Post new topic Reply to topic  [ 14 posts ]
PostPosted: Sat Aug 07, 2004 8:57 pm
I'm looking to build a new front wheel for TT. Weight is a super issue but would appreciate some advice on the hub with the least bearing resistence. I have built wheels with Campy, Shimano, Tune, etc., etc. and price is not a primary consideration
 Post subject:
PostPosted: Sat Aug 07, 2004 8:58 pm
Correction. My post should read "weight is NOT a super issue"....... :oops:
 Post subject:
PostPosted: Sat Aug 07, 2004 9:10 pm
Zipp is very smooth, but much drag from the freewheel when not pedalling.
 Post subject:
PostPosted: Sat Aug 07, 2004 9:13 pm
I'm probably opening a can of worms but I've been riding my Dura Ace hubs lately and they are smooth and have little bearing resistance.
The bearings are free in the hub ( no carrier) and they are larger than my other wheels. If a bearing is twice as large in dia will it spin half as slow given the same wheel rpm?
 Post subject:
PostPosted: Sat Aug 07, 2004 9:17 pm
No, when the wheel does 100 rpm, the bearing will do 100 rpm, no matter how big it is. The bearing will spin even faster (larger route in same time) when it's bigger. But the contact area will be bigger and the load will be better divided.
 Post subject:
PostPosted: Sun Aug 08, 2004 12:47 am
Have you tried or evaluated DT Swiss?
Their "Hugi" (pronounced Her-gee) range is probably the best hubs I have ever used - Phonak also use their hubs.
I use their XR4.1 Rims on my Bianchi MTB, and I can say that my experience with them is very positive.
 Post subject: Not Quite?
PostPosted: Sun Aug 08, 2004 2:26 am
If the outer race is doing 100rpm the larger the ball the slower it has to spin. Try this as a mental picture wheel rolls along the road at a constant velocity which does more revolutions: the one the size of a jockey wheel of one the size of a road wheel?
Success is how far you you bounce back up after being knocked down
 Post subject: Re: Not Quite?
PostPosted: Sun Aug 08, 2004 3:11 am
Exactly. That's also why you have to calibrate the wheel size into your bike computer or HRM.
 Post subject:
PostPosted: Sun Aug 08, 2004 4:42 am
Dura-ace and probably Record have labyrinth (zero contact) seals.
PostPosted: Sun Aug 08, 2004 2:44 pm
No, the outside of the wheel has a higher speed. The hub does as much rpm as the rim -if this is not so you have strange spokes :lol: - and because the diameter of the rim is bigger than the diameter of the hub, the speed is higher. But I think it's not about speed. I think that bigger bearings are better, altough their speed is bigger.
PostPosted: Sun Aug 08, 2004 5:33 pm
The influence of bearing resistance in the total ammount of rolling resistance of a bicycle is lower than the measuring error.
The levers involved are 300mm (outer diameter of the whole wheel) against ~12mm (diameter of BB on hub)
Martin
Snowman and Strong Walker
Scott Sc
my old stuff
my new stuff
 Post subject:
PostPosted: Sun Aug 08, 2004 5:54 pm
Hey, are we talking about linear or angular speed here?
 Post subject:
PostPosted: Sun Aug 08, 2004 7:19 pm
Try removing the grease from the hub/bearings & using parafin instead.The lower viscosity of parafin will reduce the drag in the hub but the parafin will have to be replaced before each event(the grease hole in campag hubs is handy for this).My 2c worth!
 Post subject:
PostPosted: Sun Aug 08, 2004 8:43 pm
use ceramic bearings :lol:
Users browsing this forum: addictR1, bruno2000 and 45 guests
There are no new unread posts for this topic. Advice on Hollowgram set up
quaman26
13
673
Wed Jun 13, 2012 4:29 am
There are no new unread posts for this topic. New bike advice
Wonderman
14
961
Tue Oct 16, 2012 9:42 pm
Wonderman View the latest post
This topic is locked, you cannot edit posts or make further replies. Stripping advice
carbon337
Mon Mar 04, 2013 9:56 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Frame stripping advice.
weeracerweenie
11
928
Mon Jul 23, 2012 1:25 am
weeracerweenie View the latest post
There are no new unread posts for this topic. Carbon seatpost advice
Wonderman
19
1040
Wed Sep 19, 2012 11:07 pm
kulivontot View the latest post
It is currently Fri May 24, 2013 8:09 am
