It is currently Thu Jan 18, 2018 1:30 am
Post new topic  Reply to topic  [ 34 posts ]  Go to page 1 2 3 Next
 Post subject: My new bike!!!!
PostPosted: Fri Sep 17, 2004 4:22 pm
:D
I just had to make a post, as I have finalized my entire build! Only thing that might change is bottle cage and cables used.
Input appreciated, thanks!
Model: 05 Scott CR1 Limited “SUPERLITE” Weight
Bar Tape: Cinelli Cork 40
Bottle Cage: Arundle 30
Bottle Cage Bolts: 4 Aluminium 5
Bottom Bracket: New Ultimate ISIS 108mm 118
Brake Levers/Shifter: 7800 Dura Ace 10 Speed (incl. shifters) 420
Rear Brakes: Zero-Gravity 185
Front Brakes: Zero Gravity weight included above 0
Cables: Shimano Cables 120
Cassette: 7800 Dura Ace 10 Speed 12-23 180
Chain: KMC X10 230
Crankset: Stronglight Pulsion 172.5mm ISIS 434
Crank Bolts: New Ultimate ISIS 23
Derlr (Front) 7800 Dura Ace 10 Speed Braze On 71
Derlr (Rear) 7800 Dura Ace 10 Speed 180
Fork: Ritchey WCS Carbon 280g
Frame: 05 Scott CR1 Limited (Size M / 54cm) 880
Handlebar: Kestrel EMS Pro SL 40cm 168
Headset: FSA integrated 80
Headset Cap/Bolt: FSA 0g
Headset Spacer: Scott Carbon 10mm 5
Pedals: Speedplay X/1’s with Alu insert 133
Quick Releases: USE Alien Spin Stix 56
Seat Binder: Scott CR1 16
Seat: AX Lightness Apollo SL 73
Seatpost: Heylight Superleicht II 31.6mm 110
Stem: Ritchey WCS 90mm 100
Tires Kenda Kaliente 23mm X 2 380
Tubes: Continental Supersonic (with extended valve stem) 102
Wheelset: 1270
Misc Option: Rim tape 5
TOTALS:
grams: 5696g
pounds: 12.54lbs
AND NO BS PARTS AND CLINCHERS!!!! AHHHHHHHHHHHHHHHHHHH
 Post subject:
PostPosted: Fri Sep 17, 2004 4:37 pm
congrats!!! superlite, weight achieved is amazing considering alla parts are rideable and raceable...got a pic u can share? reading your old posts, i thought u were going to build a six 13...
 Post subject: Chain
PostPosted: Fri Sep 17, 2004 4:46 pm
I'm sorry to say this, but the KMC chain weighs significantly more than 230. My scale is only accurate to +/- 5 grams, but it said 265.
-Andrew
 Post subject:
PostPosted: Fri Sep 17, 2004 5:35 pm
Superlite Check your PM. 8)
Cheers,
:lol:
"Ride lots." -- Eddy Merckx
Click Here to see my Scott CR1.
 Post subject:
PostPosted: Fri Sep 17, 2004 6:22 pm
Any chance of a pic please SL?
I'm just gagging for a Look 585...
rico
 Post subject:
PostPosted: Fri Sep 17, 2004 6:28 pm
No pics, as I'm still waiting on parts to arrive
Still waiting on frame, BB, Saddle, Post, stem and wheels.
Everything else I have.
Just got my Pulsion's today, going to swap bolts and weigh!
 Post subject:
PostPosted: Fri Sep 17, 2004 6:55 pm
well, even with the weight discrepencies, it should still come in under 13lbs, so thats pretty cool, make sure you get some pics up of the wierd (more specialist parts) that make up your build.
 Post subject:
PostPosted: Fri Sep 17, 2004 8:56 pm
What rim tape is 5g/pair?
Vittoria plastique is good, easy and 26g but 5g???
I know classfibre tape is light but 3 rounds weight like 20g/pair and less would not last in 8 bar...so I use Vittoria...
Samu @ www.signature.fi
 Post subject:
PostPosted: Fri Sep 17, 2004 9:59 pm
Tape is crap, but only weighs sub 5g. Good for MTB only.
I'm using Continental Supersonic Rim Tape, the lightest I know of.
ALSO, updated my build, cranks came in at 434g!!!
AND stay tuned, I just ordered my super sweet wheels, something you guys have never seen before. And weigh a scant 1270g!!! 8)
Soon I will have the lightest DA equiped ever! HAHAHA!!!
 Post subject:
PostPosted: Fri Sep 17, 2004 11:31 pm
Superlite- people are asking for pictures.......why don't you just tell everyone that the list is just a dream......that no actual bike exists...but that maybe someday if you mow enough lawns that you might actually buy this "bike"?
 Post subject:
PostPosted: Fri Sep 17, 2004 11:44 pm
It's not a dream, I have ordered all the parts, I'm waiting for them to arrive.
Bike won't be done until mid december however due to CR1 Limited availability. I should have every part except the frame within 3 weeks.
Like I said, I have everything except the frame, wheels, BB, saddle, post and stem. All of which (except frame as it's not available) payed and ordered.
 Post subject:
PostPosted: Fri Sep 17, 2004 11:49 pm
C-40, you are simply hilarious. :lol:
 Post subject:
PostPosted: Fri Sep 17, 2004 11:59 pm
When I get my wheels in I'll take a pic of everything.
And yeah, I mowed alot of lawns this summer. :wink:
 Post subject:
PostPosted: Sat Sep 18, 2004 12:45 am
My bike:
Frame: '04 Bianchi XL EV4 57 cm 1160 g
Fork: '04 Bianchi XL Carbon 350 g
Headset: Bianchi 50g
Aheadcap: Schmolke 5g
Headset Spacers: Carbon 3 g
Stem: Syntace F99 Ti 97 g
Handlebar: Oval Concepts A950 42cm 170 g
Handlebar Tape: Bike Ribbon 30 g
Saddle/Seatpost: Ax-Lightness (ca.70g) + New Ultimate (350mm) ø27.2 mm (129g) 229g
Seat Binder: B-T-P 7g
Front Derailleur: Campagnolo Record (B-T-P) 58g
Rear Derailleur: Tiso Sereo 165g
Shift & Brake Levers: Campagnolo Record Ergopower 324g
Crank Arms: Stronglight Pulsion 300g
Chain Rings: TA 134g
Chain Ring Bolts: Tiso 7g
Crank Fixing Bolts: 24g
Bottom Bracket: FRM BB-CU2 Al 132 g
Cassette: Campagnolo Record (12/25) 190g
Cassette Lockring: tune Edelzwicker 5 g
Chain: Campagnolo C10 Ultra HD-L 250g
Brakes: Dia Compe BRS (tuned) 175g
Wheelset: Xero Lite XR1 1520g
Tyres: Veloflex Record 260g
Skewers: tune 49 g
Cables & Housings: Campagnolo Record 248g
Pedals: Speedplay X1 126g
Bottle Cages: tune Wasserträger 4.5 g
Totales Weight: 6038.5g
I will buy a tubular wheelset though, if I have the money together. (Will save me about 500g)
 Post subject:
 Post subject:
PostPosted: Sat Sep 18, 2004 3:07 am
Ummm?
No offense, but why did you post your bike specs? :lol:
There are no new unread posts for this topic. Which one is fastest? UCI Time trial bike or non-UCI triathlon bike?
TonyM
Tue Dec 26, 2017 8:30 am
bllx View the latest post
There are no new unread posts for this topic. Help me find a bike article. Does anyone remember this bike?
alcatraz
10
1217
Sat Aug 05, 2017 8:08 am
alcatraz View the latest post
There are no new unread posts for this topic. 5kg bike claimed as "Worlds Lightest Bike"...
jimaizumi
11
3204
Sun Jun 25, 2017 5:40 am
SK5 View the latest post
There are no new unread posts for this topic. What bike to get?
lemkeg
21
2738
Fri Sep 08, 2017 6:16 pm
moyboy View the latest post
There are no new unread posts for this topic. New Bike Day!
gsindela
Thu Feb 16, 2017 2:23 am
Fixie82 View the latest post
Users browsing this forum: Chris3g, Google [Bot], KarlC and 30 guests
