It is currently Sun Jan 22, 2017 7:25 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Tue Sep 21, 2004 6:28 pm
WWotY 2007
Hello.
Here are some pictures of my rear Zipp:
This one was done with the flash,that's why it looks very dark:
As you see,it is bad finished at close range.
Are every rims like that or did I get a bad serie?
They are very expensive,they should at least make something beautiful,even at close range.The pictures are clickables.
Thanks.
Adrien.
RAR wheels
Roues Artisanales
 Post subject:
PostPosted: Tue Sep 21, 2004 7:28 pm
They look just normal. I had 11 pieces of Zipp rimas and all looked like that.
If you want nice and shiny CF-products,add more epoxy. More weight and look, nothing else.
If you want light and strong, use high pressure to put epoxy out and heat tread them right. More fiber, less epoxy= stronger.
AND remember, in most cases, using twill is not best fiber type but in most peoples eyes that is best and almoust only CF that they recognice.
And if you look some German made light weight wheels, they look bit home made also. But they are best what you can get with ANY money.
If you want best looking "cafe racer" wheels, get new Campa Boras...
Samu @ www.signature.fi
 Post subject:
 Post subject:
PostPosted: Wed Sep 22, 2004 7:04 pm
WWotY 2007
Ok thanks you.
RAR wheels
Roues Artisanales
PostPosted: Thu Sep 23, 2004 4:52 am
Your photos look like they were taken of my rims! Even down to that weird looking "blemish" in the first photo that has two lighter patches. I have exactly the same blemishes. My AC use Zipp 280 rims and they appear to be very well made, with less attention paid to cosmetics, and consequently more attention paid to performance. They are LIGHT, that's for sure.
Wait till they break--you should have long sold them by then...
cheers,
dr Phil Gandini
Link to my 11.5lb Neo Ultimate
 Post subject:
PostPosted: Thu Sep 23, 2004 5:33 am
can they even become untrue from usual riding?
 Post subject:
PostPosted: Thu Sep 23, 2004 2:34 pm
no, full cfk-bodies, using a duroplastic matrix, can't be bent plastically untill the structur fails in some way (invisible and/or inner cracks etc) - and even then bending is most impropable at least for full gfk/cfk structures. foamcore sandwiched structures or profiles with "large" cross-sections on the other side CAN kind of bend plastically in case of failure as the foamcore still takes some loads and the hole sandwich only breaks partly, wich causes some kind of "virtual bending" (it's still only bent elastically but stays untrue for unbalanced tensions)...
to keep it short, if they rims themselves become untrue - ie free from spoke tension!!! - they are likely to be "smashed" some way :)
 Post subject:
PostPosted: Thu Sep 23, 2004 5:40 pm
can I get a testing sample?! I'll like to test the wheels under 100,000 miles and see if they become untrue from normal riding :D
 Post subject:
PostPosted: Thu Sep 23, 2004 8:15 pm
in fact, i was talking of the rims only. sorry about that :)
nevertheless i don't have a set to give you for testing purposes - i don't have a set of these anyway...
 Post subject:
PostPosted: Thu Sep 23, 2004 10:47 pm
I'll take ANY pair of wheels for testing purposes ;)
 Post subject:
PostPosted: Thu Sep 23, 2004 10:57 pm
Really, want some spinergy Rev-X's? :twisted:
 Post subject:
 Post subject:
PostPosted: Fri Sep 24, 2004 2:45 am
sure!
There are no new unread posts for this topic. Zipp 303 vs Zipp 404 chainstay rub
nemeseri
14
1553
Sat Nov 26, 2016 4:49 am
nemeseri View the latest post
There are no new unread posts for this topic. Rims for wheel build
pickerd
Mon Jan 02, 2017 5:37 pm
pickerd View the latest post
There are no new unread posts for this topic. Replacement rims in 18F and 24R with 2:1 lacing?
NiFTY
Fri Apr 01, 2016 8:52 am
fabriciom View the latest post
There are no new unread posts for this topic. Frame recommendations for wide rims
mogwaiboi
Sun Feb 14, 2016 1:35 am
mogwaiboi View the latest post
There are no new unread posts for this topic. Valve length for 50mm rims
burglarboycie
19
1242
Wed Aug 31, 2016 1:29 pm
Lugan View the latest post
Users browsing this forum: HammerTime2, UTmtnbiker, Yahoo [Bot] and 30 guests
