply fell out of the hub! they didn't have a thight fit at all. so all i had to "glue" them back in with some special Loctite...not what you are looking for in a new wheelset. ok,ok - i got a free replacement rear hub within 1 week but i would have to re-lace the wheel to which i never did.
the wheels are ok for training. they are pretty light and look good. however my custom built CR350 with FRM SL hubs and 28/28 DT Revo are much stiffer. MUCH! and also 80g lighter (1292g vs. 1371g of the CR420 with Sapim CX-Rays).
my CR350 wheels feel even faster so aerodynamics of the CR420 also isn't too good in my point of view. nevertheless i used them as my everyday wheels. so after 1 year i decided to give them a overhaul at my wheelbuilder. he checked spoke tension but the re-thightened wheels don't feel any better either. the CR 350 of that same wheelbuilder are much stiffer. the rims are also pretty weak. my wheelbuilder said they wouldn't accept too high spoke tension because they start de-forming. sprinting and going down at speed is definitely wobblier than with the CR350 which really surprise me. they are even stiffer than some black Ksyrium SLs i used before.
 Post subject:
PostPosted: Fri Sep 24, 2004 12:13 am
This is quite strange... I have AC cr420 and I love them! I didn't have any problem with them, they feel fast and light. (well, I had Mavic Cosmos before...) Maybe it's because I weigh 120 pounds...
 Post subject:
 Post subject:
PostPosted: Fri Sep 24, 2004 6:16 am
sure it's your weight!
and coming from the Cosmos' weight they sure feel fast....
There are no new unread posts for this topic. Scott CR1 frame size?
sanfairyanne
Mon Nov 20, 2017 11:20 am
jekyll man View the latest post
There are no new unread posts for this topic. Question for those w/ Scott Addicts
MAsshole
Tue Jun 27, 2017 3:15 pm
lord_brush View the latest post
There are no new unread posts for this topic. I'm looking at buying a Scott Addict
dim
Fri Dec 01, 2017 5:15 am
TonyM View the latest post
There are no new unread posts for this topic. Scott Foil HMF Build
ab01ns
Sat Dec 16, 2017 5:30 pm
banik69 View the latest post
There are no new unread posts for this topic. Scott Foil vs. Addict
DaVinci
29
6824
Wed Mar 01, 2017 6:31 pm
p3dalfaster View the latest post
Users browsing this forum: darnellrm, jfranci3 and 40 guests
cron
