Sram/Truvativ GXP BB
rbrtwyn
by rbrtwyn
Does anyone know what size bearings Sram/Truvativ uses on their new GXP BB? I read somewhere that they use 2 different sizes but I can't find anything that says for sure what the two sizes are.
Thanks.
RollinOn27s
by RollinOn27s
As the two openings are of different sizes, yes, I believe the bearings are also of different sizes.
rbrtwyn
by rbrtwyn
Thanks. Does anyone know what the 2 bearing sizes are?
Ti
by Ti
As far as I know ,they are the same as Shim and FSA.Race Face uses two different sizes.The size should be 37x25x7mm.
Hyde
by Hyde
I can help..."ish". I pulled my extra bottom bracket out of the tool box & took some measurements & did some inspecting...short of pulling the bearings. Well, Truvativ are sly. They have their own dust covers on the bearings with no size defining markings. Here are the measurements I took with my Calipers.
The 2 bearings look to be identical, however the non drive side bearing has a sleeve in it to make the ID Smaller. Here are the approx measurements...
OD 1.45"
ID .940"
ID w/ Sleeve .870" (non drive side)
Width .35"
Sleeve Width .50
Hope this helps
Auk
by Auk
Just got burned by this the past month. Same bearing but, as stated above me, the non-drive has a pressed in sleeve that forces you to buy the Truvative/Sram bearings/cups.
Really no way around it, as there is slop on the spindle otherwise.
Hyde
by Hyde
Looks like it is a "6805" by matching my measurements to the closest bearing size
http://www.vxb.com/Merchant2/merchant.m ... gory_Code=
Hyde
by Hyde
Auk wrote:Just got burned by this the past month. Same bearing but, as stated above me, the non-drive has a pressed in sleeve that forces you to buy the Truvative/Sram bearings/cups.
Why can you not press out the sleeve & repress it into the new bearing? Take it to any decent auto mechanic & he should be able to do it in a couple minutes or point you in the direction of someone with a press who can.
rbrtwyn
by rbrtwyn
Thanks for all the help. Another reason this board is the best!
