Post new topic Reply to topic  [ 27 posts ]
Go to page Previous  1, 2
 Post subject: Re: Spoke holding tool?
PostPosted: Fri Jan 26, 2007 4:10 am
divve wrote:
Also, as tension becomes higher the chance of the spoke yielding from twisting increases.
If the spoke is yielding from twist *without* holding it, it will also yield if you are holding it on the bladed section. The stress that the spoke sees will be the same... same torque, same tensile load. The advantage of *not* holding is that you can easily see the amount of torque (twist) being applied to the spoke.
Maybe it is easier to use a holding tool rather than just overshoot... but I kinda doubt it since you are involving your other hand and have to fit the holder to the spoke.
 Post subject:
PostPosted: Fri Jan 26, 2007 5:44 am
I recieved a set of Bontrager race x lites this year that came with a keychain/spoke holder/spoke wrench, the thing was ill, but I lost it.
Keepin' it Real since like last week or something.
 Post subject:
PostPosted: Fri Jan 26, 2007 11:38 am
No, because you're not holding the spoke in the middle. The tool is best used as close as possible to your spoke key near the nipple. As mentioned previously with high tension the spoke also has a high tendency of twisting without the nipple doing much of anything.
There's no problem in holding the tool. I don't really see why it's hard to use both hands...maybe because I'm ambidextrous it's less of an issue for me :wink:
PostPosted: Fri Jan 26, 2007 1:13 pm
Tubbie Guru
Hi,
The advantage of holding the special spoke key is that you'll feel the spoke resist.
I just can't imagine working on bladed spokes without this sort of tool..... :?
What puzzles me in your statement, and I'm reading between the lines here, is that you seem to imply that any tendency to twist while increasing spoke tension would automatically result in a yielded spoke.
Is this the case or am I reading too much into it?
Ciao, :wink:
 Post subject: my bladed spoke tool
PostPosted: Fri Jan 26, 2007 4:05 pm
This is what I made. It has a 2mm hole recessed 5mm deep at the beginning of the bladed slot. This allows the tool to overlap the transition between the bladed section and the round section of the spoke. This also allows the tool to be as close to the nipple as possible and it significantly reduces the point loading at the end of the tool which can be a problem with other slotted spoke holders.
Cheers,
Jeremy
 Post subject: another view
PostPosted: Fri Jan 26, 2007 4:08 pm
This view shows the overlap.
Cheers,
Jeremy
PostPosted: Fri Jan 26, 2007 7:55 pm
The maximum stress in the bladed portion of the spoke will be the same whether you use a tool that holds the blade, or you just let the spoke twist. The torque applied is governed by the resistance of the threads, and if this torque is resisted by any part of the (weak) bladed part of the spoke the same stress will occur. The only difference will be in the angle of the twist... and I guess the location, since if you are holding the spoke, you know exactly where the highest stress occurs.
So... if the spoke is yielding without the tool, it will also yield with the tool, and if you exceed the yield stress, the maximum amount of plastic deformation will be the same. Maybe confining the yield to a shorter section of spoke is better than letting it occur anywhere in a large span... not sure about that. At least if you confine it to a small length the spoke will still appear to be straight rather than noticably twisted... but the magnitude of plastic deformation and weakening (if any) will be the same.
The only aero spokes I've used were Wheelsmith's, and they are thicker in the middle (1.3mm vs .9mm for CX-Rays). The spoke twist didn't seem excessive without holding them, but I don't know what happens to CX-Rays. I had assumed that normally the yield stress is not exceeded... but maybe I'm wrong... maybe these are taken beyond yield all the time, and the tool is necessary to make sure that the permanent twist is a short one rather than a long one. If this is true, but the spokes are not failing, then I guess it doesn't hurt anything.
Holding the spoke at the round part would eliminate the over-stress completely, though.
PostPosted: Sat Jan 27, 2007 2:53 am
[/quote]Holding the spoke at the round part would eliminate the over-stress completely, though.[/quote]
Like this:
Awhile ago I found a good use for the obsolete Campy chain tool. It has smooth parallel jaws that grip the spoke firmly without damaging the spoke at all. I clamp it around the full size round section of the spoke. I also made a "side entry" nipple wrench so that I can position the spoke holder directly beneath the nipple. I use these tools during the high tension rounds.
Cheers,
Jeremy
PostPosted: Sat Jan 27, 2007 8:29 am
You have a regular machine shop there don't you?
Looks good...
PostPosted: Sun Jan 28, 2007 8:46 am
Jeremy... just wondering if you or anybody else knows where to find a spoke wrench similar to the one you made... ie one that has a long handle that allows space for clamping near the nipple. I know Hozan makes or made one but I can find it in small size (.127") anymore.
PostPosted: Sun Jan 28, 2007 2:48 pm
According to UBT Hozan does not make that wrench anymore and UBT no longer has any of the .127 size. UBT has another one from a company called Cyclus. It is a lot shorter than the Hozan and the head is a lot bulkier, so you can't clamp the spoke as close to the nipple. Also, the tolerance fit seems a little loose to me. Topeak made one as well, but the fit is so sloppy that it is worthless. I eventually gave up trying to find a good side entry nipple wrench. That's why I started making my own. I actually want to find a source to produce these for sale. With my wrench, I can clamp the round part of the spoke 1mm away from the end of the nipple. This eliminates all twist while tensioning. P.S. as a fellow New Mexican, I could probably be convinced to make one for you.
Cheers,
Jeremy
PostPosted: Sun Jan 28, 2007 10:06 pm
Count me in! :D
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Users browsing this forum: adhumston, Bing [Bot], Majestic-12 [Bot] and 78 guests
There are no new unread posts for this topic. Bontrager Aeolus 5 16/16 spoke vs newer model 18/24 spoke
reason
Wed Oct 10, 2012 8:17 am
reason View the latest post
There are no new unread posts for this topic. Attachment(s) Minimalist tool kit / bag
winky
31
1806
Fri Feb 22, 2013 5:41 am
skiezo View the latest post
There are no new unread posts for this topic. Keo Blade spindle tool
ParisCarbon
Sun Apr 21, 2013 3:14 am
ParisCarbon View the latest post
There are no new unread posts for this topic. Wheelbuilding tool - Nipple Starter
runner999
Sun Mar 10, 2013 10:13 am
MajorMantra View the latest post
There are no new unread posts for this topic. RE: Choice of tool to R&R Bb30 bearing.
Y26
7
493
Mon Apr 29, 2013 1:52 am
winky View the latest post
It is currently Thu May 23, 2013 4:38 pm
