It is currently Mon Jan 23, 2017 12:08 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page 1 2 Next
PostPosted: Mon Jul 19, 2004 10:50 pm
American classic makes one but it is $170 and it is only 16g lighter than a much cheaper and more durable dura-ace 12-27.
I am trying to eek out the lowest gear possible with a standard shimano double crankset. I already have a 38t front. I would like to get a 28 in the back as that is the largest cog that will fit a 9spd DA rear derailleur. Durability is not much of a factor as it will be used in hillclimb races ~3 times per year. Cost is a factor because it is hard to pony up that much money for parts the hardly ever get used. Weight is obliously a factor, these are hillclimbs and I need all the help I can get!
 Post subject:
PostPosted: Mon Jul 19, 2004 10:53 pm
That would be a shimano compatable 9 speed cassette that i am after :oops:
 Post subject:
 Post subject:
PostPosted: Tue Jul 20, 2004 2:19 am
check out
http://www.cycle-dynamics.com/
They will make you a combo to your specs. It's full TI (except for the lowest cog).
I have one and love it. I got a 26 - 11 with extra cogs and end cogs. I can run a 26 - 13 or a 19- 11 depending on my race
 Post subject:
PostPosted: Tue Jul 20, 2004 5:31 am
T&A Specialities Kheops may be?
It may be that 24 is biggest option.
Look here:
http://www.starbike.com
Samu @ www.signature.fi
 Post subject:
PostPosted: Tue Jul 20, 2004 8:12 am
Maybe you can buy a 12 - 13 - 14 - 15 - 17 - 19 - 21 - 23 - 25 Dura - Ace or Ultegra cassette, take the 13 away and add a 28 that you drill out a bit...
Whow! That's a pretty damn nice garage door!
 Post subject:
PostPosted: Tue Jul 20, 2004 8:46 am
That is a great idea! thanks, i think i will give that a try. :D
 Post subject:
PostPosted: Tue Jul 20, 2004 10:42 am
I'll use that combi too, when I go to the Elzas region in 2 weeks (with 38-53 up front)
 Post subject:
PostPosted: Tue Jul 20, 2004 10:49 am
It is a long time since I tried last time, but somehow I seem to remember that it is quite difficult to drill holes in hardned steel cogs. I do remember destroying more drills than the number of holes that I was actually able to make.
 Post subject:
PostPosted: Tue Jul 20, 2004 10:55 am
This one's 85 grams :roll:
 Post subject: Cycle Dynamics
PostPosted: Wed Jul 21, 2004 1:36 pm
You can get a 28t Cycle Dynamics cog to go on the back
Success is how far you you bounce back up after being knocked down
 Post subject:
PostPosted: Wed Jul 21, 2004 2:21 pm
How much did you wait for your Cycledinamics ti cassette? I ordered mine on march and Im still waiting for it!!
 Post subject:
PostPosted: Wed Jul 21, 2004 6:33 pm
my only worry is if the 28t cog will cut the freehub body because it is not attached to an alloy carrier. I think i am going to try to JB weld or screw it to a splined spacer
 Post subject:
PostPosted: Wed Jul 21, 2004 6:46 pm
What kind of freehub body do you have?
I've used a 28 t cog without any carrier on an old 8 speed Shimano Ultegra 600 hub for 2 weeks in the Alps and no problems...
 Post subject:
PostPosted: Thu Jul 22, 2004 10:25 am
I will be using it on an American Classic. The freehub bodies on those are, i believe, aluminum. I think the ultegra is steel. I have seen xtr (ti) freehub bodies cut into a little by loose cogs so I want to see if i can solve that problem before it is one.
 Post subject:
 Post subject:
PostPosted: Fri Jul 23, 2004 1:14 am
Cobalt drill bits will work in steel, but they seem to get dull pretty fast. My application was drilling out some seized steel bolts, and I had much better success with straight flute carbide drill bits from J&L industrial supply. Carbide bits are pricey, but this is WW right? You should use eye and breathing protection when drilling as carbide tools contain boron.
http://www.jlindustrial.com/search/searchresults.jsp;jsessionid=BCJK4YH5040R1LAUBIWSFEVMCQFCYIV0?_requestid=181151
Quote:
Use for drilling hardened steel 45-65 Rockwell “C” scale
• Straight flute makes this drill ideal for cutting difficult-to-machine and abrasive materials such as nickel base material, titanium alloys, stainless steels and cast iron
• The straight flute design provides maximum rigidity and reduces tool deflection
• Available sizes 3/64" to 1/2"
• Available in 140º and 135º point angles
There are no new unread posts for this topic. Will a RD6800SS fit a 30T cassette?
zalle
Thu Dec 08, 2016 10:11 pm
zalle View the latest post
There are no new unread posts for this topic. Help me choose a cassette
zalle
10
1254
Thu Dec 01, 2016 7:25 am
mpulsiv View the latest post
There are no new unread posts for this topic. New Campag 11 Cassette
Valbrona
Wed Sep 28, 2016 12:42 pm
benzebub View the latest post
There are no new unread posts for this topic. 11-29 vs 12-29 SuperRecord Cassette
3Pio
35
1818
Fri Dec 23, 2016 2:24 pm
3Pio View the latest post
There are no new unread posts for this topic. Sram etap & 11-30 cassette
rickytek
15
2984
Tue Jun 21, 2016 2:34 pm
Marin View the latest post
Users browsing this forum: Bing [Bot], gtv18, Hovis, joec, mariosimas, ooo, PinaF8, stoney, Yahoo [Bot] and 28 guests
