It is currently Fri Jan 19, 2018 2:51 pm
Post new topic  Reply to topic  [ 613 posts ]  Go to page Previous 120 21 22 23 2441 Next
 Post subject: Re: Tillquist's kitchen!
PostPosted: Thu Jan 02, 2014 7:11 pm
Tillquist,
I just e-mailed you about 3T ARX version.
Thanks!
My Colnago EPS http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=83064&start=45
PostPosted: Mon Jan 06, 2014 9:14 pm
hi - can you tell something about handling with garmin on this holder? As it is a bit lower than with original holder and closer to the handlebar - is there any problem to press buttons on use touchscreen?
thx
PostPosted: Mon Jan 06, 2014 10:03 pm
I have the 3T holder. It easy to reach everything.
PostPosted: Tue Jan 07, 2014 12:00 am
Just my word :-)
See all my bike h e r e
PostPosted: Wed Jan 08, 2014 10:23 pm
petal666 wrote:
Looks like the ritchey wcs 4 axis has had a bolt width change at some stage. My new mount doesn't fit.
There are 2 versions of Ritchey stems available, one with a wider bolt patter for extra stiffness which is what I have. 2 new stems on their way. :D
PostPosted: Wed Jan 15, 2014 9:19 pm
I ordered a mount the same time as I ordered my canyon.
This week I noticed that the mount doesn't fit. Unfortunately I can't run another stem on this canyon.
I mailed tilquist about it if I can change it for another mount so I can use the mount on a other bike. So far I don't have a answer :-(
Edit: a had a good proposal from tilquist. Thanks!
Verstuurd vanaf mijn GT-I9105P met Tapatalk
PostPosted: Wed Jan 15, 2014 9:59 pm
Garmin mount for new Giant Contact SLR one piece stem/bar
PostPosted: Wed Jan 15, 2014 10:03 pm
I have send you a mail.....
PostPosted: Thu Jan 16, 2014 12:02 am
Hey Tillquist, I sent you an e-mail regarding Bontrager RXXXL stems. They're 22mm. I don't know if you have anything in that spec.
PostPosted: Thu Jan 16, 2014 5:38 am
I too am interested in the Bontrager xxx lite stem (newest model). The only issue is that the face plate has more of a curve than most (especially compared to 3T arx stem).
PostPosted: Thu Jan 16, 2014 7:30 am
Received my mount yesterday for my Zipp stem. Great quality. Thanks a ton!
Looks so much better than the K-edge mount that I had.
PostPosted: Sun Jan 19, 2014 4:38 am
I am finally getting around to hopefully getting a picture posted. Stem is a Moots Ti stem and I had Tillquist modify the Garmin mount so that the center was not machined all the way through. Plan was to mount the Di2 junction box on the bottom, which worked out great. I took the stock 11 speed mount and cut the tabs off with a razor knife giving me a flat surface. Then some epoxy to hold the Di2 mount to the Tillquist mount. Junction box is easily snapped off if needed. Charging port is easy to get too. Also since the stem cap bolts are recessed the outside diameter of the Tillquist mount fits into the recess in the stem cap. These were measurements that I provided when ordering. I did have the mount anodized black, as it came painted. Great guy to work with.
PostPosted: Sun Jan 19, 2014 10:17 am
Very nice! Looks like I'll be doing that as well (once I build up my 11 speed crit bike in April) making my 3rd Tillquist mount. Good work.
carbonLORD.com
PostPosted: Tue Jan 28, 2014 4:21 pm
Received my zipp mount today and install it. When I mount my garmin on the mount there is no click. Is this normal?
For the rest a great mount.
PostPosted: Tue Jan 28, 2014 4:43 pm
Correct, no click.
carbonLORD.com
Users browsing this forum: AZR3, Baidu [Spider], benzebub, bobones, corky, dcorn, Google [Bot], Google Adsense [Bot], kolau, svendsvin, vladi78 and 46 guests
