Post new topic Reply to topic  [ 19 posts ]
Go to page 1, 2  Next
PostPosted: Tue Aug 03, 2004 7:56 pm
I've got a full carbon fork (Giant TCR)... without any star-fangled nut inside for tightening the headset... What are my options for a lightweight component to do this that will work well with my carbon steerer?
 Post subject:
PostPosted: Tue Aug 03, 2004 8:16 pm
Plastique cap....with or without USE Ring-go-star.
Samu @ www.signature.fi
 Post subject:
PostPosted: Tue Aug 03, 2004 8:45 pm
if you are an ultra weight weenie you could:
1) remove your front brake
2) obtain a piece of threaded rod, 2 nuts and 2 washers,
3) tighten the nuts against the washers bearing on the underside of your fork and top of your stem,
4) tighten the stem clamp,
5) remove the rod, nut and washers
6) reinstall brake.
PostPosted: Tue Aug 03, 2004 8:49 pm
Get the Extralight Ultra Star from Lightbikes.com
It reinforces the carbon steerer beside helping with the top cap
 Post subject:
PostPosted: Tue Aug 03, 2004 10:22 pm
http://www.henryjames.com/
Order the Alpha Q kit. This it the best insurance for a carbon steerer as it completely reinforces the tube. The only downside is it is more or less permanent since you glue it in place.
Be sure to clean the ID of the steerer with sandpaper before epoxying the insert. Wet both surfaces with epoxy, position the insert and let cure upside-down with a greased bolt installed in the nut.
 Post subject: That URL doesn't work...
PostPosted: Tue Aug 03, 2004 10:28 pm
do you have a working URL for lightbikes.com or another place that I can get an extralight ultra star?
 Post subject:
PostPosted: Wed Aug 04, 2004 2:55 am
I'm not certain that the AlphaQ kit is compatible with all carbon steerer tubes...apparently the wall thickness of the AlphaQ is thinner than some others (which is why they have the flange kit). The diameter of the alloy tube might not fit all steerer tube inside diameters, I'm not sure.
"Gimondi è un eroe umano, che viene sconfitto ma che continua la sua corsa fino a tornare a vincere." - Enrico Ruggeri
PostPosted: Wed Aug 04, 2004 2:57 am
http://www.sales.light-bikes.com/
 Post subject:
PostPosted: Wed Aug 04, 2004 5:39 am
Alpha Q forks are silly. First you make light fork that has so thin walled stereer that it flex like hell and second you need alloy reinforcement so you could clamp stem to it. If I remember correctly that alloy tube+star weighed ~42g so it's doulble as Rin-go-star (very handy).
Many road forks haven't got hole on bottom on fork so treaded rod can't be used. But you van use normal alloy anchors and take them out after thightening headset. But best solution in to get Stork Stiletto fork, you know what I mean when assembling it. Amaising engineering!
:wink:
But if you must stay on lower quality forks then Extralite may me nice, only 6g!
 Post subject:
PostPosted: Wed Aug 04, 2004 10:37 am
@ Mr_Potatohead
Great tip on star nut savings. I'm running a Pace RC-31 carbon fork on my mtb. My fork does have a hole in the bottom, so I'll be trying that one out.
I currently run 10mm of carbon spacers and a ring-go-star. If it works, I could lose the 10mm spacer, the ring-go-star and cut my steerer tube to a shorter length.
I was considering shortening my steerer tube anyway. I use my mtb on the road 90% of the time and the aero advantages of 20mm off my front end would also help.
Anyone have a rough idea what 20mm of steerer tub would weigh?
 Post subject:
PostPosted: Wed Aug 04, 2004 3:27 pm
3cm weighs about 10g (carbon steerer), so it will be about 6g + the ringostar and the spacer.
 Post subject:
PostPosted: Wed Aug 04, 2004 6:53 pm
I suppose you could use a big ol' carpenters clamp. I would just be concerned about applying the clamping load eccentric to the centerline of the fork tube.
What are these alloy anchors that you refer to?
 Post subject:
PostPosted: Wed Aug 04, 2004 6:59 pm
6) reinstall brake.
Just install expander and top cap and remove it again after adjusting the headset bearings
 Post subject:
PostPosted: Wed Aug 04, 2004 7:38 pm
Alloy Achors...I meaned some sort of expander system that is remoable after use. Not very handy.
 Post subject:
PostPosted: Wed Aug 04, 2004 8:48 pm
yeah that's probably a better idea, my idea is actually from the days of press into head tube headset cups. You can use the same principle to install your own headset without the ol' hammer and block of wood.
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
Users browsing this forum: Yahoo [Bot] and 47 guests
There are no new unread posts for this topic. Attachment(s) Cracked carbon fork steerer?
kets
12
989
Wed Oct 17, 2012 1:49 pm
kode54 View the latest post
There are no new unread posts for this topic. Cannondale slice top cap for use with star nuts
digiadaamore
Sun Aug 12, 2012 2:06 am
digiadaamore View the latest post
There are no new unread posts for this topic. Cervelo Funda, whats the size of star nut
digitalnorbs
Wed Oct 10, 2012 4:24 pm
digitalnorbs View the latest post
There are no new unread posts for this topic. DT Swiss Hub - 36 Step Star Rachet Upgrade
audiophilitis
Mon Feb 11, 2013 2:52 am
audiophilitis View the latest post
There are no new unread posts for this topic. Super 6 evo,steerer top cap
logy
11
1633
Mon Sep 17, 2012 1:10 pm
leosantos View the latest post
It is currently Sat May 25, 2013 3:52 am
