Post new topic Reply to topic  [ 7 posts ]
PostPosted: Fri Jul 30, 2004 10:07 pm
I've got a pair of 2004 Mavic Ksyrium SSL SL's... I've noticed that there is a lot of friction in freehub.... like... I can roll my bike forward and the pedals turn because the freehub doesn't err... freewheel so freely. Anyone have this problem and know how to fix it?
 Post subject:
PostPosted: Fri Jul 30, 2004 11:25 pm
Hi there
We get this problem quite frequently at work at it happens when the freehub starts to get a little dry. Take the free hub off clean thoroughly with contact cleaner and some cotton buds. When you put it back together use a light chain lube and do not grease it as this adds quite a lot of drag and you will be back to wher you started. If you need a diagram of how to get your hub apart look at the mavic website. You will need a 5mm and a 10mm alley key. Hope this helps. dan
 Post subject:
PostPosted: Sun Aug 01, 2004 12:08 pm
Danielson,
Thanks for the tip, as I also have this problem. Where are you from, country?
cheers
Ralph
"the older I get, the better I was"
 Post subject:
PostPosted: Sun Aug 01, 2004 3:19 pm
Use 80W90 gear oil. It has the perfect consistency ensuring correct and long lasting lubrication without leaking excess. When you clean out your hub be careful not to spry on any bearings.
 Post subject:
PostPosted: Sun Aug 01, 2004 6:28 pm
I went to the Mavic site to see the hub diagrams but I could not find them. There is a Technical Manual available but it requires a password to view it. I don't know why they want to keep the manual secret. Has anyone seen this technical manual, and is it worth reading? Can anyone PM me a password so I can read it?
 Post subject:
PostPosted: Sun Aug 01, 2004 6:48 pm
http://www.tech.mavic.com/uk/produits/road/roues.htm
 Post subject:
PostPosted: Sun Aug 01, 2004 7:08 pm
Ralphy-boy I am from London England.
Users browsing this forum: Bing [Bot], Exabot [Bot], SolidSnake03, Vuong05 and 28 guests
There are no new unread posts for this topic. Component friction testing
[ Go to page: 1, 2, 3, 4, 5 ]
howler
65
3812
Thu Feb 14, 2013 12:34 am
fdegrove View the latest post
There are no new unread posts for this topic. Revisiting old school cranks and friction testing
Praha19300
Sat Feb 16, 2013 3:18 am
Praha19300
20
1018
Tue Feb 19, 2013 1:25 am
There are no new unread posts for this topic. Mavic CXR 80
53x12
Fri Jun 15, 2012 11:49 am
wassertreter View the latest post
There are no new unread posts for this topic. Mavic CC SLR rim tape
fogflip
Mon Oct 29, 2012 6:39 pm
madmole View the latest post
It is currently Sun May 19, 2013 1:17 am
